Welcome to the North American Subaru Impreza Owners Club Monday May 4, 2015
Old 02-27-2013, 12:48 AM   #1
Freeman.
Member#: 312895
2007 WRX TR
Satin White Pearl
Default Weird startup issues.
Hey guys I have 2002 wrx with a 2.5 hybrid built motor. It is running on a opensource tune and is on a vf39 and e85. I also have a downpipe, exhaust, grimmspeed 3 port boost controller, cold air intake, tgv deletes, and 850cc injectors with a walbro 255.
My car has been acting funny since the day I bought it used with 71k miles, I just recently had the 2.5 put in it and still has the same problem. It idles really choppy and lopy when I put gas in it, I changed the evap purge solenoid and it has not fixed it. I think it honestly is a little worse, even went I start the car normally it will still chop and act funny. It's weird because if I tap the brakes when it is doing it the car will clear up and sound normal and then it when I take my foot off the brake pedal it will do it again. I have checked for vacuum leaks and I can't seem to find anything. I can also smell the fuel pretty bad when it starts the rough chopping noise. But other than the idle it runs good.
Any help would be appreciated, I've been trying to fix this problem for 3 years. Thanks guys!
Video :
Freeman. is online now   Reply With Quote
Old 02-27-2013, 08:58 AM   #2
danger1138
Member#: 279525
04 rex luger!
Could be u have a problem with the brake booster or the line running from it.
danger1138 is offline   Reply With Quote
Old 02-27-2013, 10:16 AM   #3
jaxscuby
Sammo Hung
Member#: 10613
2002 USDM WRX
i would check all line around intake manifold, vacuum lies, fuel lines for a loose clamp
the car was tuned for the current set up?
Old 02-27-2013, 11:17 AM   #4
Freeman.
Member#: 312895
2007 WRX TR
Satin White Pearl
Yes the car is tuned for its current setup.
Old 02-27-2013, 12:01 PM   #5
2gnt2wrx
Member#: 123625
2002 wrx
2015 wrx gbp
I have the same problem with my 02, vf34, ID750's and new plugs. It starts and sounds like crap for the first few seconds then evens out. I also have major issues filling the gas tank too. I wonder if these problems are related.
This issue never showed in my 04 wrx, 05 wrx or 06 sti, might be an 02 issue.
2gnt2wrx is online now   Reply With Quote
Old 02-27-2013, 05:09 PM   #6
Mr.Chow
Member#: 256390
2004 Baja Turbo
Dark Blue
running e85? Mine had a bad fuel pump and it fixed this issue. If you're running e85 in the winter months you'll have to expect rough starts. I went on a pump gas tune for the winter. You're not all the far from me, if you want a fresh open source tune from a pro on the cheap let me know.
Mr.Chow is offline   Reply With Quote
Old 02-27-2013, 11:45 PM   #7
Freeman.
Member#: 312895
2007 WRX TR
Satin White Pearl
I added a vid, hope it helps!
Old 02-28-2013, 10:34 AM   #8
2gnt2wrx
Member#: 123625
2002 wrx
2015 wrx gbp
No, mine is running a 93 octane tune using a cobb AP, and Pro Tuned by Cobb in Plano Texas.
It has always had little rough start for the first couple of seconds until it evens out.
Old 02-28-2013, 11:50 AM   #9
2gnt2wrx
Member#: 123625
2002 wrx
2015 wrx gbp
Does it only do it when the engine is warm? cold? or both?
Mine only does it cold.
Old 02-28-2013, 02:58 PM   #10
Freeman.
Member#: 312895
2007 WRX TR
Satin White Pearl
Mine is the opposite. Doesn't do it on a cold start but does it when it's warm and when I get gas.
