Old 02-24-2013, 09:30 PM   #1
bridgestone24
Member#: 268817
2009 Stg 2+ HB WRX
Default Home brew SS 3" midpipe
Hey all,
I figured I'd share my weekend work. I previous installed a catted 3" down pipe and the car came with an SPT cat back, but the SPT midpipe was 2.5". I know it won't make much (if any) difference but I thought it would be fun to weld up an SS 3" pipe. The welds aren't pretty as I did all the work on a 40+ year old stick welder running 1/16" and 3/32" E6013 rod. Didn't feel like spending he money on SS rod.
bridgestone24 is offline   Reply With Quote
Old 02-25-2013, 10:35 AM   #2
DeleriousZ
Member#: 323869
2000 ST-outback
White/Grey
Cool man, but why did you go with SS piping if you weren't going to weld it with stainless rod?
DeleriousZ is offline   Reply With Quote
Old 02-25-2013, 11:40 AM   #3
PARANOID56
Member#: 22035
2003 Brocoma DCab
71 FJ40, 13 DRZ400SM
so the welds would rust but not the rest of the exhaust. duh
OP, you should paint at least the welds to keep from rusting. and god damn for using a stick welder. that takes some skill to not burn though that thin tubing.
also, whats the wood saw blade for? home made cold saw?
PARANOID56 is online now   Reply With Quote
Old 02-26-2013, 07:05 AM   #4
bridgestone24
Member#: 268817
2009 Stg 2+ HB WRX
Thanks! haha and yes, I'm going to seal the welds, it's just on the car as a shake down of sorts. Given that I did stick weld it, I'm waiting for any unnoticed pin holes to show themselves then I'll spot weld those locations and seal it up. I did light test the welds first, but I'm sure i missed some. Typically the welds don't rust that much even when using mild steel rod though.
The blade you see in the picture is a 60 tooth metal chop saw blade. I ran a speed controller on the chop saw to bring the rpms down to the correct speed for metal so I wouldn't burn up the blade (so yes, home brew cold saw). I'm fairly new to exhaust fab work but I'm looking forward to picking up a mig or tig soon . I have several other projects in mind for down the road.
Old 02-26-2013, 11:22 AM   #5
PARANOID56
Member#: 22035
2003 Brocoma DCab
interesting, i have thought about that before with a chop saw. are you using a router speed controller? got any pics of that setup? how does it work for you? where did you pick up the blade?
Old 02-26-2013, 06:31 PM   #6
bridgestone24
Member#: 268817
2009 Stg 2+ HB WRX
Exactly - I picked up the speed controller from amazon along with the blade. If you decide to go with the speed controller setup I suggest picking up a laser tachometer to set the blade rpm.
Here's a list of parts, I didn't get the tachometer but wish I did.
Amazon.com: Irwin Industrial Tools 4935558 12-Inch 60-Tooth Metal Cutting Circular Saw Blade for Ferrous Steel: Home ImprovementAmazon.com: Irwin Industrial Tools 4935558 12-Inch 60-Tooth Metal Cutting Circular Saw Blade for Ferrous Steel: Home Improvement
Amazon.com: MLCS 9400 Standard Duty Router Speed Control: Home ImprovementAmazon.com: MLCS 9400 Standard Duty Router Speed Control: Home Improvement
Digital Photo Laser Tachometer Non Contact Tach: Amazon.com: Industrial & ScientificDigital Photo Laser Tachometer Non Contact Tach: Amazon.com: Industrial & Scientific
Old 02-26-2013, 06:58 PM   #7
PARANOID56
Member#: 22035
2003 Brocoma DCab
so how well does it work? how many cuts do you get from a blade?
Old 02-26-2013, 07:30 PM   #8
Subikid90
Member#: 239233
1998 LGT
In for the results on the home brewed cold cut saw!
Also if you have a DC stick welder you can pick up a tig torch with gas valve, bottle of argon, flowmeter and use that as a starch start setup.
Subikid90 is offline   Reply With Quote
Old 02-26-2013, 07:54 PM   #9
bridgestone24
Member#: 268817
2009 Stg 2+ HB WRX
The chop saw worked really well and made clean cuts. I wish I had the tachometer because I turned up the speed controller at one point and in two cuts burned up the blade. Luckily I had an older spare blade and finished with that.
I don't have pics of the setup. It's pretty straight forward with a standard wood chop saw fitted with a metal blade. The chop saw plugs into the speed controller and the speed controller goes to an outlet. Operating the saw is a little odd because the saw running free versus when under load draws different current. The saws ability to resist slowing when under load (making a cut) is reduced when the power supplied is reduced. I would recommend setting up a few practice cuts to get the speed dialed under load before starting on the project.
Old 02-26-2013, 07:58 PM   #10
bridgestone24
Member#: 268817
2009 Stg 2+ HB WRX
Very cool. I actually have a spare stick setup that could be converted. I'll need to read up on it more. Thanks for the tip!
Old 02-27-2013, 02:15 PM   #11
Subikid90
Member#: 239233
1998 LGT
http://m.youtube.com/#/watch?v=PPKst...%3DPPKstOZSZug
Here is a video explaining what you need
Old 02-28-2013, 08:10 AM   #12
bridgestone24
Member#: 268817
2009 Stg 2+ HB WRX
Neat, thanks for the vid! Watched a lot of this guys welding tutorials but I haven't seen this one.
