#1 |
Member#: 306918
Hey everyone. I just wanted to show my 12 WRX blackedout headlights and angel eyes. I know this has been done many times before but I wanted to get this out there to clear up some things that I couldn't find anywhere.
First off I used the new Morimoto xB led angel eyes off of lightwerks. They are the 100mm ones. I could find anyone who had used these before on a WRX so I guessed with the 100's. They fit around the HID bulge and kind of hover as you can see in the pictures. If I were to do it again I would order the 90mm because they would probably fit right on top of the bulge and not hover. Secondly, I used satin krylon fusion paint and I think it has the best look. I did sand the chrome up a little bit but I honestly don't think its really necessary. Also, I used JB weld metal putty to attach the rings which I think is way easier and cleaner than dealing with liquid glue in that tight of an area. Third, Because these LED's last so long I wanted them on all of the time except when the key is out of the ignition. To do this, I grounded each LED to the ground off of the headlight harness then ran the + wire to the under hood fuse box. In the fuse box, there is an empty spot for a relay which gets 12v all the time except when the ignition is off. Also, Make sure you clean the lens every time before you put the lights in the oven. If you don't you'll end up with finger prints burnt into the lens from the oils in your skin. Everything else, I got from this DIY write up. http://www.iwsti.com/forums/how-inst...8-wrx-sti.html Here are the pictures: ![]() ![]() ![]() ![]() ![]()
#2 |
Member#: 261307
South East
Vehicle:04 wrx wagon WRB |
Looks great nice job!
#3 |
Member#: 325412
NESIC
Vehicle:2012 WRX OBP Stg 2 |
Looks killer. Might be my next mod.
#4 |
Member#: 306918
Thanks guys. Just ordered some yellow fog light overlays which will hopefully make it look a little better.
#5 |
Member#: 330059
Vehicle:2013 WRX Limited Satin White Pearl |
Wow looks great, I must do this...is it possible to do red? Is the yellow from the adhesive you used or it that the color that comes w/ the halo assembly? Either way looks sweet! how long approximately did it take you? Difficulty scale 1-10? Any other roadblocks or advice besides the 90mm sizing? Once again, nicely done!
#6 |
Member#: 330059
Hmmm looks like its the actual led light that is yellow, right?
#7 |
Member#: 343626
RMIC
Vehicle:2013 WRX Sedan SWP |
Nice job, looks awesome!!
#8 | |
Member#: 306918
The yellow when they are off is how they come because to have white LED's they have to be coated with a phosphorous layer which is yellow. They sell ones that are white when off but the on color is amber. I didn't have to buy a halo kit because I have the limited which comes with halos. literally all I changed was that yellow LED ring glued to the halo dome and painted the chrome parts and removed/painted where the amber turnsignal light reflector was. With painting and all it took approx 6-8 hours because I waited a while between coats to make sure it was dry and the oven and wiring eats a lot of time as well. No real road blocks other than figuring out what to wire them too. Most people wire them to the parking lights which is the middle level on your light knob. I didn't like that because my head unit dims with the parking lights on so I don't use that setting. I only use all the way off or all the way on for my head lights. To get them to work in that case I had to find a 12v power supply that would be on all the time that the key is past the off position. after a couple hours of sticking my multimeter in every thing under the hood I found an empty relay socket in the fuse box that isn't specified for anything. I found that the power to that relay socket is only on when the key is in and past off, and the power is off when the key is off or removed so I taped into it. As for difficulty, if you have done wiring/painting/and basic mechanical work it is probably a 5-6. If not its probably 8-9 |
#9 |
Member#: 306918
Actually now that I really think about it. If you follow the write up I posted in the original post and my tips here, its pretty easy just really time consuming and a lot of annoying down time waiting on paint to dry and ovens to bake
#10 |
Member#: 303165
Vehicle:2012 WRX SWP |
looks good, i decided i didn't want halos, here's how mine turned out, i also done flat paint
#11 |
Member#: 306918
#12 |
Member#: 303165
i dont have any halos, its just the stock housings painted flat black, the projector is modified to look red when its off, but shine normal when its on (hid), and no my signal lights are regular, the holes are taped over with blue painters tape because my car is in storage for 2 more months and i dont want dust getting in there
#13 |
Member#: 306918
Ohh sorry, I meant projectors not halo's. How are they modified? Now that I look more closely I can see that its tape lol. I thought they were blue bulbs at first.
#14 |
Member#: 346928
SWIC
Vehicle:2013 sti hatch Dark Gray Metallic |
Looks great. Hopefully I'll be doing the same shortly. Thx for sharing
#15 | |
Member#: 338623
SCIC
Vehicle:2011 Subaru WRX red |
#16 |
Member#: 343895
Vehicle:2013 wrx sedan CBS |
^ please that would be greatly appreciated..
#17 |
Member#: 306918
Here ya go guys.
fuse box just behind the battery ![]() The red wire is my + and its plugged into the empty relay spot. ![]() Hope that helps! |
#18 |
Member#: 331262
NESIC
Vehicle:2012 WRX Dark Grey Metallic |
nice write-up, looks really good
#19 |
Member#: 343895
op did u use the corner marker light harness that is an option that comes with the morimotos?
#20 | |
Member#: 241254
Vehicle:2010 STI DGM |
Since we're showing off headlights, I did mine in a krylon carbon grey metallic which comes in pretty close to looking like DGM and has a metallic flake just like DGM. I also went ahead and did the TSXR lens swap which I am really happy with. ![]() |
#21 |
Member#: 338623
SCIC
thanks for the pics. quick question, there are just two wires, black i for ground and red is plugged into that fuser? did you have to connect the red wire together for both LEDS?
#22 | |
Member#: 306918
Heres a link to the lights. http://shop.lightwerkz.net/Morimoto-xBALED-Rings |
#23 | |
Member#: 306918
Hope that makes sense. |
#24 |
Member#: 343895
op ur red wire, is it a metal prong? like the ones that clip into female receptors
#25 |
Member#: 306918
