Old 02-15-2013, 04:58 PM   #1
calebtharrell
Member#: 242113
2004 STi, 2008 STi
The White Wolf
2008 Aspen White Subaru Impreza WRX STi
515whp/450wtq @ 25psi on E-85 (Fuel System Limited)
Engine:
-All Internals have been blueprinted and balanced
-New Block halves
-Torque plate honed
-CP Pistons w/ Molybdenum coated skirts (99.5)
-CP Wrist Pins (WPC Treated)
-Crower Billet Rods (Resized to tight FSM specs)
-2012 Nitrided Heat treated Crankshaft (Dynamic Balanced)
-Cosworth Main Bearings Standard Clearance (WPC Treated)
-Cosworth Rod Bearings Extra Clearance .0018-.0020 as measured (WPC Treated)
-Cosworth Head Gaskets .78mm
-ARP Custom Age 625+ Head Studs
Heads:
-Deck/Resurface to high RA
-5 Angle Radius Valve Job
-GSC S2 Camshafts
-GSC Beehive Springs
-GSC Titanium Retainers
-Supertech Nitrided +1 Intake Valves
-Supertech Inconel +1 Exhaust Valves
-Supertech Guides
-Supertech Seals
-Supertech Buckets & Shims
Engine Accessories:
-Crawford V2 AOS
-KillerB Oil Pickup
-11mm Oil pump (WPC Treated Internals)
-Mocal HD 25 Row Matrix 235 Oil Cooler
-Mocal 180 Degree Thermostatic Sandwich Plate
-Mocal 25mm Oil Plate Spacer
-Koyo Racing Radiator
-Samco Radiator Hoses w/ T-Bolt Clamps
-DEI Radiator Additive
-Deleted and Ported TGVs
-Gates Timing Belt kit w/ Water Pump
-Grimmspeed Radiator Shroud
-Grimmspeed Lightweight Crank Pulley
-Grimmspeed EBCS
-Grimmspeed Manual Boost Controller
-Grimmspeed Secondary Air delete plates
-Kartboy Oil Cap
-Kartboy Battery Tie Down
-Omni 4 Bar MAP Sensor
-Subaru Block Heater
-Fumoto Oil Drain Valve
-Optima Yellow Top Battery
-Pro-Bolt Dress Up Bolts & Washers
Turbo & Related:
-GTX3076 .82 AR (Powder Coated Cold Side - Ceramic Coated Hot Side)
-Litespeed Header (Swaintech White Lightning Coated and Ported)
-ARK GRiP Catback Exhaust (cut off neck down section and welded 3" flange)
-Perrin Rotated Up-pipe
-Perrin Rotated Downpipe
-Perrin Rotated Cold Air Intake
-Perrin FMIC (Wrapped with DEI Reflect-A-Gold)
-Perrin Coolant Reservoir
-Tial MV-R 44mm Wastegate
-Forge BPV
-All Exhaust components are Ceramic Coated then wrapped in DEI Titanium
Fuel:
-FIC 1100cc Injectors(1300cc at 55psi Base)
-Deatschwerks 300lph Pump
-Deatschwerks Fuel Pump Hardwire Kit
-Fuel Lab Fuel Pressure Regulator (Set at 55psi)
Drivetrain:
-Clutch/Flywheel Assembly has been balanced
-ACT 6-puck Sprung Disk
-ACT Extreme Duty Pressure Plate
-ACT Streetlite Flywheel
-Cobb Double Adjustable Short Shifter
-Cobb Shifter Bushings
-Torque Solutions Pitch Stop
-Torque solutions Motor Mounts
-Torque Solutions Transmission Mount
Brakes:
-AP Racing 6-Piston Front Big Brake Kit - Competition Gray
-AP Racing 4-Piston Rear Big Brake Kit - Competition Gray
-Goodridge Stainless Braided Lines - Front & Rear
-Ferodo DS2500 Front & Rear (Street)
-Ferodo DS3000 Front & Rear (Track)
-RCE Kool Brake Kit (Cooling Ducts)
-Grimmspeed Master Cylinder Brace
-Motul RBF600 Fluid
Suspension/Wheels:
-Most Parts Powder Coated Stone Bronze (Pictures for Reference)
-AST 4100 Coilovers
-AST Tender Springs F/R
-Hypercoil 8k Front Springs
-Hypercoil 10k Rear Springs
-Vorschlag Camber Plates
-Racer X Fabrication Rear Upper Control Arms
-Cusco Rear Lower Control Arms
-Cusco Front Lower Arm Bar Type II w/ Control Arm Braces
-Cusco Steering Rack Bracket
-Cusco Power Brace Rear Member Side
-Kartboy Endlinks Front
-Kartboy Endlinks Rear
-Whiteline Front Roll Center Adjustment Kit
-Whiteline Rear Adjustable Toe Arms (V2)
-Whiteline Transmission Crossmember Bushings
-Whiteline Rear Trailing Arm Bushings Front
-Whiteline Front 24mm Adjustable Sway Bar
-Whiteline Rear 22mm Adjustable Sway Bar
-Whiteline Rear Sway Supports
-Whiteline Front Control Arm Bushings
-Whiteline Anti-Lift Kit
-Whiteline Steering Rack Bushings
-Whiteline Rear Differential Inserts
-Whiteline Rear Subframe Inserts
-Super Pro Rear Trailing Arm Bushings Rear
-Seals-It Rod End Seals & Boots (On Spherical Bearings)
-Enkei NT03 18x9.5 +27 Touge Factory Limited Edition Flat Black
-Hankook RS-3 275/35-18
-ARP Extended Wheel Studs Front & Rear
-Muteki Black Open Ended Super Tuner Lug Nuts
-New Wheel Bearings Front & Rear (1000 miles)
-High Temp Coated Knuckles & Hubs
Interior:
-Cobb Accessport V2
-Kenwood DNX-7180 Navigation system
-JPM Coachworks Alcantara Padded Steering Wheel - Jet Black - Shark Gray
-JPM Coachworks Alcantara Sun Visors - Jet Black - Shark Gray
-JPM Coachworks Alcantara Shift Boot - Steel Gray - Shark Gray
-JPM Coachworks Alcantara E-Brake Boot - Steel Gray - Shark Gray
-Alcantara Upper & Lower Dash - Jet Black
-Alcantara Cluster Hood & A Pillars - Jet Black
-Alcantara Center Console & Shift Surround - Jet Black
-Alcantara Heater Trim & Side Dash Covers - Steel Grey
-AEM Digital Wideband with RS-232 cable for logging
-AEM Digital Boost Gauge
-AEM Digital Oil Pressure Gauge
-ATI Center Dash Pod Alcantara Wrapped - Jet Black
-ATI 52mm to 60mm Conversion Rings
-Prova Black SI-Dial Knob
-Anarchy Motive 6MT White Heavyweight Shift Knob
-Proto AccessPort Mount
Exterior:
-Overland Designs Custom Painted Headlights Shadow/Black
-JNA Front Lip
-HT Autos Side Skirt Extensions
-HT Autos Rear Lips
-2011+ Front Bumper/Tow Hook Cover
-2011+ Grill & Mustache
-2011+ Foglight Surrounds
-35% Window Tint
-OEM Subaru Rain Visors
-STi Limited Side Badges
-Password JDM V2 Rear Wiper Delete
-VG V1 Shark Fin Antenna
-Subtle Solutions Front License Plate Delete
-Touge Factory License Plate Frame
-Painted Red Tail Lights & 3rd Brake Light
-Vinyl Emblems F/R Gloss Black w/ Gloss White Stars
-White Grill Pinstripe
Index:
Bottom end was built by NF Performance.
Head work was performed by MAPerformance.
Andrew Pace was the previous owner.
Credit due where it is deserved.
calebtharrell is offline   Reply With Quote
Old 02-15-2013, 04:58 PM   #2
calebtharrell
Member#: 242113
2004 STi, 2008 STi
Current Projects
Future Plans
I am looking for input/suggestions on anything you see below.
Fuel System:
-ID1300 Injectors
-Fuel Rails - Black IAG
-Radium Surge Tank with in-tank Walbro 465
-Fuelab 818 series Fuel Filter w/ fiberglass 6 micron element
-Fragola 6000 -8 AN Feed & -6 AN Return PTFE lines
-Fragola Real Street PTFE Fittings
Suspension:
-All uninstalled parts powdercoated Stone Bronze to match my other suspension parts.
-Clean as much as I can and POR15 parts that aren't powder-coated. (Upper Control Arms, Knuckles, Axels etc.)
Interior:
-Alcantara All the Things
-(Dreaming) Status Alcantara Spa Seats
Power:
-Speed Density Tune
-IAT Sensor w/ Extended Harness
-4" Intake
-KS Tech 8mm Phenolic TGV Spacers
-Fluidampr Pulley
-Tial 50mm Q Blow Off Valve
-(Dreaming) Reversed Process West Intake Manifold
Exterior:
Misc:
-Relocated Custom Power Steering Reservoir
-Flat4Motorsports High Pressure Power Steering Kit
-Relocate ABS Pump
-Remove A/C and related parts
-Convert Breather Hoses to AN
-PTP Lava Turbo Blanket
-Powdercoat Misc. Brackets/Pulleys/Items in Engine Bay
Old 02-15-2013, 04:59 PM   #3
calebtharrell
Member#: 242113
2004 STi, 2008 STi
Old 02-15-2013, 04:59 PM   #4
calebtharrell
Member#: 242113
2004 STi, 2008 STi
Build Pictures
Stone Bronze Powder Coat (Will have to get another picture in better lighting)
Old 02-15-2013, 04:59 PM   #5
calebtharrell
Member#: 242113
2004 STi, 2008 STi
The Family
My Daily Driver
My Every Other Weekend Warrior - Soon to be For Sale
Old 02-15-2013, 05:35 PM   #6
silverwerx
Member#: 81246
. .13 EVO X MR
.03 Cosworth Wrx, 14 Jeep
looks good.
silverwerx is offline   Reply With Quote
Old 02-15-2013, 05:36 PM   #7
calebtharrell
Member#: 242113
2004 STi, 2008 STi
Originally Posted by silverwerx View Post
looks good.
Thanks! It is still a work in progress.
Old 02-15-2013, 05:42 PM   #8
DearDiaryJackpot
Member#: 343041
2013 sti
white
Speechless about your historical win.
DearDiaryJackpot is offline   Reply With Quote
Old 02-15-2013, 05:46 PM   #9
ctzn
Member#: 318324
2011 WRX Hatch
's into thread.
ctzn is offline   Reply With Quote
Old 02-15-2013, 10:33 PM   #10
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
You bought this car as-is from MN, right? It was a great build and very well thought out! Looking forward to seeing where you take it from here
xluben is offline   Reply With Quote
Old 02-15-2013, 11:18 PM   #11
calebtharrell
Member#: 242113
2004 STi, 2008 STi
Yes! This is Andrew Pace's old car. I have done a decent amount of things since I bought the car and have much more in store. I started out with an amazing platform to begin with. I had put in tons of research prior to the purchase of this car. My plans were to build my 04, but after finding this car I couldn't justify passing it up. Andrew definitely has a ton of Subaru knowledge and that was obvious through the lay out of the car. I only intend to take it to the next level.
I have followed your thread a little as well. Your photography is top notch and your car is on a great pathway as well. I will be updating this thread regularly and would love for you to leave your insight along the way.
Old 02-15-2013, 11:26 PM   #12
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
Thanks! Andrew did a great job choosing parts. It just needs some more fuel and it can really put down some power! Is it still running MAF? Does the Perrin kit have a 3" intake pipe? Or does it use a 4"? I don't recall from when I saw this car last winter. Unfortunately I never got a ride when it was turned up. Only on his initial, low boost tune. It was still a blast and very responsive for turbo of that size.
Old 02-15-2013, 11:46 PM   #13
calebtharrell
Member#: 242113
2004 STi, 2008 STi
Yes it is currently running MAF. I will be getting a Speed Density tune for sure once I purchase the fuel upgrades. I am pretty sure the Perrin intake is a 3".
I definitely plan on upgrading the fueling, but I will probably sort out all of my suspension mods first. I enjoy flying through curves more so than going fast in a straight line. I live in the mountains and spend most of my time out on back roads.
Old 02-16-2013, 12:52 AM   #14
02rhdsti
Member#: 285803
2006 Subaru
Grey
Sick!
02rhdsti is offline   Reply With Quote
Old 02-16-2013, 01:28 AM   #15
02wrx-sti-man
Member#: 189024
2008 Wrb Sti
Nice ride! I am somewhat local to you, I would love to check it out sometime!
02wrx-sti-man is offline   Reply With Quote
Old 02-16-2013, 10:19 AM   #16
calebtharrell
Member#: 242113
2004 STi, 2008 STi
For sure. I know a decent amount of Subie guys in the Asheville area, we should all get together sometime.
Old 02-16-2013, 10:56 AM   #17
I WANT AN STI
Member#: 79983
2005 STI
my wife's family lives in hendersonville, a little outside of asheville, we go there a few times a year but always drive her tsx cause of the comfort and gas mileage. Love the area and the roads are really fun around their place. If I ever decide to drive my car up there we shall need to get together so you can show me some hidden gems of the mountains ha.
NICE COLLECTION, Im super jelly.
the hatch is badassery...
I WANT AN STI is offline   Reply With Quote
Old 02-16-2013, 11:32 AM   #18
calebtharrell
Member#: 242113
2004 STi, 2008 STi
I am very familiar with Hendo, my sister lives there. You definitely should bring your Subaru next time. We could go for a parkway drive. Amazing scenery and a fun drive as well. Just keep me updated and I am sure we can work something out! Thanks for the kind words!
Old 02-18-2013, 02:03 AM   #19
AaronCKC
Member#: 338621
2013 WRX Limited
Satin White Pearl
Amazing car, Cant wait to see what you do with it later!
AaronCKC is offline   Reply With Quote
Old 02-18-2013, 04:31 AM   #20
RoidRage
Member#: 272471
2010 WRX FlareObody
Red
Sweet build, cant wait to see some dyno graphs!
How are the ASTs + Vorshlag plates? I have the Eibach R2s and Vorshlag Plates and they are good but can be quite harsh sometimes.
RoidRage is offline   Reply With Quote
Old 02-19-2013, 01:08 PM   #21
calebtharrell
Member#: 242113
2004 STi, 2008 STi
The AST's are quite comfortable actually. If I set them to full soft they feel comparable to stock (if I had lower spring rates even more so). My judgement is a little off though because I don't mind a harsh ride. My daily has pretty much every TiC Race Bushing made. The AST's have been my favorite set of coilovers I have driven on. I definitely think they are the best in the price range.
Old 02-19-2013, 01:21 PM   #22
calebtharrell
Member#: 242113
2004 STi, 2008 STi
Just Installed the Vinyl Emblem Overlays
They go nicely with the white/black theme
Old 02-19-2013, 01:48 PM   #23
juanmedina
Member#: 133146
07 FPgreen [email protected]
WRX VF39+E85 12.0, 121mph
nice car
juanmedina is online now   Reply With Quote
Old 02-19-2013, 01:49 PM   #24
calebtharrell
Member#: 242113
2004 STi, 2008 STi
Originally Posted by juanmedina View Post
nice car
Thanks Juan, means a lot coming from a legend like you haha
Old 02-19-2013, 01:52 PM   #25
juanmedina
Member#: 133146
HAHA thanks. It will be nice to see it person and tested out againts mine
