Old 02-26-2013, 12:17 AM   #1
exk20z3kid
Member#: 307921
Default '12 WRX trouble starting
A few weeks ago my car would just not turn over. It wasn't a very cold morning, and I had nearly a full tank of gas. It eventually did start after a little while. I wanted to wait and see if it happened again before making a thread, and it has not happened since. It was a weird one time occurrence.
What do you all think? Bad gas?
exk20z3kid is offline   Reply With Quote
Old 02-26-2013, 12:19 AM   #2
Loyale93
Newbie Moderator
Member#: 91347
'13 XV Crosstrek,12
1050 Triumph Speed Triple
I think you have a 1 year old car that's still under warranty. You should call the dealer and get them to fix it for free.
Loyale93 is offline   Reply With Quote
Old 02-26-2013, 12:20 AM   #3
exk20z3kid
Member#: 307921
Lol. Should have seen that coming.
You must not have read my whole post. It didn't happen again, so I see no reason to take it to the dealer. If it were an actual problem I am sure it would have happened again after that one instance. If I take the car to the dealer for an issue that is not happening anymore what do you think they would say?? ... Exactly. Waste of my time and theirs.
I am just curious to see what you all think it could have been.
Old 02-26-2013, 12:52 AM   #4
ShinjiML
Member#: 257231
2011 STI
Did you by any chance get a new fuel filter?
ShinjiML is offline   Reply With Quote
Old 02-26-2013, 03:52 AM   #5
GrumpyPitbull
Member#: 313311
This happened once on my 2012 as well. I turned the key and it cranked, but did not fire up. Then I tried again and it fired after cranking a bit longer than normal. Like you, it only happened that one time.
I have no idea what the issue was, and didn't worry about it since it was a one time occurance.
GrumpyPitbull is offline   Reply With Quote
Old 02-26-2013, 07:32 AM   #6
Loyale93
Newbie Moderator
Member#: 91347
'13 XV Crosstrek,12
Correct. My apologies. 12:30 AM = Not my friend.
Old 02-26-2013, 08:58 AM   #7
Member#: 301037
2004 Forester XT
As we all know unless you can show and prove the problem to the dealer most of them will act as though you are crazy and send you on your way. Hopefully it was just a fluke
art@grimmspeed is offline   Reply With Quote
Old 02-26-2013, 09:59 AM   #8
nmlittlebigman
Member#: 321409
2003 Big Effing Van
7.3L powerstroke diesel
Did you by chance disconnect your battery for any reason the night before? If so it resets the ecu learning and unless you leave the ignition on for a few seconds before trying to crank it will take longer than usual.
nmlittlebigman is offline   Reply With Quote
Old 02-26-2013, 10:46 AM   #9
GMR54
Member#: 328913
2013 WRX 5 Door
This happened to me a few weeks ago on my 2013 wrx. Like the other posters had mentioned, it only happened once.
GMR54 is offline   Reply With Quote
Old 02-26-2013, 01:47 PM   #10
exk20z3kid
Member#: 307921
Thanks for the responses everyone.
I have not changed the fuel filter nor did I reset the battery.
Old 02-26-2013, 02:44 PM   #11
gfreed1
Member#: 272788
2011 WRX 1.5XTR
DGM 380AWHP 380TQ
I have had this problem before. It doesn't turn over right away sometimes. It cranks for about 3 seconds before it starts. I must say that this started happening after my last tune. It might be a fuel pressure issue or something like that but I'm not sure
Current Mods
TBE catless
AEM CAI
Perrin TMIC
ID 1000cc injectors
Deatchwerks fuel pump
GT Spec UEL Headers, up-pipe, dump tube
38mm waste gate
Perrin Inlet
Grimmspeed ECBS
Tuned at IAG 323whp 352wtq at 17-18 psi
gfreed1 is offline   Reply With Quote
Old 02-26-2013, 02:46 PM   #12
Gallo2011
Member#: 268310
2011 SSM STI saloon
Church!
I've owned my car for a little more than 2 two years. One time and one time only, it would not start after driving it home from work and turning it off to open my garage door. First try, nothing. Second try after sitting for 10 seconds or so, vroom.
Don't sweat it. It's a mechanical device and it will have its moments of wtf??!!
Gallo2011 is offline   Reply With Quote
Old 02-26-2013, 03:58 PM   #13
Napalm3nema
Member#: 263954
2014 EVO X / 05 WRX
Wicked White / Blue
My battery died way sooner than I expected, perhaps get your battery checked and see what the results are?
Napalm3nema is offline   Reply With Quote
Old 02-26-2013, 04:09 PM   #14
08_sti
Member#: 347911
Chapter/Region: HIIC
08 subaru wrx sti
aspen white
Resets idle parameters, dont freak out its normal if you did in fact reset your ecu
08_sti is offline   Reply With Quote
Old 02-26-2013, 07:13 PM   #15
lakerfan32
Member#: 318002
2012 WRX Sedan
Satin White Pearl
Very weird, this has happened to me before as well. But only once...Strange indeed...
lakerfan32 is offline   Reply With Quote
Old 08-28-2013, 03:09 AM   #16
backseatwindowsup
Member#: 321212
2012 WRX
Same issue here, this happened to once before a few months ago, didn't think anything of it it. But then it happened again this morning. Anybody have ideas? I'm gonna give the dealer a call tomorrow morning and see what they say.
backseatwindowsup is offline   Reply With Quote
Old 08-28-2013, 05:17 AM   #17
rquinn19
Member#: 341182
2011 WRX
SSM
Happened to me once as well about 6 months ago. I have a 2011. Hasn't happened since.
rquinn19 is offline   Reply With Quote
Old 08-28-2013, 07:01 AM   #18
jonnyteix07
Member#: 246071
2010 impreza 2.5i
white
I've bad my 2011 wrx for about two years now and just this past winter it happend three times for me. The only thing I could track all three times was that it would happen on a day where there was a significant decrease in temperature. It would not start for about 5-10min or so. Have contacted Subaru. They won't do anything unless they can replicate it (figures). No idea what it is.
Current mods:
Aem CAI
Cobb OTS stage 1
jonnyteix07 is offline   Reply With Quote
Old 08-28-2013, 08:41 AM   #19
Raidenking
Member#: 350606
2012 WRX
Next time you guys have this happen try leaving car with power on but no crank for 10-15 seconds then try to start her up. Fires up right away? Then maybe power is not coming on right away to fuel pump
Raidenking is offline   Reply With Quote
Old 08-28-2013, 08:45 AM   #20
Scomi21
Member#: 347348
2013 WRX
Good idea, will try this. Car doesn't turn over as quick as I remember. This problem only happened when I forgot to tighten down negative battery terminal though
Scomi21 is offline   Reply With Quote
Old 08-28-2013, 02:58 PM   #21
jt subie
Member#: 364962
2012 WRX
happened to me one day then a few days later it happened again. hasnt happened since. been close to a year since then.
jt subie is offline   Reply With Quote
Old 08-28-2013, 05:29 PM   #22
stephenscm
Member#: 322266
2012 WRX sedan
PBP
This has happened to me last fall in my 12 wrx, abd i live in NYC so it wasnt too cold. I tried to start the car and it wouldnt, i waited a minute and it struggled n didnt start, then a few more minutes passed and it turned on. Like many others this was a one time thing, so far.
stephenscm is offline   Reply With Quote
