Welcome to the North American Subaru Impreza Owners Club Sunday August 28, 2016
Old 02-21-2013, 08:44 AM   #1
PlasmaWRX
Member#: 335428
2012 WRX
Plasma Blue Pearl
Default Weird sound when closing door after Q300 install
Hey everyone, I installed a Q300 catback in my 2012 wrx hatch back in August. For the past few months I have heard this weird spring metal type noise when shutting the drivers side door. The sound is louder underneath the car. When driving, the car enters boost and peaks properly. No sounds/smells of an exhaust leak. I took some videos, one at normal standing height and one with the camera near the drivers side skirt.
I broke my leg so I havn't driven in 2 months, but hopefully I can get under it soon to determine what it is.
PlasmaWRX is offline   Reply With Quote
Old 02-21-2013, 11:39 AM   #2
MacAlert
Member#: 70965
2013 WRX STI
ISM
Sounds like something is loose and rattling around. Make sure all bolts/connections are tight and nothing is rubbing against the exhaust.
MacAlert is offline   Reply With Quote
Old 02-21-2013, 12:27 PM   #3
goswald79
Member#: 119292
2003 WRX
Sonic Yellow
Is your car on jack stands? Sounds weird, by my driver door makes the same noise when on four stands. I had mine up in the air for about a month, taking my time with some upgrades and maintenance. I noticed the same noise, and it went away when she was back on the ground.
Now, I will note that I have a GDA chassis and your profile says you are in a 2012.
I did not diagnose mine, but I am betting it is some minor chassis flex. I was looking at ladder bars and fender braces as a possible solution.
Hope it helps. May not, but I tried.
goswald79 is offline   Reply With Quote
Old 02-21-2013, 02:55 PM   #4
PlasmaWRX
Member#: 335428
2012 WRX
Plasma Blue Pearl
Yes I am in a 2012, I am thinking it is the heat shield down there, the one between tranny and exhaust. I think it is just hitting on the new wider exhaust at one point.
Old 02-21-2013, 02:58 PM   #5
Mr Wrex
Member#: 332887
2012 WRX stage 2+
DGM (sedan)
Did you make sure all the heat shielding was bolted down tightly? I somehow missed a bolt when I installed my q300 and it made that noise til I found it
Mr Wrex is offline   Reply With Quote
