Welcome to the North American Subaru Impreza Owners Club Tuesday March 31, 2015
Old 02-20-2013, 06:00 PM   #1
SaabaruAero05
Member#: 335112
'05 Saabaru
Red
Default timing belt tensioner question
Just replaced my timing belt, with a gates kit.
Got everything in and last step is to pull the pin on the tensioner. This is a brand new one. I pulled the pin, and it didnt really move. the belt doesnt feel tighter, and i can still put the pin back in it no problem, is this something to be worried about? will it tighten up once i turn the motor over a few times?
thanks guys.
SaabaruAero05 is offline   Reply With Quote
Old 02-20-2013, 06:52 PM   #2
mayer2103
Member#: 301789
03 mustang cobra
white
give it 30 minutes and it should get tight
it just takes time
mayer2103 is online now   Reply With Quote
Old 02-20-2013, 08:49 PM   #3
SaabaruAero05
Member#: 335112
'05 Saabaru
Red
Ok, thanks!!
Old 02-20-2013, 09:21 PM   #4
Uncle Scotty
Member#: 16200
OK Houston
we have an Uncle
yeah....give it 30 minutes to push up and that should do it...dont rev the hell outta the motor for the first couple hundred miles
Old 02-21-2013, 04:33 PM   #5
SaabaruAero05
Member#: 335112
'05 Saabaru
Red
Still hasn't moved, it's been 24 hours since I installed....
Old 02-21-2013, 04:37 PM   #6
cmiovino
Member#: 134005
2004 WRX Premium
At this point, it may be defective. It's always a possibility.
I know I took it easy on mine like Uncle Scotty said. Although, I've never heard of such a thing actually. I still felt it was better to 'break it in'.
I'd highly suggest getting another one.
Old 02-21-2013, 04:52 PM   #7
SaabaruAero05
Member#: 335112
'05 Saabaru
Red
i'm thinking its defective, i'm contacting gates right now, i'll see what they say, hopefully they will send me another one. i do have the old one still, but i would feel better with a new one obviously..
Old 02-21-2013, 07:44 PM   #8
Uncle Scotty
Member#: 16200
OK Houston
we have an Uncle
i saw somebody post that there had been a bad batch of tensioners, lately....dont remember the details, now...but these kinds of things happen
you could use the old one for a bit while ya wait for the new one.....if you re-compress it S L O W L Y in a vise....think half a turn of the handle every 30 seconds.....find a small allen wrench to use as a pin...re-pin it and install it and done
Old 02-22-2013, 12:19 PM   #9
rick-l
Member#: 33868
2003 wrx
srp
Aren't you supposed to compress them with the cylinder vertical?
rick-l is offline   Reply With Quote
Old 02-23-2013, 12:53 AM   #10
bsuby
Member#: 347520
02 wrx
midnight black
no being vertical shouldnt matter I had to compress mine an did it on a vise horizontal an had no problems
bsuby is offline   Reply With Quote
Old 02-23-2013, 02:26 AM   #11
Uncle Scotty
Member#: 16200
OK Houston
we have an Uncle
so rotate the vise to keep it vertical....and for temp use it wouldnt matter
Old 02-23-2013, 11:08 AM   #12
rick-l
Member#: 33868
2003 wrx
srp
I was just pointing out that the service manual says to do it vertically, I don't know why.
CAUTION:
Always use a vertical type pressing tool to move the adjuster rod down.
Do not use a lateral type vise.
