Old 02-23-2013, 07:59 PM   #1
belac88
Member#: 276917
91 Legacy ss
Pearly white
Default ea82 turbo
so i just bought an 87 subaru rx turbo coupe. it handles awsome for an 80's car but i just want to know what other nasioc members have done to get more umph outa the little 1.8???? ill put pics up soon.
belac88 is offline   Reply With Quote
Old 02-23-2013, 08:28 PM   #2
ballitch
Member#: 74907
98 cam'd EJ251
Wrx Tranny,slowr than ish
Some have swapped the TD04 from the wrx onto that motor, with good results, and some with a few toasted motors.....
You might try the usmb, i'm sure that info is over there.
~Josh~
Old 02-24-2013, 12:45 AM   #3
belac88
Member#: 276917
91 Legacy ss
Pearly white
That's what I've been reading. I also read that if u put a mbc and stock tmic off a wrx and open the exhaust up a little I can boost to 10 psi with not too much worry but do I need to upgrade the fuel system or add a fifth injector.
Old 02-24-2013, 12:02 PM   #4
i_c_the_light
Member#: 88618
1994 Legacy
"The Silver Slug"
Those guys don't like lots of boost, or heat. Do whatever but be wary the heads on those will more than likely crack when subjected to excessive heat.
i_c_the_light is offline   Reply With Quote
