Old 08-21-2013, 09:00 AM   #151
rjrutzky
Member#: 30367
2005 Legacy GT
NASA SE PTB Champ
Originally Posted by Homemade WRX View Post
I think you don't understand that helical and spur (straight cut) and tooth profile and synrco and dog are gear engagement types.
Dog has no synrcos.
As for time attack, we want dig engagement for faster shifts and also no waiting on syncros to catch up at high RPM That's part of why dog engagement is points off of your power/weight in ST/TT classing.
I completely understand spur/helical/dog/syncro. F4m posted this:
EMCO Hybrid Dog gear set including the input shaft 1-2 Spur gear (Straight cut) 3-5 Helical $6,750
If you do the dog box you have to do the forks Which are a little more than PPG but you can see you're already saving $2,079.80
I assumed the hybrid part was dog 1-2 because you can't do helical dog engagement that I'm aware. I didn't see any option for a full syncro box
rjrutzky is offline   Reply With Quote
Old 08-21-2013, 09:50 AM   #152
vicious_fishes
Member#: 158864
2003 SOHC destroker
i always thought helical dog was very easily possible, it's just that nobody bothers because by the time you go dogbox practicality/DD friendliness/etc has been thrown out the window?
vicious_fishes is offline   Reply With Quote
Old 08-21-2013, 10:20 AM   #153
Homemade WRX
Member#: 33782
96 bastard child
search FIRST, then PM!!!
Ok, so to re-emphasize, and there is nothing abnormal about what he's saying.
He's say dog engagement with a straight cut 1-2 and helical 3-5 (which actually reminds me of my old PAR dog).
Seriously, did I miss a post somewhere? Trying to proof some of what's posted. He had mentioned separately that there would be a syncro engagement box available too.
As for Phil's post, talking about the transfer gears to change the ratios; the wording is a little misleading. I can elaborate more on drop gear options for front to rear but that gives a front diff torque bias.
We are still talking and waiting on ratios. I gave the uber mother load list of ratios several months back, including track oriented ratios that I would like to see but we haven't heard anything back from EMCO, as ratios are obviously strongly limited by tooth design.
-Micah McMahan
3MI Racing
Old 08-21-2013, 10:36 AM   #154
Innovative Tuning
Member#: 67958
MY96 Time Attack
and 06 STI daily
I'm glad you're targeting 3.9 final drive as I agree that makes the most sense.
Innovative Tuning is offline   Reply With Quote
Old 08-21-2013, 10:52 AM   #155
rjrutzky
Member#: 30367
2005 Legacy GT
NASA SE PTB Champ
-Micah McMahan
3MI Racing
That makes sense if what you are saying is what they are proposing. So there will be a 1-2 spur/synchro, 3/4/5 helical syncro set, but 2k more than ppg? Maybe I need to think about taking the power cut and going dog
Old 08-21-2013, 11:53 AM   #156
mpj_becks
Member#: 6265
It might be my reading skills at this hour but what is the cost of the complete dog box (Straight cut)?
mpj_becks is offline   Reply With Quote
Old 08-21-2013, 11:57 AM   #157
rjrutzky
Member#: 30367
2005 Legacy GT
NASA SE PTB Champ
Best I can tell is a "little bit more" than 6750
Old 08-21-2013, 11:59 AM   #158
Aceyduce
Member#: 194449
2011 Mazda, 2003 WRX
Black , WRB
6750 + forks + diffs, so 'a little bit more' is my guess too
Aceyduce is online now   Reply With Quote
Old 08-21-2013, 12:00 PM   #159
mpj_becks
Member#: 6265
Ah ok so I didn't miss it then, thanks!
Old 08-21-2013, 12:52 PM   #160
Flat 4 Motorsport
Member#: 295846
WRX FP HTA GT3076R
Sexual Chocolate
I'm not offering a complete spur gear dog box.
you have the choice of:
1-2 spur cut dog engagement with 3-5 helical dog engagement
or
1-2 spur gear syncromesh 3-5 syncromesh
you can do a syncromesh spur, its just going to take away from the spur gear itself because the syncro's are electron beam welded and the case is only so big so you need to allow room for the rest of the gears.
as for the drop gear comment. Micah understands this stuff a lot better than I do.
I'm learning about a lot of this as I go as well. So if something doesn't make sense I do apologize, Anthony had just told me that we would be able to adjust the final by swapping out the drop gear (transfer gear and shaft) so that ring and pinions wouldn't have to be swapped but I may have misunderstood.
-Phil
Flat 4 Motorsport is offline   Reply With Quote
Old 08-21-2013, 01:07 PM   #161
Homemade WRX
Member#: 33782
96 bastard child
Warfield, I'll hit you up later and fill you in.
Old 08-21-2013, 01:09 PM   #162
FlatironsTuning.com
NASIOC Storefront Vendor
Member#: 171650
The Transfer gears/drop gears are in the tail section and are what controls the ratio going to the rear differential.
From 2002 - 2005, WRX's have a 1.1:1 transfer gear, and that is why their rear ring and pinion is 3.545 (makes it a 3.9 final with the transfer ratio). From 2008 on, the transfer ratio is now 1:1 and the rear R&P is a simple 3.9 ratio.
So depending on what rear diff you are running, and the ratio of the R&P in that diff, you would need one drop gear ratio or another.
For cars making a lot more power, you would want to change there out as well, as they would be the weak point if you retained the stock gears.
FlatironsTuning.com is offline   Reply With Quote
Old 08-21-2013, 01:26 PM   #163
mpj_becks
Member#: 6265
Roger that!
Old 08-21-2013, 01:29 PM   #164
Homemade WRX
Member#: 33782
96 bastard child
Correct. There is one other 1.1:1 r&p option that you can run, which Dom of Maxwell Power told me last week...well it's close enough
Old 08-22-2013, 01:36 PM   #165
rallynutdon
Member#: 24568
1993 Impreza, WRX
drive train, Open class
I think they wanted to use up the SVX rear diffs that they over produced for what they sold.
rallynutdon is offline   Reply With Quote
Old 08-22-2013, 04:17 PM   #166
Matt Monson
Member#: 832
99 2.5RS, '85 911
'73 914 and 2012 BRZ
Post 368:
http://forums.nasioc.com/forums/show...ht=914&page=15
We've been doing helical dog gear conversions for more than a decade. They just aren't as strong as straight cut. But clearly they can take a beating:
So to answer the earlier question, no, there is no reason you cannot make a helical geared dog box.
Old 08-31-2013, 01:57 PM   #167
wolfmanRX
Member#: 317171
Sounds pricey...why not just upgrade to sti transmission with the extra gear
wolfmanRX is offline   Reply With Quote
Old 08-31-2013, 02:26 PM   #168
Homemade WRX
Member#: 33782
96 bastard child
You must not have read the thread, so Cliff notes:
Largest gains come from
1.) 80 lbs weight savings in transmissions (not counting R180 swap weight if needed).
2.) Faster shifts from the dog engagement.
3.) With dog engagement you can take advantage of using a strain gauge on the shift run to run an interrupt for up shifts.
Don't even use the clutch, just move the shifter. Downshifts, well trying to incorporate a blip would be really tricky.
4.) not so sure I think of this is a perk but just a difference; you don't have to do a 6-spd conversion. You just swap out your 5-spd.
Old 08-31-2013, 02:42 PM   #169
Flat 4 Motorsport
Member#: 295846
WRX FP HTA GT3076R
Sexual Chocolate
If you do a six speed swap proper, I guarantee unless that is a stolen six speed it will cost you more money in the long run.
Swap hubs, correct drive shaft, dccd controller, there's a lot more than just a transmission.
Just an FYI
-Phil
Old 08-31-2013, 02:58 PM   #170
Flat 4 Motorsport
Member#: 295846
WRX FP HTA GT3076R
Sexual Chocolate
Originally Posted by Matt Monson View Post
Post 368:
Video Link: http://www.youtube.com/watch?v=yz3wQMgwKr0
( I know you know this Matt) but It seams that a majority of the potential customers need some education.
And the reason is because you can have a nice and wide gear that has the surface area to accept all the torque and loading.
Which is why I'm having EMCO develop a 1-2 spur with a wide gear profile, dog engagement. And then switch to helical dog engagement for 3-5 the ket to this whole deal is *Materials used* heat treatments and gear surface prep.
I wish I could send every one a sample of an EMCO gear. I have pics but those don't do the gears justice.
To be able to feel the highly mirrored polish, beveled cut tooth profile. There are NO sharp edges what so ever period on any of the gears.
But its the quality of materials used along with heat treating, carbonizing blah blah blah.
I say blah blah blah because I don't know all their proprietary secrets nor will I ever.
Anyone who follows road racing knows that EMCO and Xtrac are the some of the best and biggest names in the business!
-Phil
Old 09-01-2013, 02:15 PM   #171
logic246
Member#: 225907
I have yet to see a 5 speed split casing box stand up to beatings.
logic246 is offline   Reply With Quote
Old 09-01-2013, 03:21 PM   #172
scby rex
Member#: 104878
02 wrxbastardchild
aw, MPS 2.34 breaking in
600whp isnt a beating?
scby rex is offline   Reply With Quote
Old 09-01-2013, 03:28 PM   #173
Boeleni
Top Scoob 003
Member#: 1812
1999 Impreza Try-R
Satin Black
So what does one need to swap out to go from 6 speed to 5?
Boeleni is offline   Reply With Quote
Old 09-01-2013, 08:12 PM   #174
scby rex
Member#: 104878
02 wrxbastardchild
Depends on what year rear diff you have. But if your going to build a 5mt you can build it with or without stub shafts and the ratio that suits your rear diff.
The cheapest would be the trans and linkage, a clutch and flywheel, a driveshaft and that's all I can think of.
The dss will make you a 5mt shaft with a r180 yoke if that's what you want or you can change the companion flange on the rearend.
Old 09-01-2013, 10:17 PM   #175
lordsanointed
Member#: 301522
2011 WRX
Phil, any special price for the first 20 buyers? The group buy:
http://forums.nasioc.com/forums/show....php?t=2258560
Or are U$ 6750 the final price?
lordsanointed is offline   Reply With Quote
