Welcome to the North American Subaru Impreza Owners Club Friday August 28, 2015
Old 02-16-2013, 06:29 PM   #1
tjmazz13
Member#: 291681
'04 PSM STi
Rotated Borg Warner s256
Default STi consuming lots of oil!
I have a 2004 STi with 117k miles on it and about every 2 weeks I need to add like 3 quarts of oil.
I did a compression test, all the numbers were good.
Checked for leaks, and there were none.
Checked turbo for shaft play, there is none.
What else could it be?!
tjmazz13 is offline   Reply With Quote
Old 02-16-2013, 06:50 PM   #2
HinshawWRX
Medium Frank
Member#: 140114
2014 Porsche
GT3 (Currently on Fire)
Define "all numbers were good?"
Old 02-16-2013, 07:28 PM   #3
tjmazz13
Member#: 291681
'04 PSM STi
#1 - 140psi #2 - 135psi #3 - 145psi #4 - 132psi
Old 02-16-2013, 07:46 PM   #4
05_r6
Member#: 325895
3 qts in 2 weeks is a lot of oil. I have to add about 1 qt every 2000 miles which is about avg from what i hear. Check your intake and intercooler for oil.
05_r6 is offline   Reply With Quote
Old 02-16-2013, 08:30 PM   #5
WaitTheresMore
Member#: 289315
2006 STi
"Frosty"
sounds like a blown turbo seal
WaitTheresMore is offline   Reply With Quote
Old 02-16-2013, 08:56 PM   #6
dellman600
Member#: 346606
sounds like blown ringland to me
dellman600 is offline   Reply With Quote
Old 02-16-2013, 09:17 PM   #7
Slimsti
Member#: 155696
2007 BLK STI Dom3XTR
415/405 Precision Tuning
Compression wouldn't be that consistent. I'd pull the turbo and check for bad seals or a bent fin. Are u blowing clouds of smoke at idle? While cruising? Under boost? Have u ever replaced ur pcv valve? Also check the oil feed line to the turbo. Have someone rev the car to 2500-3000 to build pressure and see if its leaking.
Slimsti is offline   Reply With Quote
Old 02-17-2013, 06:00 PM   #8
carnz-pj-410
Member#: 110994
RS Coupe
1988 FZR400
We are changing his PCV on monday, I know the guy he bought the turbo from and it was mint at the time, anything is possible I know.
His PCV is original and I have a new one for his car in my shop so thats where we are starting.
carnz-pj-410 is offline   Reply With Quote
Old 02-17-2013, 06:06 PM   #9
Cois32
Member#: 294755
2004 Impreza WRX
WRB vf39'd
Turbo.
Cois32 is offline   Reply With Quote
Old 02-17-2013, 10:37 PM   #10
DerekB707
Member#: 220114
07 2.5i EJ257 6MT
Rotated BW S200sx-56
I'd change the pcv and go from there. Hopefully its something simple like that. My buddies wrx was doing the same thing, but not quite as much oil consumption and he traced it down the pcv.
DerekB707 is offline   Reply With Quote
Old 02-18-2013, 08:53 AM   #11
indytruckboy
Member#: 192599
2004 STI
2007 Outback Wagon
the car probably should not be driven in the meantime......
indytruckboy is offline   Reply With Quote
Old 02-18-2013, 12:24 PM   #12
walhalla
Member#: 333084
agreed.
walhalla is offline   Reply With Quote
Old 02-18-2013, 12:43 PM   #13
yenny
Member#: 143116
maybe do a leakdown test
yenny is offline   Reply With Quote
Old 02-18-2013, 07:45 PM   #14
Baja_Gernaut
Member#: 229922
2005 F-Inductd BAJA
rumble black
that sounds about right When I do an oil change with mobile1 synthetics I burn up all four quarts within the 1500 miles. I add another 4 quarts and the oil lasts until the next oil change. I know it sounds crazy but it is so true. I just laugh that I have to spend around 50 bucks in oil between oil changes
Baja_Gernaut is offline   Reply With Quote
Old 02-19-2013, 04:11 AM   #15
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
oh my gawd
this is one of the DUMBEST things i have ever seen posted, here
Old 02-19-2013, 04:12 AM   #16
Uncle Scotty
Member#: 16200
OK buy Nates beans
OP has a blown motor....if it isnt leaking it all over the ground under the engine
its toast
Old 02-19-2013, 01:14 PM   #17
renblock
Member#: 347310
ringland if your blow off valve or recirc valve is unsually oily
renblock is offline   Reply With Quote
Old 02-19-2013, 02:42 PM   #18
trev762
Member#: 280572
2011 sti sedan
plasma blue pearl
Im not sure about that Scotty I think this one takes the cake/
trev762 is offline   Reply With Quote
Old 02-20-2013, 10:30 AM   #19
Fir3Fighter
Member#: 316780
2003 Impreza WRX
Hahaha wtf? Is this real life?
Fir3Fighter is offline   Reply With Quote
Old 02-20-2013, 02:18 PM   #20
tuzzio
Member#: 292532
05 STI
I hope you can't afford to fix it after
tuzzio is offline   Reply With Quote
Old 02-20-2013, 06:49 PM   #21
GrumpyPitbull
Member#: 313311
Say hello to the next generation of Subaru owner lol.
GrumpyPitbull is offline   Reply With Quote
Old 02-20-2013, 07:21 PM   #22
endrswrd
Member#: 323908
2013 BRZ ltd
ISM
No. Just no.
endrswrd is offline   Reply With Quote
Old 02-20-2013, 07:33 PM   #23
C4RBON_F1BER
Member#: 208507
'15 BRZ
OP, have you checked your crank case pressure? I've seen a bunch of oil get pushed through a turbo due to high crank case pressures (not in a Subaru, though). Just something else to check.
C4RBON_F1BER is offline   Reply With Quote
Old 02-20-2013, 08:08 PM   #24
guroove
Member#: 129833
2005 Forester XT
Obsidian Black Pearl
Do a search, and you'll find Uncle Scotty is right. It doesn't mean you need a new engine right now, but if you intend to drive the car like it was meant to be driven, it won't last very long, and it will keep consuming oil until the motor is replaced or rebuilt. I managed to put 40,000 miles on my last motor over the course of over 2 years after it started consuming oil. PCV and turbo oil consumption is never this severe. When it's this bad, it's the shortblock.
guroove is offline   Reply With Quote
Old 02-20-2013, 11:31 PM   #25
WRXSteye20008
Member#: 175565
2014 Sport Premium
Past: 351awhp Sti
I was going through almost the same thing about 2.5qts every 700 miles and it was a broken ringland on #4. Take off you TMIC and see if there is oil in there as well as in your downpipe. A great and simple test; start the car until it is warm, take the oil cap off. Is there any trace of smoke coming from it? It sounds like you are getting massive amounts of blow by as there is no oil present on the outside of your engine. Do you take your car to IAG?
WRXSteye20008 is offline   Reply With Quote
