Welcome to the North American Subaru Impreza Owners Club Monday June 29, 2015
Old 02-18-2013, 10:52 AM   #1
animalcrackers
Member#: 271364
2002 and 2006 WRX
AW - OPB
Default High pitch sound from speakers as I accelerate?
So I just hooked up my pioneer deck, hifonics amp, and kenwood 12" sub. My friend did the wiring harness on the deck as I wired everything to the back of the car and battery.
Everything sounds good when the engine isn't on but as soon as you turn the car on a high pitch whining sound comes from the speakers and as the rpms go up, so does the sound I can pretty much tell people i have a kenny bell.
My friend said it was caused by the remote/power wire being with the speaker wires but I rewired so everything was separate and nothing. What could be causing this? Is it alternator whine?
Thank u
animalcrackers is offline   Reply With Quote
Old 02-18-2013, 10:52 AM   #2
ABeastinWRX
Member#: 239469
2004 WRX
Alternator whine?
ABeastinWRX is offline   Reply With Quote
Old 02-18-2013, 11:14 AM   #3
animalcrackers
Member#: 271364
2002 and 2006 WRX
AW - OPB
Originally Posted by ABeastinWRX View Post
Alternator whine?
Thats what another buddy of mine said it could be, I've never heard of it though so I'm gonna go with he made that up haha
Old 02-18-2013, 05:18 PM   #4
802-303
Member#: 283194
Pioneer's normally show ground loop issues more than any other h/u's. A few things you can try are.
1) Better grounds. Amp, h/u, and factory subaru grounds.
2) Make sure rca's and speaker wire are complete opposite side as power.
3) ground your rca's to radio ground/ amp ground. (rap copper wire around all 4 rca's, then ground to amp on one end, h/u on other end.)
You are getting a "ground loop" because your dealing with different ground paths between a common system..
802-303 is online now   Reply With Quote
Old 02-18-2013, 05:45 PM   #5
ABeastinWRX
Member#: 239469
2004 WRX
Haha I didn't see you suggested this... I was saying it could be that, my friend had a BMW with the same problem.
Old 02-18-2013, 06:25 PM   #6
Corinator
Member#: 211974
2004 WRX STi PTE6466
2002 Sentra SE-R Spec V
I had this same problem on my Sentra. Ended up using one of the bolts that holds the seat bracket down as a ground and now it is fine. Originally I had it ground out to the handbrake bracket, but I think that had the grounding issue because of the handbrake sensor circuit.
Corinator is offline   Reply With Quote
Old 02-18-2013, 10:28 PM   #7
animalcrackers
Member#: 271364
2002 and 2006 WRX
AW - OPB
Does the remote wire also need to be separate from the power? Thats the only one that runs with the power to the trunk.
Thank you though and everyone else, lemme try everything and ill let you guys know what does the trick
Old 02-18-2013, 11:05 PM   #8
Van Johnson112
Member#: 346968
2004 WRX wagon
48W Crystal Gray
The remote wire is a positive signal so your fine running that with your power. But definitely check your amp ground connection. Make sure its tight and on clean bare metal.
Van Johnson112 is offline   Reply With Quote
Old 02-18-2013, 11:06 PM   #9
802-303
Member#: 283194
Your remote turn on, and power can run down the same side. Rca's and speaker wire down the other. You never want your signal to run with power. If you need to cross the two make sure it's at a 90 degree intersection.
Quality of install is number one, keep it clean. Rca's will benifit when it comes to quality and blocking external interferance. Cheaper rca's work well for subs. But spend some money on jacketed, insulated rca's for your 4ch.
Work on my first post, keep us updated.
"The easiest thing you can do is install a system with noise interferance. The hardest lesson you'll learn is how to prevent it to began with."
-D.E.I instructor I met in my install youth.
Old 02-19-2013, 05:03 PM   #10
thewhiteknyt
Member#: 336644
GRB WRX
WR Blue
Exactly what Johnson said. And when he says bare that really means bare as in scrape off any paint. If that doesn't work try other grounding points, grounding everything at the same point, check your battery and make sure its all and well, if you have a signal processor lift the ground.
Do you have twisted pair RCA's? "Shielded" RCA's really don't do much. When the signal cable (or speaker crossover) is next to the power you are getting "inducted noise"
thewhiteknyt is offline   Reply With Quote
Old 02-19-2013, 06:13 PM   #11
verbalwarfare1
Member#: 347603
2005 impreza
champagne
You are getting ground noise as stated. I installed an earth ground and all of my static noise was fixed.
verbalwarfare1 is offline   Reply With Quote
Old 02-19-2013, 07:44 PM   #12
dbmonster
Member#: 335675
2013 WRX hatch
Obsidian Black Pearl
Great suggestions^
Where do you have your amp grounded?
dbmonster is offline   Reply With Quote
Old 02-20-2013, 10:50 AM   #13
animalcrackers
Member#: 271364
2002 and 2006 WRX
AW - OPB
I have shielded RCA's
And my amp is grounded in the trunk on one of the studs for the trunk latch. Its weird because at first it was grounded with something else (I think the tail light ground) so i moved it to a stud with nothing. This FIXED the interference and everything was sounding perfect for about 30 minutes till it slowly came back. There is some white paint back there so I definitely will sand that down tonight and see what that does.
And what do you mean by earth ground?
Thank you for all of the help everyone.
Old 02-20-2013, 11:10 AM   #14
802-303
Member#: 283194
A trunk lid on a uni-body car is not a ground... (think of how many pieces of metal and bolts that ground path as to travel to get back to ground..) Pull up your rear seat bottom, and sand down the paint by a seat belt bolt. drill, then tap a ground. (look twice, drill once. You have a lot of important things under there.)
Old 02-20-2013, 08:32 PM   #15
dbmonster
Member#: 335675
2013 WRX hatch
That's where I would suggest grounding as well, under the seat bottom right by one of the seat belt bolts. you want you ground point to be on the main uni-body structure of the car. Pick a spot right next to one of the seat belt bolts, get a wire brush wheel that you can attach to a drill and go to town on the paint, you want to have a 1"x 1" square of completely bare metal where you are going to screw your ring terminal down.
Watch this for more advise.
Old 02-20-2013, 09:36 PM   #16
802-303
Member#: 283194
(I'm serious)
dbmonster, I enjoy your back up. I half-ass a reply, and you fill in the details and add sources.. Plus, it's good to see another person adding quality information in this "beat myself in the head" audio thread.
(-End bro-out)
animalcrackers- How's the build? If we don't hear what the solution was, I'm retiring.
Old 02-20-2013, 09:46 PM   #17
dbmonster
Member#: 335675
2013 WRX hatch
Thanks man!
I'm pretty new to this forum, and just trying to help where I can. I'm a noob to the subie world, but I'm a veteran when it comes to car audio, been doing it professionally for 10+ years.
