Old 02-16-2013, 07:56 AM   #1
WRBWRXWGN
Member#: 340320
2002 WRX Wagon
World Rally Blue
Default Boost controller question
So I'm putting in an HKS EVC 6 today in prep for a bigger turbo. According to the instructions it wants me to completely bypass the factory boost control solenoid. What I'm wondering is if I bypass the solenoid without immediately getting a tune, how much is my car going to hate me and also, what kind of feedback does the factory solenoid give the ecu (boost pressure/vacuum maybe I'm not sure)? I know I can leave it in the system for the time being if I need to, to just kind of act as a secondary measuring device. My car is a 2002 WRX btw
WRBWRXWGN is offline   Reply With Quote
Old 02-16-2013, 09:50 AM   #2
kellygnsd
Member#: 32669
2007 2.34LR, EFR7670
LINK G4 hybrid STi
Why not just wait to hook it up then.
Old 02-16-2013, 10:08 AM   #3
subie bro
Member#: 327229
2005 Wrx
^ this.
Also if you bypass the bcs without a tune you will over-boost, which causes feedback knock which is no bueno.. Wait to get tuned and then ask you tuner.
subie bro is offline   Reply With Quote
Old 02-16-2013, 12:50 PM   #4
SpongeBobSquarePants
Member#: 296048
2011 STI
Blurple
I would wait as well to install the boost controller. As far as bypassing the OEM ebcs, if you install the boost controller properly you would just turn the duty cycle down on the evc and you should under boost and then slowly add duty cycle until target boost is achieved. I'd keep the boost low until you are able to tune. Hope this helps
SpongeBobSquarePants is offline   Reply With Quote
Old 02-16-2013, 01:47 PM   #5
WRBWRXWGN
Member#: 340320
2002 WRX Wagon
World Rally Blue
Thanks guys, but what's most important to me is finding out what kind of feedback to the ecu that I'm losing if I bypass the factory boost solenoid. Also I was going to do it before the turbo, because the evc in and of itself is a hefty project for install to be done properly. I don't want to have to do the boost controller and the turbo in the same day
Old 02-16-2013, 05:16 PM   #6
Black94Snake
Member#: 274499
1994 5.8T Cobra
565rwhp @ 10psi
Originally Posted by subie bro View Post
^ this.
Wait...what? Boost controller can't reduce wastegate pressure. With the BCS disabled, he won't make any more boost than the spring in the wastegate.
Overboost... Psh, you don't know what you're talking about.
Black94Snake is offline   Reply With Quote
Old 02-16-2013, 09:18 PM   #7
BlazeRex
Member#: 268354
02 WRX 05 LGT
Slow Automatics
He says bypass the BCS, not disable it. I think he means as in disconnect all the lines in the system...
BlazeRex is offline   Reply With Quote
Old 02-20-2013, 09:05 PM   #8
WRBWRXWGN
Member#: 340320
2002 WRX Wagon
World Rally Blue
Exactly. Thank you
Old 02-21-2013, 04:28 AM   #9
jebjkey
Member#: 73884
Chapter/Region: HIIC
16 HyperBlue STi
16 Crystal White STI
Disconnecting all the lines will disable the boost control system.
You can run a hose from the outlet nipple directly to the WG nipple. That will will give you WG spring pressure until you swap your turbo.
jebjkey is offline   Reply With Quote
Old 05-06-2013, 06:18 PM   #10
pyrox
Member#: 345474
02 WRX
240sx 2jz GT4088R
i also want to know
or can someone link us to the right direction. i looked around with no luck
pyrox is offline   Reply With Quote
Old 05-10-2013, 03:20 PM   #11
bcheck555
Member#: 174930
Originally Posted by pyrox View Post
i also want to know
The solenoid provides no feedback.
bcheck555 is offline   Reply With Quote
Old 05-10-2013, 03:36 PM   #12
Concillian
Member#: 4414
2002 WRX Sedan
Midnight Black
The car will pop a CEL if the solenoid isn't plugged in (electrically). So it checks resistance.
That's the extent of how the ECU uses the boost solenoid feedback.
Wire everything, have the hoses ready, but run a hose from compressor nipple to WG nipple to be on spring boost, then hook it up when you get tuned.
Concillian is offline   Reply With Quote
