South East Region Club
Go Back   NASIOC > NASIOC Regional Areas > South East Region Forum
Old 08-20-2016, 06:21 PM   #1
Subbie16
Member#: 435139
2016 WRX Limited-6MT
Pure Red
Default Engine/Transmission mount upgrade Stage 2+ 2016 WRX
I upgraded my 2016 to a full Cobb TBE and Cobb CAI to go to Stage 2+. I wanted to do it right and had my shop swap out the pitch stop mount, transmission mount and engine mounts for all Group N items. Engine mounts needed a spacer that the shop Gerry rigged out of stainless covered in zinc to prevent rusting as they are not a direct fit. However what brings me to the post is the "rubbing noise" that I believe are the einginw mounts. When driving slow and trunk g left or right (say from a stop sign) or accelerating from a stop in 1st it makes this rubbing noise. I also noticed when starting the car the left side of the engine visibly shakes and makes the noise again. I cannot confirm the right side is doing any of this and haw noticed these issues only occur on the left side. I took my tuner for a test drive after he also heard the noise. Threw the car back on the lift and they couldn't find anything rubbing or loose. They had a tech in the car up in the air going thru gears to try and reproduce it but could not. The J pipe is not rubbing anything and everything is torqued down to spec and nothing is missing. Has anyone else who has installed these parts had this issue? The noise is very disconcerting. My tuners (Gold Cobb tuner) chalked it up to NVH. However after starting the car back up after stopping for a few minutes I am not to sure since it only occurs on the left. Anybody have any thoughts of what the noise/rubbing could be?
Subbie16 is offline   Reply With Quote
Old 08-24-2016, 09:18 AM   #2
jaxscuby
Sammo Hung
Member#: 10613
2002 USDM WRX
back in the day when we swapped motor & tranny group-N mounts the only
thing it really produced was more vibration through the steering wheel.
visibly the motor did not shake as much almost non-existent.
did not need a spacer for motor mount. so I would look into that.
group-N are factory so they should fit like factory..
pictures are worth a thousand words.
