Old 02-26-2013, 11:26 PM   #1
devlin0311
Member#: 304958
2006 the best one
black
Default Why am i boost creeping ?
I have an amr cxr500 turbo 10.5 cm hot side. MY intake is stock 2.5 inch with free flowing exhaust (3 inch). When i bought my turbo i purchased the 14.5 psi actuator. Sense i did not have a big enough intake to support my turbo It was only tuned to 16 psi. I understand boost creep for the most part but i dont understand why i am boost creeping bc I bought a big enough interanl wastegate to support it !
Elaborate please .
devlin0311 is offline   Reply With Quote
Old 02-28-2013, 08:23 AM   #2
jebjkey
Member#: 73884
Chapter/Region: HIIC
16 HyperBlue STi
16 Crystal White STI
Need datalogs with WDC.
Maybe you are just over boosting due to a tuning issue? That is an easy fix. From what you listed for your mods, boost creep does not seem as likely as a tuning issue causing an over boost situation.
Data logs will tell the story.
jebjkey is offline   Reply With Quote
Old 03-02-2013, 12:37 PM   #3
jaxscuby
Sammo Hung
Member#: 10613
2002 USDM WRX
the issue is your turbo is making more boost than what you desire and
the internal wastegate is to small to bleed of the excessive pressure.
Old 03-02-2013, 10:50 PM   #4
jebjkey
Member#: 73884
16 HyperBlue STi
Without datalogs showing WDC going down to zero while the ECU is trying to control boost, it is just as possible (more possible, really) that his tune needs to be fixed as opposed to having a boost creep problem. Until the OP can show us datalogs proving otherwise, it should be assumed that he has a tuning issue not boost creep.
If lowering WDC lowers boost, then it is not boost creep, it is a tuning issue.
Old 03-09-2013, 09:20 PM   #5
jaxscuby
Sammo Hung
Member#: 10613
2002 USDM WRX
ok, the wdc do control desired boost.
cxr-500 is a 47/9 lb wheel.
what boost control are you using?
Old 03-09-2013, 09:29 PM   #6
Psychoreo
Member#: 79643
2015 WRX STI
Terminal black pearl
Elaborate please .
Psychoreo is offline   Reply With Quote
Old 04-10-2013, 10:08 AM   #7
devlin0311
Member#: 304958
2006 the best one
black
Originally Posted by Psychoreo View Post
The best answer i have ever got haha
