Old 03-29-2013, 04:14 PM   #101
Blackmamba24kb
Member#: 330797
2012 Impreza 5dr Prm
Satin White Pearl
Originally Posted by Rememo View Post
Since I didn't have fogs, I had to install the relay. It's buried, but it isn't hard to get to. Pop off some trim, pop out the glove box (I actually left mine in), remove a bunch of screws, and pop out the area around the glove box. I didn't complete remove the area. Once it's loose, you can just reach up behind it to plug in the relay.
Sounds worse than it is.
yup its actually easier than it sounds. just got to unscrew a few screws and remove the grey/silver panel, the glove box and thats it. you can technically reach under it all i think but it might be a pain to find the slot.
Blackmamba24kb is offline   Reply With Quote
Old 03-29-2013, 04:29 PM   #102
Blackmamba24kb
Member#: 330797
Satin White Pearl
Originally Posted by ans2k View Post
The DIY: Use this as a reference. http://techinfo.subaru.com/proxy/661...FogLampKit.pdf
There are three Clips on the bottom of each fog light. You have to stick a flat head between the head of the clip and the body of the clip, clip and the car. Then twist and pull it out. There are one on the side and two towards the front.
Then you need to remove one bolt. Yes, one bolt is all that is securely holding the foglight in place.
Here is a comparison picture between the stock and the outback.
This is how the old fog light is mounted in the car. I removed the cover just to show you the comparison of how it looks mounted. You don't have to remove the cover, but it could make it easy. Just push from behind.
This is the new one.
I will get a picture with them on later tonight. and a comparison picture some time next week or just go look at your own. LOL
UPDATE!
Comparison pictures. These were at my parking garage incline. I did one facing towards the incline and one down the incline.
Facing up incline Headlights only:
Facing up incline, head lights and fog lights.
facing down the incline head lights only:
Facing down the incline, head lights and fog lights:
holy moly! thats a huge difference bc i can barely notice my stock fogs when they are on even with the yellow film over them..
i will need to highly consider this swap. ill be in touch hehe
Old 03-29-2013, 04:57 PM   #103
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
Did you aim your stock ones? I don't notice much difference between properly aimed stock and these.
And these seem to building condensation
Old 03-29-2013, 05:01 PM   #104
Blackmamba24kb
Member#: 330797
Satin White Pearl
not sealed properly? weird....i did aim them, but maybe i didnt do a good job. ill have to mess with it since you said you didnt notice that big of a difference....but shouldnt be be noticeable since the wattage is higher in your new fogs?
Old 03-29-2013, 05:19 PM   #105
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
it is a little brighter, and the same area is lit up (so i think i got them pretty dang close) but in dense fog (airport was reporting 500ft of forward visibility this morning) they still don't do much. it could just be the lack of color differential
and both lights are building just a little condensation in the same spots, so I'm not sure.
Old 03-30-2013, 08:39 AM   #106
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
I double checked my aim this morning, they are currently about 4.5" low at 10ft and should be 2.4" low, when I get my overlays on I will fix that
Old 03-30-2013, 08:59 AM   #107
scoutisimo
Member#: 315759
2014 WRX Hatch
Satin White Pearl
I noticed many new imprezas on the dealer lot this morning had no chrome rings around the fogs. Are these from the kit only? I may end up returning these unless they look really cool.
scoutisimo is offline   Reply With Quote
Old 03-30-2013, 09:45 AM   #108
sgoldste01
Member#: 322264
2012 Impreza Sp 5sp
Obs Blk Prl/Drk Gray Mtl
Or do the Limiteds have the chrome trim, while the other Impreza models don't?
sgoldste01 is offline   Reply With Quote
Old 03-30-2013, 10:04 AM   #109
Guzzi 1
Member#: 338666
2014 Impreza Limited
SWP/Blk Leather CVT
FWIW, I was able to reach up and feel where that relay went, then reach up and stuff it in without removing anything. Bottom right of relay block as I recall.
When I installed the fogs on my car, the kit came with shiny trim around the fogs. I could have popped off the blank plate and used the original parts too if I wanted to.
John
Guzzi 1 is offline   Reply With Quote
Old 03-30-2013, 10:05 AM   #110
Guzzi 1
Member#: 338666
SWP/Blk Leather CVT
You are correct. Unless you add them from the accessory catalog.
John
Old 04-10-2013, 02:10 AM   #111
webster354
Member#: 343343
2014 Impreza 5dr Ltd
Received my fog assemblies. Here's some unboxing pictures and a Subaru Parts Warehouse mini review:
Pricing: Very good (especially with the spring coupon).
Ordering processing: 1 business day
Shipping (to WA): 5 business days
Packaging: Good
webster354 is offline   Reply With Quote
Old 04-13-2013, 09:08 PM   #112
scoutisimo
Member#: 315759
2014 WRX Hatch
Satin White Pearl
Originally Posted by scoutisimo View Post
Will do. Ill take pics of a stock housing with yellow bulbs too. I'm hoping they reflect in there enough to give a slight yellow hue while off.
As promised, here are pics of the relay location. If you just put the seat back and lay on the floor and look up behind the glovebox it is literally right there. It's so easy, a caveman could do it. (note the new relay for the fogs is the big grey one that sticks out.)
Also, as stated in previous posts, to all concerned about locating the wires for the assemblies; once you pop the fasteners on the bottom of the front bumper, and pop the assembly covers off the wires are right there taped to the frame rail. Mine had blue tape. Very easy to locate. This mod is very easy and I think anyone could do it.
I went with yellow bulbs instead of overlays, they fogs do not appear as yellow as I had hoped with the reflection when not lit, but they do their function when on.
Old 04-15-2013, 09:50 AM   #113
fistv
Member#: 350063
2013 Impreza sport
The whole downside of these and the stock fogs is you cannot turn of the headlights to get their most effective, the light reflected back from the low beams reduces the effectiveness of the fogs.
fistv is offline   Reply With Quote
Old 04-15-2013, 01:52 PM   #114
cdlong
Member#: 147834
2013 Impreza Sport
1995 240sx
cdlong is offline   Reply With Quote
Old 04-15-2013, 04:11 PM   #115
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
as soon as I get a chance in a few weeks, I think I am going to look into finally doing this.
Old 04-15-2013, 04:12 PM   #116
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
Originally Posted by cdlong View Post
that is the older gen, the new one is slightly different. i am going to look into the wiring diagrams today
edit: colors appear to be the same, just the relay is in a different location
Old 04-15-2013, 04:47 PM   #117
fistv
Member#: 350063
2013 Impreza sport
Rather than trying to put lipstick on a pig and get any kind of decent light from the factory fogs I think I'm going to go for a pair of Hella fogs in the lower grill area. That way I think I can run the DRL's and parking lights then manually control the fogs to start then wire the hella fused relay though the DRL's for switch power to operate the relay. I have not actually looked at what lights come on with the first setting just that the DRL's come on as soon as I put it into drive so I don't know if I have tail lights at that point. Won't do any of this until I figure out how to mount them.
Old 04-15-2013, 05:06 PM   #118
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
drls are just that, the drls only, no other lights come on
Old 04-16-2013, 10:18 AM   #119
fistv
Member#: 350063
2013 Impreza sport
Flicked on the parking lights and I get rear markers and front markers, I'll look around for an unused fuse that is ignition controlled to operate the hella fused relay and grab light power from the battery. There are a heck of a lot of bulbs in those light housings.
Old 04-16-2013, 11:33 AM   #120
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
Parking lights are supposed to be the front and rear markers so what you saw is correct.
I would just go straight to your battery for the relay power and tap a light near the housing for the trigger
Old 04-19-2013, 01:26 PM   #121
MackDaddy
Member#: 15451
2016 Accord EXL Navi
Lunar Silver
Cool
Did the upgrade, hardwired H11 pigtails in (good ones, not the junk from Autolumination,) and upgraded the OEM H11 bulbs to Philips X-Treme Vision.
Done. Nice upgrade.
Thanks for posting!
Decent H11 Pigtails on eBay
For those that don't want to splice:
H11 to PSx24W Harness
MackDaddy is offline   Reply With Quote
Old 04-19-2013, 01:39 PM   #122
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
Done. Nice upgrade.
Thanks for posting!
Let me know if yours build up some condensation in them after 20+min of use, mine have been when it is cold out
Old 04-19-2013, 01:41 PM   #123
MackDaddy
Member#: 15451
Lunar Silver
Hmmm... interesting.
Shall do sir.
Old 04-20-2013, 10:29 PM   #124
MackDaddy
Member#: 15451
Lunar Silver
Report thus far: No condensation as you stated FlyBoy. It was fairly cold here today too, 45 deg.
I'll keep tabs on them and report if I find different results..
BTW - Philips X-treme Vision H11's in both low beams, and fogs are a great upgrade!
Old 04-21-2013, 12:22 AM   #125
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
I have yet to use mine in that warm of a temp every time I have noticed it was in fog around 30F
/endless winter
