Old 09-19-2002, 02:07 PM   #1
MK19
Member#: 21977
Bear s like food
Default Front Brake Tools for pads
Well, finally got some Stop Tech pads, but I am unsure of what tools I will need. I will be getting some metric sockets and end wrenches. I ascertain I will need allen wrenches too (?)
MK19 is offline   Reply With Quote
Old 09-19-2002, 02:12 PM   #2
Gil
Member#: 20872
t3h rubber-neckers
must die!
Hey,
just did my pads yesterday.
you'll need to remove your wheels (of course). And a 14mm socket to remove the bolts holding the caliper to the "frame?". All you need to do is remove the two bolts on the outside, or even just the bottom one (loosen top one), and dwing the caliper up and have it rest on the rotor/guard.
Also want to think about maybe a C-clamp and a piece of wood to push back the piston (I used the old pads) since the new pads will be thicker than the old ones and you can't fit the caliper over them. took me only about 10 minutes per corner.
- Gil
Gil is offline   Reply With Quote
Old 09-19-2002, 02:23 PM   #3
MK19
Member#: 21977
Bear s like food
GREAT!! Thanks a lot.
Old 09-19-2002, 02:24 PM   #4
cnk
Member#: 10757
2013 BRZ Limited 6MT
Just make sure when you compress the pistons that you take the cover off the brake fuild resevoir so that it's easier to compress. Keep an eye on the resevoir to make sure it doesn't overflow. Use a vampire syringe to suck out any fluid before it overflows. You may also want to use a coat wire hanger or something similar to keep the caliper up so that it doesn't fall down on you while you're working.
Calvin
cnk is offline   Reply With Quote
Old 09-19-2002, 05:02 PM   #5
shogunate83
Member#: 6006
you can use this thing
http://www.sears.com/sr/product/summ...id=00947365000
use that and the old pads... to push the piston back
shogunate83 is offline   Reply With Quote
WTB: Front Brake Rotors & Pads, WTT Quite BOV for Loud Bov ttownscooby NWIC Private Classifieds 13 04-14-2009 04:29 PM
FS: 01 RS Front brake setup, Calipers, pads, brackets and rotors GottaREX Tri-State Area Forum 0 12-22-2005 01:26 PM
2003 WRX Front Brakes - Rotors Calipers Pads Lines Heat Shields crystalhelix Private 'For Sale' Classifieds 5 05-17-2005 11:45 PM
Stock WRX front brakes w/ hawk pads jparent33 Private 'For Sale' Classifieds 8 05-17-2005 04:17 AM
Wanted WRX front brake calipers and pads Longitude Private 'Wanted' Classifieds 2 06-28-2004 11:51 AM
