Old 02-23-2013, 04:04 PM   #1
bigredlovesimpreza
Member#: 289795
2008 Impreza WRX
Default Help routing Vacuum line
I am currently working on installing my SPT boost gauge and the only issue I am having is routing my Vacuum line through the firewall. I was wondering if anyone had any helpful tips on how to do this because I am only able to feed it about 2-3 inches then it gets stuck.
bigredlovesimpreza is offline   Reply With Quote
Old 02-23-2013, 06:03 PM   #2
bigredlovesimpreza
Member#: 289795
2008 Impreza WRX
I was able to feed it through but I could not locate it at all. It sounded like it was behind the cloth when inside the car. If anyone knows what I am saying help would greatly be appreciated. I have everything else ready to go I just need to feed this line
Old 02-23-2013, 07:14 PM   #3
bigredlovesimpreza
Member#: 289795
2008 Impreza WRX
Finally got it. Now I feel like a big derp.
Old 02-23-2013, 07:24 PM   #4
nmlittlebigman
Member#: 321409
2003 Big Effing Van
7.3L powerstroke diesel
Glad you got it. It's funny how these 1 hour jobs turn into to half the day
nmlittlebigman is offline   Reply With Quote
Old 02-26-2013, 05:57 PM   #5
bigredlovesimpreza
Member#: 289795
2008 Impreza WRX
Right??? At least I was able to figure it out haha
Old 02-26-2013, 07:22 PM   #6
akfmx
Member#: 226059
Icy Silver
Legacy
Which grommet did you poke it through? I'll be doing a boost gauge install soon.
akfmx is offline   Reply With Quote
Old 02-26-2013, 08:08 PM   #7
m1r4g3
Member#: 220476
2--> 06 STI & 12 Leg
WRB & SWP
there is a hole by on the drivers feet
m1r4g3 is offline   Reply With Quote
Old 02-27-2013, 12:58 PM   #8
bigredlovesimpreza
Member#: 289795
2008 Impreza WRX
There's a plug near the center of the car, feed the line in. If you try and force it to the driver side it won't feed, but if you allow it to go where it wants it will. I did that early in the stage, but couldn't find the line. Finally I got the idea to check from the passenger side. If you go there and see reach into the small gap behind the center column of the car you should be able to grab the line. I then took a wire hangar and fed it through to the other side. It makes the job much easier. If I figured that out earlier it should have only taken an hour or so
Old 02-27-2013, 01:51 PM   #9
grinch77
Member#: 198758
2004 STi
Tape the line to a solid piece of 12g wire makes it a lot easier to feed and pull.
grinch77 is offline   Reply With Quote
Old 02-27-2013, 02:24 PM   #10
akfmx
Member#: 226059
Icy Silver
Legacy
I think I will try the grommet in the drivers side fender well.
