Old 02-23-2013, 10:04 PM   #26
subi305
Member#: 152449
2003 Impreza WRX
correct i did do the pull after swaping maps and putting 93 oct. blacksnake i would find someone with a maf but i dont know anyone here with a wrx.
subi305 is offline   Reply With Quote
Old 02-23-2013, 10:06 PM   #27
subi305
Member#: 152449
2003 Impreza WRX
should i still do the 3rd gear pull? btw?
Old 02-24-2013, 08:45 AM   #28
Black94Snake
Member#: 274499
1994 5.8T Cobra
565rwhp @ 10psi
Find a god damn maf...
Black94Snake is offline   Reply With Quote
Old 02-24-2013, 09:00 AM   #29
Black94Snake
Member#: 274499
1994 5.8T Cobra
565rwhp @ 10psi
Since you clearly don't understand how this forum works, I have spent my precious minutes of morning poop time, calling out to the members of the SE region. Just simply to show you how.
http://forums.nasioc.com/forums/show....php?t=2472273
Old 02-24-2013, 02:56 PM   #30
subi305
Member#: 152449
2003 Impreza WRX
listen I appreciate the help and I have been on this forum for quite sometime. Some people are just not as mechanically inclined as others. I dont feel like I need to be bashed for asking questions. But I viewed what you did for me and I Really Really Appreciate all of your help. thnx snake
Old 02-24-2013, 04:42 PM   #31
Black94Snake
Member#: 274499
1994 5.8T Cobra
565rwhp @ 10psi
Check out this item I found on eBay: http://pages.ebay.com/motors/link/?n...d=380565002272
Old 02-24-2013, 09:23 PM   #32
subi305
Member#: 152449
2003 Impreza WRX
well if thats the case ill by it asap. I just dont understand why the maf would not let me hit target boost? either way i uploaded the 91 acn map on 93 oct. I did another log here it is if you wanna take a look.
https://docs.google.com/spreadsheet/...Wc&usp=sharing
Old 02-24-2013, 09:56 PM   #33
Black94Snake
Member#: 274499
1994 5.8T Cobra
565rwhp @ 10psi
I'm going to laugh hysterically when you blow up your car.
Stop driving like an *******, you clearly have a serious problem.
You need to stop reflashing your ECM. You car is trying to tell you something and by resetting you are basically telling it to go F itself. Try driving the car normal for a few days and see what your A/F Learning values do.
Have you not noticed that your MAF values never exceed 150ish g/s? If you had a boost leak your MAF values would be normal, but your boost wouldn't hit target values. Your car is creating pretty severe knock corrections, even after a reflash. That right there should tip you off that you need to stop driving lick a dick. The only other thing that *COULD* create the symptoms you are seeing, is a post maf leak and a broken BCS, or a post maf leak and a severe boost leak.
If the MAF isn't registering the full amount of air that is entering your intake, you could infact be running so lean that you cant even produce a full combustion inside the cylinder. If you aren't getting enough out of the engine, you wont spool the turbo so make higher boost.
If you truly don't care about your engine (which you clearly don't) add your a/f sensor to your datalog. I'd be willing to bet that you don't see it ever get down near your target a/f ratios.
Old 02-25-2013, 11:38 AM   #34
Cobb Tuning
Member#: 4803
So I bought my brand new accessport after having my car for three years. After installing it and uploading a 91 oct stage 2 map I data logged it and here is what i came up with.
P.s. my modds are ebay turbo back, uppipe, and drop in filter, also have a turbo xs mbc. (I'm a little concerned with the boost if any one can help lmk.
here is my data log
https://docs.google.com/spreadsheet/...2c&usp=sharing
Hi there. You have a lot going on here. First thing is that an MBC is not compatible with our maps. Depending on how you have it set up, the MBC can completely remove the engine control unit (ECU) from boost control, meaning that any boost problems would be due to the MBC and not anything specific to the tune. An MBC is not necessary with these cars - you can get more than adequate boost control with the factory boost control components and ECU.
You also have quite a bit of perceived knock in these logs, as indicated by the low DAM. You mentioned that you were running 89 octane at some point. This could certainly cause issues when trying to run a 91 octane map. This could cause the DAM to drop as you've seen. Then you reflashed the 93 octane map after filling up with 93 octane gas. If the tank was not near empty, the effective octane could also be lower from the mix of 89 and 93.
At this point, I would take the car to a professional Subaru tuning shop and have them do a once-over on the car.
Bill
Old 02-25-2013, 12:10 PM   #35
subi305
Member#: 152449
2003 Impreza WRX
thnx for the help. will do.
Old 03-05-2013, 12:38 AM   #36
subi305
Member#: 152449
2003 Impreza WRX
*update*
cleaned maf today withe maf cleaner. it was black! also am in the process of cleaning the injectors. put some Lucas lube in it with a full tank. anything i should look out for?
Old 03-05-2013, 05:53 AM   #37
jebjkey
Member#: 73884
Chapter/Region: HIIC
16 HyperBlue STi
16 Crystal White STI
Were there any change in the AF Learning values and/or how the car drove after you cleaned the MAF?
Have you taken your car to anyone to get looked over yet?
jebjkey is offline   Reply With Quote
Old 03-14-2013, 06:48 PM   #38
subi305
Member#: 152449
2003 Impreza WRX
I haven't had a chance yet due to
Finances . Feels smoother, I wanna take it this weekend. Should I run a log driving slow?
