Old 02-15-2013, 10:29 AM   #1
Deliviox
Member#: 335417
Default What are some methods to clean the engine bay?
I was wondering what are some of the ways people clean their engine bays. What products do you use and how do you apply them? Also any suggestions on what to use to polish and shine as well.
Deliviox is offline   Reply With Quote
Old 02-15-2013, 10:44 AM   #2
Mike05wrx
Member#: 314747
2005 WRX
i just put a bag over the intake and the alternator, and then lightly spray the engine bay, and then spray simple green on it, let it sit for a few, and then get in there with a toothbrush and loosen all the crap. then lightly spray it down and dry it. you can use armor all on the plastic parts to shine it up if you desire
Mike05wrx is offline   Reply With Quote
Old 02-15-2013, 11:04 AM   #3
Deliviox
Member#: 335417
Thanks would like some other suggestions as well. And what I can shine the metal with
Old 02-15-2013, 11:13 AM   #4
Loyale93
Newbie Moderator
Member#: 91347
'13 XV Crosstrek,12
1050 Triumph Speed Triple
Spray simple green over everything
Spray hose on everything
Let dry
Drive car.
Your Dodge car is a little different from our Subarus. In the Subaru, keep in mind that the hood scoop allows water in the engine bay every time it rains, so you really don't need to worry about using a hose and getting water on things. Just watch it around the battery.
Loyale93 is offline   Reply With Quote
Old 02-15-2013, 11:18 AM   #5
thatderekguy
Member#: 301501
black
And intake and alternator
thatderekguy is offline   Reply With Quote
Old 02-15-2013, 11:18 AM   #6
Rex_BoostNY
Member#: 220306
2015 WRX Limited
Derp
Cover intake/alternator/battery wire harnesses. Spray entire bay with scrubbing bubbles, have a beer, rinse engine bay. Win!
Rex_BoostNY is offline   Reply With Quote
Old 02-15-2013, 11:28 AM   #7
Deliviox
Member#: 335417
How long would you let the scrubbing bubbles sit? And how long on the simple green?
Old 02-15-2013, 11:36 AM   #8
Mike05wrx
Member#: 314747
2005 WRX
for simple green i'd say about 5 minutes or so
Old 02-15-2013, 11:37 AM   #9
Rex_BoostNY
Member#: 220306
2015 WRX Limited
Derp
Usually 5-10 mins, youll see when the scrubbing bubbles is doing its work it'll turn brown and run a bit. Some areas may need a little scrubbing, my engine bay didnt but im not sure how dirty yours is.
Old 02-15-2013, 11:48 AM   #10
Deliviox
Member#: 335417
Alright. Any suggestions on a way to shine the non plastic parts?
Old 02-15-2013, 12:12 PM   #11
Rex_BoostNY
Member#: 220306
2015 WRX Limited
Derp
You can apply Adam's In & Out to everything which is my preference, there are alternatives as well.
http://www.adamspolishes.com/p-517-a...out-spray.aspx
Old 02-15-2013, 12:21 PM   #12
G-Sep
Member#: 346983
2013 13 WRX rolling
on oranges
Make sure the engine isn't hot but warm to the touch. If you can't lay your hand on it then it's too hot to wash.
G-Sep is offline   Reply With Quote
Old 02-15-2013, 12:34 PM   #13
p951951951t
Member#: 276541
1972 Alfa Romeo GTV
Alfa Rosso
Also don't get and harsh degreasers on bare aluminum parts. They will start to corrode almost instantly.
p951951951t is offline   Reply With Quote
Old 02-15-2013, 12:43 PM   #14
Deliviox
Member#: 335417
So just stick with sinple green? Nothing like purple power?
Old 02-15-2013, 12:54 PM   #15
Crazy_pilot
Member#: 164242
1992 SVX
2008 Spec B
Before Scrubbing Bubbles:
After:
Crazy_pilot is offline   Reply With Quote
Old 02-15-2013, 12:56 PM   #16
Rex_BoostNY
Member#: 220306
2015 WRX Limited
Derp
Simple Green, Scrubbing Bubbles, either will work. Don't think into it more than you need to, you'll realize when you clean it that its a really simple process. I personally allow my bay to dry a bit before turning the car on. Air compressor, leaf blower, etc lol.
Old 02-15-2013, 01:04 PM   #17
Deliviox
Member#: 335417
Ok well I have scrubbing bubbles so ill just do that and see how it goes
Old 02-15-2013, 01:23 PM   #18
AspenScoob255
Member#: 217405
2006 WRX
Corrode, no...however, it could cause some staining or oxidation if overly aggressive or allowed to dry.
As for cleaning, I have no experience with scrubbing bubbles. I use APC plus and an assortment of brushes to clean the bay. Use a metal polish to bring the shine back on metal parts and a dressing to darken plastics.
In reality it is all pretty straight forward, just use common sense and don't spray water down the intake tube or directly into the alternator.
AspenScoob255 is offline   Reply With Quote
Old 02-15-2013, 01:37 PM   #19
Deliviox
Member#: 335417
Alright ill keep that in mind does the type of netal polish naatter since the heat of the motor
Old 02-15-2013, 01:39 PM   #20
Mike05wrx
Member#: 314747
2005 WRX
i just washed my engine bay. it's beautiful on Long Island today. only took me about 15-20 mins. covered the intake and the alternator
Old 02-15-2013, 01:51 PM   #21
AspenScoob255
Member#: 217405
2006 WRX
The heat of the motor doesn't have much to do with it. A metal polish contains abrasives or chemical cleaners to remove imperfections from a metals surface. It does not leave a protective layer on the surface to be affected by heat, I believe this is what you mean; correct?
What exactly are you polishing?
Old 02-15-2013, 02:28 PM   #22
Deliviox
Member#: 335417
Correct and I just want it looking good for a meet
Old 02-17-2013, 12:56 AM   #23
neomax
Member#: 54585
2013 WRX
The way I detailed engines when I worked at a detail shop was to first lightly spray the engine bay with water. Spray degreaser on everything, I never worried about covering anything in the engine bay. If needed, I'd hit the real dirty areas with a brush, then spray the engine bay down. The trick here is be smart about it, use HOT/WARM water, and if you only have access to cold water spray from a distance. Use the "shower" setting on hose head is avail.
I always left the engine running. I've done hundreds and hundreds cars like this, never an issue on anything, this includes everything from Honda's to Mercs to Maserati's. Many cars were repeating customers and never saw any ill effects from this method. After you've rinsed off the engine, let dry and then apply a nice engine dressing.
Side note: I've always thought it's funny when people insist about covering components and insisting the engine cannot be hot when washing. Has no one opened their hood after driving in a thunderstorm? Or a snowstorm? Or after off-roading? Your engine is completely covered in water and mud. Trust me your engine bay is way hotter when running at high RPM's with the hood closed when that freezing snow is being thrown onto your engine. Again though, this all requires common sense, if the engine is having electrical issues or trouble running, would I do this cleaning method? Of course not!
neomax is offline   Reply With Quote
Old 02-17-2013, 09:07 AM   #24
Frank-i-e
Member#: 316463
2005 STi
World Rally Blue
I just did regular car soap with a bucket and a rag.
Covered the alternator and just was out there cleaning and talking to friends.
Before:
After:
Frank-i-e is offline   Reply With Quote
Old 02-17-2013, 11:51 AM   #25
Jimmy4thenguyen
Member#: 342387
I use APC (the big bulk container from auto geek) and dilute it 4:1 for engines and 10:1 for interiors. PM me is you have questions!
Jimmy4thenguyen is offline   Reply With Quote
