Old 03-21-2013, 03:07 PM   #76
Rememo
Member#: 340728
2013 Impreza 5-spd
Originally Posted by webster354 View Post
Do you guys recommend removing the front wheels or is there enough clearance?
There isn't any reason to remove the wheels.
I just finished installing my Outback fogs, but I didn't have any fog lights at all, so I had to install the switch and relay also. Took me about an hour to do everything.
Since it was in the 20's AGAIN today, I was lazy and didn't even bother running the car up onto my ramps. I didn't have any problems accessing anything, although it would make it a bit easier to have the car on ramps.
When it warms up, I'll align them to spec. A quick check has them aimed pretty low, so I should be OK for the time being.
If anyone needs a set of stock Impreza fogs, I have a pair, since they came with the install kit.
Rememo is offline   Reply With Quote
Old 03-21-2013, 03:59 PM   #77
webster354
Member#: 343343
2014 Impreza 5dr Ltd
OK, thanks for the ramps tip.
webster354 is offline   Reply With Quote
Old 03-27-2013, 10:04 AM   #78
scoutisimo
Member#: 315759
2014 WRX Hatch
Satin White Pearl
Placing my order now. I have the base with no fogs currently. I found part numbers for everything needed.
To all who are wondering about part numbers...
relay 82501AG041
switch H4510FJ000
ivory bezel 83472FJ010WJ
chrome trim rings 57731FJ030 and 57731FJ020
scoutisimo is offline   Reply With Quote
Old 03-27-2013, 10:15 AM   #79
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
Used these this morning in <1/4 visibility this morning, really not much better than stock.
Only advantages I see so far:
1. Glass lens
2. H11 bulbs
My opinion might change once I get overlays installed.
Old 03-27-2013, 10:16 AM   #80
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
relay 82501AG041
switch H4510FJ000
Ordering the outback fogs?
Old 03-27-2013, 10:28 AM   #81
scoutisimo
Member#: 315759
2014 WRX Hatch
Satin White Pearl
I'm on the fence on the outbacks or stocks... price difference is only $40 but it just seems so much easier to just plug in the oem ones and be done with it. But... the outbacks look like they have some black in the housing like the headlights.. would look cool with yellow bulbs..
Anyone with the outbacks.. do they In fact match the headlights better appearance wise or is it just the pics playing witg my head?
Old 03-27-2013, 10:35 AM   #82
MackDaddy
Member#: 15451
2016 Accord EXL Navi
Lunar Silver
I don't know maybe the new housing with 24W H16's are really good. but to me, the Outback assemblies with 55W H11's should be FAR superior to the OEM stock units. That just makes sense to me anyway.
I'm by no means "unhappy" with my stock OEM units (and I'm getting old too, so I NEED these to help me see at night.)
I'm still on the fence to upgrade to the H11 Outback units, but most likely will. If for no other reason, to allow easier procurement of replacement bulbs at a reasonable cost.
Just my .02
MackDaddy is offline   Reply With Quote
Old 03-27-2013, 11:32 AM   #83
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
They look about the same as the stockers
Old 03-27-2013, 12:12 PM   #84
scoutisimo
Member#: 315759
2014 WRX Hatch
Satin White Pearl
What bulb do the stockers run?
Nevermind. Just saw it in the original post.
Old 03-27-2013, 02:00 PM   #85
scoutisimo
Member#: 315759
2014 WRX Hatch
Satin White Pearl
So I think i'm going to go stock fogs. I cannot find the wiring anywhere in there. I pulled the circle mesh cover where the fog goes and looked around through there, I was under the hood poking around. Some guidance may be necessary. lil help?
Old 03-27-2013, 02:17 PM   #86
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
They come down out if the wires up just a little.
Did you try the factory instructions free from techinfo.Subaru.com?
My factory fogs are still for sale /shameless plug
Old 03-27-2013, 02:18 PM   #87
sgoldste01
Member#: 322264
2012 Impreza Sp 5sp
Obs Blk Prl/Drk Gray Mtl
Never mind.
sgoldste01 is offline   Reply With Quote
Old 03-27-2013, 02:21 PM   #88
Rememo
Member#: 340728
2013 Impreza 5-spd
Yeah... it took me awhile to find the driver's side plug. As you're looking into the hole, it's off towards the passenger side. It's taped onto the existing wires, so it won't just be dangling down. The passenger side wiring is off towards the driver's side as you're looking into the hole.
One you find the driver's side plug, you'll feel dumb for not seeing it right off.
I was going to snap some photos while I did mine, but it was too damn cold.
Old 03-27-2013, 02:49 PM   #89
fistv
Member#: 350063
2013 Impreza sport
Personally I don't see any upgrade working that keeps the fog lens so far back it's won't spread out. The fogs on all my jeeps are Hella or CIBIE and pretty much all my vehicles have had aftermarket lights on them that are lowdown, upfront and out in the wind so to speak. Maybe now that it's warming up I'll look at how to overcome that recessed fashion factory placement. :-)
fistv is offline   Reply With Quote
Old 03-27-2013, 03:04 PM   #90
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
i think that is part of the problem, but at the same time even in their location they do light up everything they are supposed too. they aren't driving lights, and honestly i was a little dissapointed they didn't work better than factory this morning in the dense fog. overlays may help and independantly wiring them probably would (but on a relatively busy interstate, i'm not driving w/o headlights on because it is illegal and there are usually troopers out there)
Old 03-27-2013, 05:56 PM   #91
fistv
Member#: 350063
2013 Impreza sport
I setup my jeeps with fogs, ecodes and two true driving lights.
Set the jeep back about 30 feet from a concrete wall, yard stick and chalk line, turn on fogs, you end up with a straight line at the top of the fogs, in my case 18", transfer that to the wall and shoot a chalk line, I adjust them on the wall to the same physical height as the top of the fog light housing, that puts all the light down low, the e codes have the same line on low beams, they also get adjusted to the same height as the line on the headlight housings, when the high beams come on they light above that low beam light, fogs go out then when the driving lights come on they drill though the top of the high beams for distance. The fogs not only light up down low but light up the sides of the road, a side benefit of this is it tends to anchor any deer by freezing before they step into the road and get frozen by the headlights which is why I like good fogs. The other thing I miss is being able to run with fogs and parking lights on those soupy mornings when all I want to see is the lines on both the center and shoulder of the road.
Old 03-27-2013, 07:25 PM   #92
webster354
Member#: 343343
1. Glass lens
2. H11 bulbs
What brand of bulbs are you using?
Old 03-27-2013, 07:53 PM   #93
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
Osram (German), they came with the assemblies
Old 03-28-2013, 05:49 PM   #94
scoutisimo
Member#: 315759
2014 WRX Hatch
Satin White Pearl
Just ordered all my parts! Can't wait for them to get in! $148 for everything is not bad. I'm going for yellow bulbs instead of overlays just to be different.
Old 03-28-2013, 05:55 PM   #95
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
even the fogs are in that price?
Old 03-28-2013, 06:01 PM   #96
scoutisimo
Member#: 315759
2014 WRX Hatch
Satin White Pearl
Yep. Was only 108 for everything through subarugenuineparts.com and i even got the chrome rings.
Fogs were the $40 oem from ebay.
The bulbs were and extra 14. I just ordered them too. just no namer yellow bulbs.
So all in total was 162. not too shabby.
Old 03-28-2013, 06:28 PM   #97
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
nice.
Old 03-28-2013, 06:37 PM   #98
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
when you do your install can you post pics of the relay location? I am still tempted to do the independent mod but the relay looks to be burried in the dash
Old 03-28-2013, 06:44 PM   #99
scoutisimo
Member#: 315759
2014 WRX Hatch
Satin White Pearl
Will do. Ill take pics of a stock housing with yellow bulbs too. I'm hoping they reflect in there enough to give a slight yellow hue while off.
Old 03-28-2013, 09:49 PM   #100
Rememo
Member#: 340728
2013 Impreza 5-spd
Since I didn't have fogs, I had to install the relay. It's buried, but it isn't hard to get to. Pop off some trim, pop out the glove box (I actually left mine in), remove a bunch of screws, and pop out the area around the glove box. I didn't complete remove the area. Once it's loose, you can just reach up behind it to plug in the relay.
Sounds worse than it is.
