Old 02-18-2013, 01:12 PM   #1
Daniel Peralta
Member#: 328963
2003 Impreza
Yellow
Default Body Roll Help
Hello guys I'm new to this forums. I want to know more about suspension on my car. I drive a 03 WRX with white-line geometry correction and 22mm F/R sway bay rear are adjustable. My question is my car still have nasty body roll. Even after a stiffer the rear sway bar up. I took off the front u-frame and front bumper beam to make my car lighter. Also taking out the bar underneath the rear seat. What can I do to fight that nasty body roll I'm having. I do some auto-cross in away
Daniel Peralta is offline   Reply With Quote
Old 02-19-2013, 11:15 AM   #2
walhalla
Member#: 333084
you took the beam off inside your bumper! that is your bumper if your in an accident it won't be good. also you may of made it lighter but a lot weaker
walhalla is offline   Reply With Quote
Old 02-19-2013, 01:11 PM   #3
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
QuickSilver Metallic
In that case, I recommend reading (and asking this question in) the Brakes, Steering & Suspension forum, since this forum is clearly not the correct place.
So, you've done little to nothing to address the body roll, and you're wondering why the car still has body roll?
Message Board Statistics All times are GMT -4. The time now is 04:34 PM.
