Old 02-28-2013, 01:36 PM   #1
Slickz888
Member#: 319087
Default New black filters
So I go to my Subaru dealership to get an oil filter and the parts guys says they got the black one and it's the new style, now does anyone know of the bypass valve rating or anything about the filter other then it is not made my fram and that it is taller?
Slickz888 is offline   Reply With Quote
Old 02-28-2013, 01:45 PM   #2
kpluiten
Member#: 120273
06 WRBWRXWGN
Now with 100% more Spec-C
Any pictures?
I still have a box of over 30 of the old black filters that I got when I bought a closed dealership parts department. I figure that amount should last the life of my wagon.
Old 02-28-2013, 05:05 PM   #3
jesterduck
Member#: 132588
2005 WRX
Part # might help as well
jesterduck is offline   Reply With Quote
Old 02-28-2013, 07:11 PM   #4
424wrx
Member#: 171948
08 wrx stg3 vf52
14 legacy, 11 fozzy
there are a few newer black filters. i know of at least 15208aa130 and 160. both are for the newer fb25 forester engines.
424wrx is offline   Reply With Quote
Old 02-28-2013, 10:49 PM   #5
bjkeed21
Member#: 247029
2010 WRX Hatch (02C)
Proletariat
Black filter, japan made, nuff said lol but it is the correct bypass, search it on legacygt.com. Im on my ipad and im too lazy to pull it up. Then go to fredbeans and purchase 12 of them. I ran two of them in a row and got a good blackstone report on the second
bjkeed21 is offline   Reply With Quote
Old 02-28-2013, 11:33 PM   #6
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
uuuuummmmm....w0w d0000000d....like the dealer is gonna have a SUBARU branded part that is the wrong specs
yeah....w0w...jeeze...maybe...like they jus spray painted them black and sellin counterfit parts or...yeah....thas it
Old 03-01-2013, 02:44 AM   #7
PhotoREX
Member#: 180193
04 Forester XT
Lmfao!!
PhotoREX is offline   Reply With Quote
Old 03-01-2013, 09:58 AM   #8
Somerset Subaru
Member#: 186498
I believe the one that guys are using is the 15208AA160 and the corresponding Oil Pan crush ring. The vin will call for the 15208AA12A so it all depends which you want and who you get at the parts counter/forum PM.
-Adam
Somerset Subaru is offline   Reply With Quote
Old 03-02-2013, 02:46 AM   #9
Mario_pic
Member#: 346512
was wondering i got a wrx a few weeks back and noticed thay used a honda fram 3593a i swaped to a mobil 1 filter it was way smaller also used mobil one full sytnthetic did some drifting thiss week now motor has a rod knock i think the drifting caused the knock but u think the filter or oil caused the problem as well also should i use subaru filters and if so what filters should i use on my bug eye after i swap out the motor thiss week ? and oil
Mario_pic is offline   Reply With Quote
Old 03-02-2013, 03:24 AM   #10
aod12
Member#: 282701
2008 FXT
Look up Mobil1 5w30 in NASIOC and read what you find. If you have rod knock...save up for a new engine
aod12 is offline   Reply With Quote
Old 03-02-2013, 02:27 PM   #11
Jessekrs123
Member#: 236927
2015 BRZ, 93 Legacy,
1984 BRAT
This. Mobil 1 5w30 shears down to piss quickly enough to make your head, and bearings spin.
Stick with the Subaru filters from the dealer as they are one of the few filters with the correct bypass pressure, and many people on here use Rotella T6 5w40 with great results.
Read the oil FAQ here:
http://forums.nasioc.com/forums/showthread.php?t=499177
Jessekrs123 is offline   Reply With Quote
Old 03-02-2013, 07:04 PM   #12
802-303
Member#: 283194
Default 15208AA160 gone!
If you find said black filters (15208AA160) you better snag them up. Subaru has now superseded them to a 15208AA15A. (a blue honeywell filter) I've ran the black 15208AA160 on my wrx for the last 2 oil changes, they have the same pressure rating/anti-drain back.... I grabbed a box when I found out they went bye bye, set for the next 100,000+.
802-303 is offline   Reply With Quote
Old 03-03-2013, 11:13 AM   #13
Supraru
Member#: 23313
99' 2.5Rs
black
The only black filters that dealers stock are for H6's and the new top mounted FB oil filters. You still can't buy a wrx jdm black oil filter. If you use the filter above that is black you are using the wrong filter on your car.
Supraru is offline   Reply With Quote
Old 03-03-2013, 09:01 PM   #14
802-303
Member#: 283194
15208AA130 - black H6 filter (fatter)
15208AA160 - black FB filter (taller)
15208AA12A - blue (correct by vin)
It may be wrong by vin. But by psi spec. and anti-drain back valve the 15208AA160 and 15208AA12A are the same. Only differance, half inch taller. Not only do I run the black 15208AA160, but did more then enough research between the two. Cut one apart, (exact internal design of the discontinued Tokyo Roki filters form japanland.) i also read all the Subaru info I could get my hands on. (Easy since I work for a Subaru dealership!)
But please tell me why using the FB filter will blow up my car/house/puppy...
Old 03-03-2013, 09:07 PM   #15
Supraru
Member#: 23313
99' 2.5Rs
black
So what you just stated is that if you use a different filter besides what is listed by the vin which is the blue filter you would be using the wrong filter. Thanks for clearing that up for me.
But please tell me where I said using the FB filter will blow up your car/house/puppy/reading skills? I stated if you aren't running the "blue" filter you're running the wrong filter on your car. It doesn't matter what research you did or what you cut open or where you work. Subaru specifies you use that filter. If you use on from the fb it is the wrong filter. You attempted to make yourself sound smart when really it was the other way around.
Old 03-04-2013, 12:54 AM   #16
bjkeed21
Member#: 247029
Proletariat
It is technically the wrong filter, but so are other filters like purolators that have the wrong psi valve. Those are what i moved on from lol exact oem anything just doesnt cut it sometimes
Old 03-04-2013, 01:24 AM   #17
Uncle Scotty
Member#: 16200
OK buy Nates beans
but the p(l)14460 HAS the correct psi valve...but it only fits the 2.0's
the wix 57712 fits the 2.5's and has the proper bpv psi
Old 03-04-2013, 09:08 AM   #18
bjkeed21
Member#: 247029
Proletariat
My mistake, i shouldve said i used the 4612 a couple times before i knew better lol
Old 03-06-2013, 07:01 PM   #19
1x2
Member#: 73564
2003 WRX
black-no wing no badges
I'm not comfortable with my ability to parse this discussion.
What's the correct filter for a 2003 2.0 liter WRX?
Thank you.
1x2 is offline   Reply With Quote
Old 03-06-2013, 07:27 PM   #20
Supraru
Member#: 23313
99' 2.5Rs
black
Thank you.
You have been on here since 2004 and you don't know what oil filter to use? Kinda weird....anyway the correct filter is part #15208AA12A. That is what will be pulled up by the vin.
Old 03-06-2013, 07:31 PM   #21
25rsti
Member#: 166324
According to the dealership I deal with only blue filters are available for my 02-03 WRX. They have black filters but those are for the BRZ and Foresters ect
Old 03-06-2013, 07:46 PM   #22
Supraru
Member#: 23313
99' 2.5Rs
black
What they are are saying is supposedly the specs are the same as the blue filters just taller and not made by fram. People drool over the jdm black filter because they are supposedly made better. That is what the confusion is here. The major majority of subaru's only call for the blue filters here in the good old USA.
Old 03-06-2013, 08:33 PM   #23
25rsti
Member#: 166324
I'm not in a fit over it at all, just passing on what I was told, when I asked.
Old 03-06-2013, 08:45 PM   #24
Supraru
Member#: 23313
99' 2.5Rs
black
I'm letting you know what you were told is true. This is not new information. I was trying to catch you up to what is being talked about in this thread. Yes there is only one filter made for the wrx currently.
Old 03-06-2013, 09:41 PM   #25
ringe
Member#: 49998
2007 WRX CT Stg 2
I've used nothing but stock filters, and have had very low insolubles showing up in my UOAs. Clearly, they're working well.
ringe is offline   Reply With Quote
