Welcome to the North American Subaru Impreza Owners Club Saturday August 29, 2015
Old 02-20-2013, 10:44 PM   #1
ScoobieRex2.0
Member#: 310009
03 WRX
MBP
Default Pouring blue smoke at idle
As title states I have a ton of oil burning and blue smoke coming out the exhaust at idle. I don't notice it at any other time but idle. What cuases blue smoke at idle. Would like adobe first before compression test.
ScoobieRex2.0 is offline   Reply With Quote
Old 02-20-2013, 11:59 PM   #2
rymaggi
Member#: 253442
coolant blow by.
rymaggi is offline   Reply With Quote
Old 02-21-2013, 12:03 AM   #3
68Cadillac
Member#: 95901
Coolant burns white.
Oil burns bluish white.
Black smoke means you're running rich.
For you OP you're turbo oil seals may be going.
68Cadillac is offline   Reply With Quote
Old 02-21-2013, 12:43 AM   #4
OC_Nooby
Member#: 311781
2003 WRX w STI V8
Check your downpipe and intercooler for oil. If the car only burns oil at start up/cold start it could be a valve seal. I couldn't see any situation where the car only burns oil at idle and only idle. It would/should get worse with revs/engine load.
OC_Nooby is offline   Reply With Quote
Old 02-21-2013, 01:12 AM   #5
Paul
Member#: 56203
00 RSTI Coupe
Twin Scroll 2.5XTR EJ207
maybe turbo.. Take the oil cap off while idling if smoke comes pouring out its the motor
Old 02-21-2013, 05:01 PM   #6
ScoobieRex2.0
Member#: 310009
03 WRX
MBP
Note: Checked the oil the other day after it was sitting cold for quite some time and found it almost dry so I added about 3 quarts to it. Checked it again the day after and it's reading about an inch above the full line. I didn't understand it.
Also: broke the motor in with 10-30 oil with ZDDP additive. Changed the oil to rotella t6 @ 1k the day after I got a tune. Prior to the tune and oil change I did not notice the smoke. Not sure if this would provide any useful insight or not.
Old 02-21-2013, 05:03 PM   #7
Junior2JZ
Member#: 64908
10.8 XT+10.0@143 GR+
2x9.0@170mph GTRs
stock motor or built?
Smoke at idle can be valve seals, but if it started after a tune.. I would consider possible short block damage
Junior2JZ is offline   Reply With Quote
Old 02-21-2013, 05:04 PM   #8
Junior2JZ
Member#: 64908
2x9.0@170mph GTRs
http://forums.nasioc.com/forums/show....php?t=2468364
After reading your 117% IDC I would go with a melted piston, cracked ring.. Especially in the cold ass weather the NE has been seeing
Old 02-21-2013, 08:58 PM   #9
Paul
Member#: 56203
00 RSTI Coupe
^ouch...that will do it.
Old 02-21-2013, 11:03 PM   #10
ScoobieRex2.0
Member#: 310009
03 WRX
MBP
Would this cause smoke from the oil fill/cap as well? I hope it's a valve although either way, unless its just from an overfill, it's $$$$
Old 02-21-2013, 11:22 PM   #11
Nuke209
Member#: 108089
2003 WRX
NF Performance
Sure it's not the turbo? j/w
Nuke209 is offline   Reply With Quote
Old 02-22-2013, 12:07 AM   #12
rymaggi
Member#: 253442
My valves are leaky, gonna need a rebuild in the next 15-25k. So I get blue ish white smoke on start up. Could be your rings giving out like mine.
Old 02-22-2013, 05:04 PM   #13
Junior2JZ
Member#: 64908
2x9.0@170mph GTRs
If you have the smoke from the fill cap, then yes.. you have more then likely collapased, cracked or melted a piston.
Old 02-22-2013, 08:34 PM   #14
ScoobieRex2.0
Member#: 310009
03 WRX
MBP
What about a floating intake valve? I lve been hearing a whining noise in boost around 4k rpm. Thought it was a boost leak so I redid all IC and intake hoses. Didn't see much oil in the process. I get a good amount if engine noise at idle but nothing crazy and definitely don't think it's not since its not heard throughout he band.
Old 02-22-2013, 08:49 PM   #15
Paul
Member#: 56203
00 RSTI Coupe
Dude if you have a decent amount of smoke coming from the oil filler your motor is toast. Like Jr said most likly a piston. Its sucks but pull the motor and see what the damage is.
Old 02-22-2013, 09:39 PM   #16
wrxsubiemod
Member#: 165104
E85 SoCalPorting
Phatron tuned
What about a floating intake valve? I lve been hearing a whining noise in boost around 4k rpm. Thought it was a boost leak so I redid all IC and intake hoses. Didn't see much oil in the process. I get a good amount if engine noise at idle but nothing crazy and definitely don' think it's not since its not heard throughout he band.
Sounds like a turbo if Its whining
wrxsubiemod is offline   Reply With Quote
Old 02-22-2013, 09:43 PM   #17
jaxscuby
Sammo Hung
Member#: 10613
2002 USDM WRX
maybe both, blown turbo and melted piston.
you won't really know until you take it apart.
compression test will tell which piston is toast.
leak down test might also tell you which cylinder is toast.
Old 02-23-2013, 03:05 AM   #18
ScoobieRex2.0
Member#: 310009
03 WRX
MBP
Yea but its coming from the driver's side. Not the turbo. Sounds like TMIC noise.
Old 02-23-2013, 01:01 PM   #19
rymaggi
Member#: 253442
Just take it to a reputable shop. Have a leak down and compression test. That will tell you
Old 04-13-2013, 07:39 PM   #20
ScoobieRex2.0
Member#: 310009
03 WRX
MBP
So no one has ever had or heard of blue smoke only at idle? There is NO smoke coming out of the oil filler. I am using rotella T6 5w40. Should I try a thicker oil? 5w50? I replaced the PCV valve and check the turbo (no shaft play whatsoever). I haven't gotten around to compression test yet. There is no oil in my coolant or vice versa. I have heard that these motor are NOT typically known for valve seal failure. I do however have a question about my heads (I know souls have gotten them inspected before the swap). One of the valves, not sure if on the intake side or exhaust side, had a bit of play to it. I noticed I while cleaning that it would rotate slightly (from left to right) with enough pressure. Would this or should this have been a cause of concern? If so would that indicate a bad guide/seal?
Old 04-13-2013, 10:47 PM   #21
grandchrist
Member#: 335037
1999 rs
white
my car did exactly the same thing than your and it appear to be a bad valve seal
(take of the manifold and look in the head port if the valves shaft look oily cause mine was)
grandchrist is offline   Reply With Quote
Old 04-13-2013, 11:46 PM   #22
bswilmington
Member#: 217563
2006 Sti 12.68 @ 108
321WHP 422WTQ dynojet SAE
I did, cracked ringlanding. Car would only smoke at idle and the hotter I got the motor(racing it), the more it would smoke at idle. When sitting in staging area it would blow massive amounts of smoke. If I drove normal, the car would only have puff or 2 at idle and not really appear there was a problem.
Vacuum would also flutter at idle. It almost acted like bad valve stem seal, but it had massive amounts of blowby. Ran like a champ until it died
bswilmington is offline   Reply With Quote
Old 04-14-2013, 10:08 PM   #23
grandchrist
Member#: 335037
1999 rs
white
so have you found your trouble
Old 04-15-2013, 05:23 PM   #24
ScoobieRex2.0
Member#: 310009
03 WRX
MBP
Did you experience smoke from the filler tube?
No I have not figure out the problem yet.
Old 04-15-2013, 06:09 PM   #25
bswilmington
Member#: 217563
Yes. I had a lot of ring blowby.
