Old 02-22-2013, 12:58 PM   #1
2.5gtbx_44
Member#: 249306
2006 Legacy spec B
Titanium silver
Default EFI Logics built and tuned 665whp 581wtq '06 Legacy AMS rotated kit 6466
Event: dyno pull
Ambient Temp: 35*ish
Elevation: 482 feet above sea level
Weather: Sunny, cold
Tires: Nitto NT05 245/40/R18
Car: 2006 Legacy spec B
Tuner: Mike Botti
Dyno Info: Mustang
Transmission:'08 STI 6spd
Gear: 4th
Peak HP at RPM: 664.9 whp at 6695rpm uncorrected 630whp corrected
Peak Torque at RPM: 581.2 wtq at 5421rpm uncorrected 550.9 corrected
Baseline hp/tq for a stock on same dyno: 219 hp 228 wtq stock 08 LGT
Target Boost: 37.5 psi
Target AFR: 11.2-11.5?
Fuel: e85
Engine/Power Modifications:
AMS 750R Rotated kit retrofitted w/ precision 6466
4" intake
STI manifold swap
EFI logics custom FMIC
Invidia race ELH
Top feed conversion
Perrin top feed fuel rails
Top feed TGV deletes
ID 2000 injectors
Tial Q BOV
EFI logics custom fuel system including SX power regulator, Marren fuel dampener, radium engineering dual external Bosch 044 Surge tank and various fittings
Aeromotive 340lph pusher fuel pump
Accessport v2
Full speed density
Efi logics custom side exit exhaust
Blitz FATT Turbo timer
Mishimoto X-line radiator
All exhaust components swaintech coated (header, up-pipe, turbine housing, downpipe and ewg dump tube)
EFI Logics stage 4+ motor:
JE Billet FSR pistons
JE proseal head gaskets
AEBS sleeved block with custom water jackets and o-ringed
K-1 crankshaft balanced
Manley H-plus rods w/ ARP 625+ hardware
Killer b oil pick up
Killer b windage tray
Killer b oil pan
ARP block bolts
ARP 625+ head studs
ACL main and rod race bearings
Supertech +1mm intake and exhaust valves
Supertech dual valve springs
Supertech titanium retainers
Cosworth S2 camshafts 278/274
Custom bowl blending
mild porting
Gates racing timing belt
ATI harmonic damper
Modded sti 11mm oil pump
water pump
new pulleys etc
NGK iridium 1 step colder plugs
Brad Penn oil
Driveline Modifications:
08 sti transmission
08 sti r180 rear end
08 spec b driveshaft
08 spec b rear axles
ACT 6 puck extreme clutch
Driveshaft shop custom front axles
Suspension Modifications:
Tein Flex coilovers
Tein edfc
Perrin 25mm FT and RR swaybars
Whiteline steering rack bushings
Whiteline Ft and rr Front control arm bushings
Whiteline Roll and bump steer kit
Whiteline ft and rr diff bushing kit
Whiteline rear control arm bushings
Enkei NT03 18x9.5 +40mm
H&R 5mm spacer in ft
ARP hardened and extended studs
Muteki R35 extended open ended lugs
2.5gtbx_44 is offline   Reply With Quote
Old 02-22-2013, 01:00 PM   #2
Stretch18
Member#: 239822
2010 WRX
t(-_-t)
Jesus Christ...
Stretch18 is offline   Reply With Quote
Old 02-22-2013, 01:03 PM   #3
jay25RS
Member#: 4273
2015 Taco
& 2015 Legacy Ltd.
This is amazing. Truly.
jay25RS is offline   Reply With Quote
Old 02-22-2013, 01:09 PM   #4
02rex62
Member#: 215004
02 Rex
I wanna go fast!!!!!
Badass!
02rex62 is offline   Reply With Quote
Old 02-22-2013, 01:13 PM   #5
tazswing
Member#: 63767
2009 OXT 5-spd
2011 STi hatch
wow. were those mods all done at the same time? I love seeing subarus pushed into the 30psi range!
tazswing is offline   Reply With Quote
Old 02-22-2013, 01:15 PM   #6
Farfrumwork
Member#: 10202
'07 Spec B
'85 EJ25 Syncro Westy
Yes, that IS badass.
Great spec there
(haha - hilarious the camera following 2 people filming with phones..)
Farfrumwork is offline   Reply With Quote
Old 02-22-2013, 01:15 PM   #7
2.5gtbx_44
Member#: 249306
2006 Legacy spec B
Titanium silver
They were done mostly over the course of a year or so. The transmission was in there for a couple years though. lol
Old 02-22-2013, 01:23 PM   #8
juanmedina
Member#: 133146
07 FPgreen [email protected]
WRX VF39+E85 12.0, 121mph
Is the turbo ball bearing? what intercooler core are you running?
Congrats!
Old 02-22-2013, 01:24 PM   #9
Nuke209
Member#: 108089
2003 WRX
NF Performance
Congrats!
Comes in bb only
Nuke209 is offline   Reply With Quote
Old 02-22-2013, 02:34 PM   #10
NW2TONE
Member#: 212509
unde your hood makin
your **** go faster
put that plastic manifold back on!!!!!! it will spool better and make more power!!!!
NW2TONE is offline   Reply With Quote
Old 02-22-2013, 02:40 PM   #11
ASF Machine
Member#: 236349
1993 Impreza
OD Green
Yuck.
ASF Machine is offline   Reply With Quote
Old 02-22-2013, 02:57 PM   #12
CTSparky
Member#: 282204
2011 5 Door STi
Plasma Blue Pearl
Like he needs more power...
CTSparky is offline   Reply With Quote
Old 02-22-2013, 03:32 PM   #13
Zee Biker
Member#: 166005
2005 Saab 92x
Beaten Silver
Originally Posted by ASF Machine View Post
Yuck.
This will be exciting.
I'm loving the powerband and how quick it seems to spool, but am a bit confused on the power VS. turbo. It's running a ton of boost but doesn't seem to make the numbers I expected out of a 6466, mustang dyno or not. Seems more characteristic of what I'd expect out of a 6266 with the spool/peak.
EDIT: I look rather hostile and do not intend to be at all, sorry.
Zee Biker is offline   Reply With Quote
Old 02-22-2013, 03:41 PM   #14
jnorth85
Member#: 76785
2000 580Whp The RSTI
SRP
totally agree, a friend of mine just had his Evo X tuned with a 6466 on E85 and made 908WHP and 40PSI
jnorth85 is offline   Reply With Quote
Old 02-22-2013, 04:09 PM   #15
Rex_BoostNY
Member#: 220306
2015 WRX Limited
Derp
I believe that was dyno'd on his more "conservative" tune
Rex_BoostNY is offline   Reply With Quote
Old 02-22-2013, 04:11 PM   #16
BlazeRex
Member#: 268354
02 WRX 05 LGT
Slow Automatics
500 wtq at 4700rpm? Not too shabby
BlazeRex is offline   Reply With Quote
Old 02-22-2013, 04:50 PM   #17
Junior2JZ
Member#: 64908
10.8 [email protected] GR+
9.1/157mph 2015 STI
Great numbers! This thing should trap in the 140s
The 6466 works very good, spools nice and can make some serious power up top. I broke the 900hp range last week with one on an EVO9
Junior2JZ is offline   Reply With Quote
Old 02-22-2013, 05:41 PM   #18
spoolinred
Member#: 117017
03 2.0fpred wrx!!
blue
What size back half is this turbo? I got the 6466 with .82 hotside. These are great numbers but i would of thought at 37 psi it would lay down a little more.
Still impressive and should be a beast on the street.
spoolinred is offline   Reply With Quote
Old 02-22-2013, 06:52 PM   #19
2.5gtbx_44
Member#: 249306
2006 Legacy spec B
Titanium silver
Comparing evos to subarus are like apple and oranges man. That evo was prob spinning at like 9500rpm. We stopped at 7300 with a valvetrain good for 8000+. My engine builder and myself agreed on leaving it here for now for sake of longevity. I drive my cars hard. It could have easily made 675-700 on that dyno. For those who are not familiar with EFI logic's dyno it reads rather low. Even lower still than other mustang dynos. I appreciate your feed back but, with no basis for comparison is rather pointless.
It was "relatively" conservative for 37.5 psi. Didnt even spin it to 7500 as stated above.
Thanks man. Mikey was stating the same thing. Should trap in the 140s. If I can get it to hook should be low 10's high 9's
Yea mine is also the .82 hotside. Please read the above. For comparison an alpha 10 put down 740 on that same dyno.
Horsepower numbers aside this should speak for itself...
Old 02-22-2013, 09:32 PM   #20
ASF Machine
Member#: 236349
1993 Impreza
OD Green
243 crank horsepower baselining at 219whp doesn't quite strike me as low reading.
That aside, I'm quite excited to see the trap speeds. Nice job doing it big on a platform not many do it big on.
We <3 the 6466!!
Old 02-22-2013, 09:36 PM   #21
Psychoreo
Member#: 79643
2015 WRX STI
Terminal black pearl
This car was silly before. It's plain retarded now. Nicely done to all involved.
Psychoreo is offline   Reply With Quote
Old 02-22-2013, 09:37 PM   #22
wrxhard
Member#: 108091
HAHAHAHAHA. Subacabra... Love it!!! Plus it hauls!!!!!
wrxhard is offline   Reply With Quote
Old 02-22-2013, 09:56 PM   #23
2.5gtbx_44
Member#: 249306
2006 Legacy spec B
Titanium silver
We <3 the 6466!!
We are excited to see the trap speeds as well. I mispoke on the 219hwp. Stock LGT makes 181whp 180wtq on that dyno. Stock vs my plot:
http://efilogics.com/dyno/graph.php?...rgb2=204000000
Old 02-22-2013, 10:22 PM   #24
jnorth85
Member#: 76785
SRP
Video Link: http://youtu.be/FKm54s2EhJA
I follow you. The evo spun to 8k similar build specs to yours sleeved, forged etc. However it was running the 1.03 hotside which would help bump the power a little more.
Looking at your curve power started to drop near redline so adding RPM wouldn't have gained you much. Unless I'm not seeing it correctly.
Old 02-22-2013, 10:38 PM   #25
Psychoreo
Member#: 79643
2015 WRX STI
Again. That's just silly
