Welcome to the North American Subaru Impreza Owners Club Friday December 2, 2016
Old 02-25-2013, 01:36 PM   #1
03NJWReX
Member#: 298655
03 WRX
WR Blue
Default Burning Rubber Smell and Bubbling Noise Near Turbo
Title pretty much says it all. Recently I've been getting a burning oil/rubber smell through the cabin air vents. I decided to take a look under the hood when I got home to see if any tubes or wires were touching hot parts of the engine and noticed a bubbling/percolating type noise coming from near the turbo. I'm assuming the smell is a problem but is the noise normal? I've recently taken the car to the dealer to do a recall on the fuel lines and they told me my oil pump was leaking and needed to be resealed and that I needed to replace a valve cover gasket, would either of these cause the noise or smell? Thanks in advance.
03NJWReX is offline   Reply With Quote
Old 02-25-2013, 03:10 PM   #2
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
ya know....my bugeye smelled like burning rubber after a long drive for a long time and i never really did figure out why......i have to assume that it was one of the belts...it stopped at some point and
the bubbeling may mean that one of your coolant lines is leaking a lil and letting air into the system or ya may need to change the cap(s)
Old 02-25-2013, 05:19 PM   #3
zandander
Member#: 281895
2005 Impreza WRX
Maybe your a/c drain hose near the downpipe. Mine is less than an inch from it so you could look at that.
zandander is offline   Reply With Quote
Old 02-25-2013, 08:11 PM   #4
jaxscuby
Sammo Hung
Member#: 10613
2002 USDM WRX
+1 ac drain line behind down pipe
Old 02-25-2013, 08:45 PM   #5
Uncle Scotty
Member#: 16200
OK buy Nates beans
the ac drain wasnt my issue....
Old 02-25-2013, 11:47 PM   #6
brew02wrx
Member#: 259970
2002 wrx cobb stg2+
psm proper fitment
is it a burning oil smell or a burning rubber smell?? The difference should be noticeable, bubbling tells me your leaking coolant and if it's burning off you should smell it as well, it should be a very sweet type of smell
could you see down to your turbo?? it might be worth removing the heat shield and taking a look at your oil and coolant lines as well as the drain line by the downpipe while you're in there
brew02wrx is offline   Reply With Quote
Old 02-27-2013, 05:43 PM   #7
italy wrx
Member#: 36450
2003 WRX
My bugeye just started smelling like this also... I looked everywhere and can't find anything leaking. Smells like a plastic bag is stuck to the exhaust..
italy wrx is offline   Reply With Quote
Old 02-27-2013, 06:06 PM   #8
Mr.Chow
Member#: 256390
2004 Baja Turbo
Dark Blue
mine had the bubbling noise, but I fixed that with adding a new rad cap on the upper tank and burping the system.
Mr.Chow is offline   Reply With Quote
Old 02-27-2013, 07:56 PM   #9
jhanso22
Member#: 344582
2003 WRX
+1 Id look here
jhanso22 is offline   Reply With Quote
Old 02-27-2013, 10:07 PM   #10
danger1138
Member#: 279525
04 rex luger!
I get that oil burning smell usually when its raining. Ive started to think that its due to when i hit a puddle of water and it getting on my wrapped exhaust manifold or wrapped Downpipe.
danger1138 is offline   Reply With Quote
Old 02-27-2013, 11:32 PM   #11
Danthrax
Member#: 299368
2014 Impreza 2.0i
My lines near the turbo have the bubbling sound too, I also had the burning rubber smell but it was the AC hose. I recently had a new radiator put in with new top and bottom hoses and a new radiator cap and my thermostat hasn't jumped as if I had an air bubble.
Danthrax is offline   Reply With Quote
