Old 02-28-2013, 11:45 PM   #1
Mariolemite
Member#: 341616
2004 WRX
Default Constant clicking under shifter when driving
04 WRX
So a little while ago I got in my car, started it up & started driving & I noticed as soon as I started to move I heard a slow clicking sound from underneath my shifter. As I drove faster, the clicking got faster. As I came to a stop, it slowed down and stopped. Is there something stuck to my driveshaft or what? I have no idea what this could be. Someone please help!
Mariolemite is offline   Reply With Quote
Old 03-01-2013, 01:46 AM   #2
PhotoREX
Member#: 180193
2002 Impreza WRX Wag
World Rally Blue
Maybe you ran something over. Check your tranny fluid level on flat ground. 5 speed or auto? Also this could be your loose shifter bushings jut vibrating. My 02 wrx always did it in 3rd gear
PhotoREX is offline   Reply With Quote
Old 03-01-2013, 02:28 AM   #3
Uncle Scotty
Member#: 16200
OK Houston
we have an Uncle
clicking usually means bad things
if it isnt something simple like a rock or something stuck in a tire.....it may be a broken gear in the transmission....'clicking' is the tell
Old 03-01-2013, 10:02 AM   #4
Mariolemite
Member#: 341616
2004 WRX
It's a 5 speed. My transmission levels are where they should be. I don't think my gears are messed up cause it still runs strong. Like it literally sounds like when you would put a playing card on the spoke of your bicycle wheel.
Old 03-01-2013, 11:38 AM   #5
Mariolemite
Member#: 341616
2004 WRX
So I found out the problem. The idiot who owned the car before me had set up under glow & zipties were hitting the driveshaft. Lol. Thanks for the help though
Old 03-01-2013, 11:49 AM   #6
jdmforrealz
Member#: 345274
Probably not the answer you are going to want to hear but could be anything from a CV axle to an internal issue within the transmission. I would start out by checking for rocks in the tires as thats what happened to me and I could only hear it with my window down driving between buildings.
jdmforrealz is offline   Reply With Quote
Old 03-01-2013, 11:50 AM   #7
jdmforrealz
Member#: 345274
I didnt read your most recent post that you fixed the problem, glad to hear ! Cheers.
Message Board Statistics All times are GMT -4. The time now is 11:39 AM.
