Old 06-11-2013, 09:50 PM   #401
apollo_f1
Member#: 230535
2013 Sport Prem. MT
Dark Grey Metallic
Originally Posted by aeoporta View Post
you are not the only one torn between both the enkei and the sparco that's what it came down to for me I just lucked out and bought both so I can switch back and forth. I use the stockers in winter they are slightly heavier but they do look nice.
I ordered the Sparcos in grey along with a set of Michelin X Ice tires ($91 a piece at the Tire Rack), I'll be set for Winter now. (yes I know it's a little early)
apollo_f1 is offline   Reply With Quote
Old 06-12-2013, 01:07 PM   #402
aeoporta
Member#: 334126
2016 2.5i Premium MT
Dark Gray Mettallic
nice price might as well get ready for winter thats what I usually do so that I can get the winter stuff for cheap.
aeoporta is offline   Reply With Quote
Old 06-12-2013, 04:19 PM   #403
apollo_f1
Member#: 230535
2013 Sport Prem. MT
Dark Grey Metallic
I figured it was nice wheels and nice tires now or wait til the fall and have to settle for cheaper wheels since the tires would be more expensive.
And the Tire Rack just phoned me to verify I knew that the sensors would need to be initialized at a dealership and that the order is ready to ship.
Old 06-13-2013, 01:51 AM   #404
garamas
Member#: 169194
04 STI
Heres how the car sits today on 18x9.5 +34 Varosten 2.2.1 235/40/18 which rub like crazy every where
BC coils pretty much all the way down in the front only about 1in of adjustment left in the front
garamas is offline   Reply With Quote
Old 06-13-2013, 12:07 PM   #405
Dijm8
Member#: 337144
2012 Impreza Hatch
Ice Silver
whats rubbing? im still waiting for my coilovers arrive before i put my wheels on, have you noticed the front fenders come rolled from factory, just need to get the rear rolled.
got spacers ordered too, 25mm rear and 10mm fronts and also need to get rear trailing arms too to adjust camber to negative
also ill be going 205/40
Dijm8 is offline   Reply With Quote
Old 06-13-2013, 12:46 PM   #406
aeoporta
Member#: 334126
Dark Gray Mettallic
They need to stop telling ppl that
http://forums.nasioc.com/forums/show...&postcount=137
Old 06-13-2013, 01:48 PM   #407
garamas
Member#: 169194
04 STI
rears are rolled with a slight pull but it hits on the back bumper tab which is normal happened on my evo and on my buddies WRX
fronts were rolled too but have tons of clearance the main thing thats rubbing is the inner fender liner (again an issue ive delt with before with slammed cars)
my main issue is that my tires a huged 235 on my next set if wheels i will go 215 all the way around
Old 06-13-2013, 01:49 PM   #408
jsteg
Member#: 329271
2012 Impreza Limited
Ice Silver Metallic
I think they're assuming most people won't spend $150 on a tool to avoid the $100 dealer fee...so in that case, they're right!
jsteg is offline   Reply With Quote
Old 06-13-2013, 06:11 PM   #409
aeoporta
Member#: 334126
Dark Gray Mettallic
Except if you change over each year the cost adds up. A regular tire shop with the proper tools should be able to update the ecu my shop was able to do it no problem eventhough I had the ateq. Dealership, no thank you.
Old 06-13-2013, 08:03 PM   #410
Dijm8
Member#: 337144
2012 Impreza Hatch
Ice Silver
thanks
yeh i had major issues with my last car in the same spot too...
Old 06-15-2013, 01:02 AM   #411
apollo_f1
Member#: 230535
2013 Sport Prem. MT
Dark Grey Metallic
My Sparcos Michelin combo arrived today. They look great and are pretty light. Although I admit the last wheel I moved was a 285 70/16 off of my F-150 I sold just after getting my Imp.
Old 06-15-2013, 10:57 AM   #412
nitroman
Member#: 347203
2013 Impreza
Just wondering does anyone see a problem with 17" +50mm offset wheels? I'm looking at the enkei RFS5 but the 17" only comes in +50. I could get the 18" which comes in +45 but that increases the price of the tire/wheel package and I'm on a really tight budget.
I used an offset calculator and the inner clearance would be 8mm less and the other position would extend an extra 4mm (compared to my stock). How do I measure if I'm going to have issues? Turn my stock wheels all the way to one side and see how much room there is on the inside corner?
nitroman is offline   Reply With Quote
Old 06-16-2013, 12:55 AM   #413
LGA2011
Member#: 321173
Actually the oem wheel are +48 of offset. There's only 2mm of difference between the oem. The older impreza wheel are at around +55.
LGA2011 is offline   Reply With Quote
Old 06-20-2013, 01:44 AM   #414
protohype
Member#: 360004
2012 impreza sport
white
Default Will these fit a 2012 impreza sport
Hey I'm new to all this love my 2012 impreza sport looking for some new shoes. I like the spacing of these tires and rims on the WRX will they work for the impreza? It is the white wrx on page 9 of this thread...sorry not to technically competent when it comes to forums
protohype is offline   Reply With Quote
Old 06-20-2013, 06:13 AM   #415
garamas
Member#: 169194
04 STI
this one is rota g force 18x9 they will work fine unless you lower the car then it will prolly need to have fender work
Old 06-20-2013, 12:18 PM   #416
protohype
Member#: 360004
2012 impreza sport
white
thanks! now its about getting my hands on some used ones. I will sell my stock gunmetal 12 impreza sports, also looking for brz/frs wheels if anyone knows anything about where to dig up any of those or knows someone who would like my wheels feel free to get in touch
Old 06-20-2013, 09:27 PM   #417
myrt1987
Member#: 323103
2012 Limited 2.0i
Dreamy Gray Mistress
Update your profile, that will help with sale.
Old 06-20-2013, 10:13 PM   #418
Nimrodd
Member#: 345821
Default Enkei G5
Nimrodd is offline   Reply With Quote
Old 06-21-2013, 07:50 AM   #419
uspopo
Member#: 317014
2015 WRX Limited CVT
ISM
+1 Nimrodd...
uspopo is offline   Reply With Quote
Old 06-21-2013, 01:00 PM   #420
aeoporta
Member#: 334126
Dark Gray Mettallic
for some reason i started singing like a g6 when I saw your pics nimrod
+2 very nice
Old 06-21-2013, 07:32 PM   #421
Nimrodd
Member#: 345821
Fly like g5! Lol thanks!
Old 06-21-2013, 08:45 PM   #422
jsteg
Member#: 329271
Ice Silver Metallic
What?! Lol
Old 06-22-2013, 02:49 AM   #423
Dijm8
Member#: 337144
2012 Impreza Hatch
Ice Silver
got some 25mm spacers the other day so was playing around today, still have my wheels sitting in boxes untill my coilovers arrive from Cusco (not till august as ther on back order)
so as you can see what look ill be going for, got some more parts coming from cusco aswell...bring on that negative camber !!
Untitled by Dijm8, on Flickr
Old 06-22-2013, 08:44 PM   #424
sexyypants
Member#: 347122
Does the 08+ Wrx suspension really work on our cars?!
Cuz if so im so buying a set
sexyypants is offline   Reply With Quote
Old 06-22-2013, 10:44 PM   #425
Nimrodd
Member#: 345821
Originally Posted by jsteg View Post
What?! Lol
Nothing lol
