Old 02-26-2013, 03:04 AM   #1
Mosting3
Member#: 296753
2005 V7 JDM STI swap
Default Ethanol + Water instead of Meth + water?
Dears,
Some questions:
1st : does Water mix with Ethanol? ( heard touloune doesn't mix with water!)
2nd: Does Ethanol have higher octane than Methanol?
3rd: if the pump is completely safe with Meth + water , can i replace meth with Ethanol ? is it worth it?
Thank you.
Mosting3 is offline   Reply With Quote
Old 02-26-2013, 07:05 PM   #2
Aquamist
NASIOC Manufacturer
Member#: 110029
2004 Citroen Picasso
1. yes it does.
2. about the same
3. Yes you can. It will be more expensive. Less latent capacity than methanol. You will also run richer if you don't trim fuel.
Conclusion:
Methanol cools better, less effect on afr, same octane. Cheaper than Ethanol..
Aquamist is offline   Reply With Quote
Old 02-26-2013, 11:37 PM   #3
Mosting3
Member#: 296753
Aquamist,
Very informative reply, thanks a lot, very helpful
Regards to you.
