Old 02-26-2013, 05:48 PM   #1
TurboRush
Member#: 131648
Default Cut out airbox = like cold air intake = p0171?
Hey Guys,
I picked up an 02 WRX for cheap a few weeks ago. Car needed a few things and had a check engine light (I pulled the code, P0171).
While in the process of looking for leaks and cleaning the MAF I pulled the air filter to find out the previous cut out the entire underside of air box, basically just leaving enough plastic to hold the filter and use the stock mounting points.
My question - I know CAI's can cause this code if not tuned for it, would the bottom side of the air box being cut out give the same trouble as an aftermarket CAI? I have a couple other suspicious connections/hoses to replace but wondering if I should start sourcing a used COMPLETE air box.
Thanks
TurboRush is offline   Reply With Quote
Old 02-26-2013, 07:38 PM   #2
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
ya need to find another airbox or one of the 'good' cai's
Old 02-26-2013, 07:46 PM   #3
TurboRush
Member#: 131648
Thhhattttsss what I figured... thanks
Old 02-26-2013, 08:53 PM   #4
wrx1392
Member#: 342331
2003 wrx
blue
i used to make C/F air silencer deletes .it has worked well in my 03 with a old Cob stage 2 ecu reflash.but with the whole bottom gone yeah i'd do what uncle said.
wrx1392 is offline   Reply With Quote
Old 02-27-2013, 12:35 AM   #5
FraudulentNeon
Member#: 29108
2002 Impreza WRX
Deleting the bottom side of the airbox and running the filter exposed will not cause that code.
FraudulentNeon is offline   Reply With Quote
Old 02-27-2013, 12:50 AM   #6
TwoFifty
Member#: 261764
2003 Impreza WRX
Considering the vehicle is throwing a lean code, meaning more air then fuel and his air box has been modified to that extent, replacing the air box with a stock one and re checking system is definitely the best place to start with diagnostics regardless of whether or not it could cause the car to throw that code.
TwoFifty is offline   Reply With Quote
Old 02-27-2013, 01:27 AM   #7
Uncle Scotty
Member#: 16200
OK buy Nates beans
d00000000000d......are you stoned????
yeah....yeah, doing that CAN and has caused a lean code many times
and for 3 or 4 reasons that I can think of just quick
Old 02-27-2013, 09:52 AM   #8
TurboRush
Member#: 131648
Either way, I dont like it hacked that way and used air box is about a dime a dozen.
Old 02-27-2013, 07:01 PM   #9
jhanso22
Member#: 344582
2003 WRX
Just grab a used air box
jhanso22 is offline   Reply With Quote
Old 02-27-2013, 07:57 PM   #10
WrxFtw02
Member#: 231192
2003 WRX
PROs Tuned 270/251
I have an airbox sitting in my attic. Let me you if you want it.
WrxFtw02 is offline   Reply With Quote
