Welcome to the North American Subaru Impreza Owners Club Friday July 3, 2015
Old 02-27-2013, 01:54 PM   #1
stylin2.5rs
Member#: 45248
2005 WRX
Default DIY clock pod modification question
Hey guys, I was looking to replace my boring OEM 05 WRX green digital pod clock. I saw several DIY's on putting an aftermarket temperature/clock/voltage meter into the car like this: WRX clock mod
I'm looking to keep things simple and was wondering if there is a way to mod the temperature & clock pod From an 09 Subaru to function in the 02-07 models? Assuming you need to re-use the 02-07 housing for the clock body. Also assuming you need to re-wire as the pin #s are different. I just like the soft white display over the green display. Also that temp gauge could come in handy
stylin2.5rs is offline   Reply With Quote
Old 04-11-2013, 12:34 AM   #2
Whitey02Wrx
Member#: 121155
02 WRX wagon
Im interested in this as well.
Whitey02Wrx is offline   Reply With Quote
Old 09-05-2013, 09:48 PM   #3
tubatalen
Member#: 324422
2002 Impreza
Midnight Black Pearl
I may not be your professional but there is a gauge called the Scangauge 2 it plugs into your OBD2 port and I'm pretty sure you could make it fit nicely into the clock housing with a little cutting...
Amazon.com: ScanGauge II Ultra Compact 3-in-1 Automotive Computer with Customizable Real-Time Fuel Economy Digital Gauges: AutomotiveAmazon.com: ScanGauge II Ultra Compact 3-in-1 Automotive Computer with Customizable Real-Time Fuel Economy Digital Gauges: Automotive
tubatalen is offline   Reply With Quote
Old 09-05-2013, 09:53 PM   #4
Ernest
Member#: 45076
2004 Stg2 Wagon 4eat
Interested as well. Scan gauge too expensive. Need something cheaper.
Ernest is offline   Reply With Quote
Old 09-05-2013, 10:00 PM   #5
dangerousatom
Member#: 70710
2002 04STi Swaped RS
w/PPGS & 02 Wagon w/PPGs
The 09^ temp gauge works off a temp sensor like the STi uses in their gauge cluster. So its fed through the wiring harness and you wont get it to work. More then likely it will read all 000 or XXX ???
Go with the first time temp gauge you posted or this one. I have this in my car it fits the stock hole perfectly with minor trimming, Red or Blue back lit and battery run clock so its always on.
dangerousatom is online now   Reply With Quote
