Old 03-02-2013, 01:15 PM   #26
AVANTI R5
Member#: 73805
2016 Cayman GT4
black
Default Mercedes-Benz G63 AMG 6x6 first drive review
What is it?
The largest and most extreme road legal SUV to ever hail from Mercedes' road car operations – the lunatic six-wheel Mercedes G63 AMG 6x6.
Set to be produced on a limited basis by Mercedes-Benz's Austrian partner Magna Steyr from the third-quarter of 2013, the colossal double-cab pickup started life as an even more rugged military version of the G320 CDI conceived and engineered for the Australian army and in operation since 2011.
This plush, leather-lined civilian version of the off-road vehicle has been conceived to appeal to some of Mercedes-Benz's most affluent clientele. It features six driven wheels, low range gearing, five differential locks and a tyre control system for its standard 37-inch wheels. Mercedes says it is "the last word in forward-thrusting power for the beaten track".
Pricing hasn't been announced, but the head of Mercedes-Benz G-class development, Axel Harries, suggests the G63 AMG 6x6 will be Mercedes-Benz’s second most expensive model behind the new SLS Electric Drive when official sales get underway in October around the 350,000 mark.
Unlike the military version of the G320 CDI 6x6, which is fitted with Mercedes-Benz's 3.0-litre V6 diesel and is offered in outputs of up to 220bhp, the G63 AMG 6x6 gets a twin-turbocharged 5.5-litre V8 from AMG with 536bhp. Torque is a 560lb ft – crucial in providing the shove required to haul the big four-seater’s considerable 3775kg kerb weight.
Mercedes' 7G-tronic seven-speed automatic transmission is fitted in place of the old NAG1 five-speed auto 'box found on the army version. Its transfer case can alter between a 0.87:1 high-range ratio for on-road driving and 2.16:1 low-range ratio for off-road conditions to all six wheels in a nominal 30:40:30 split. Power for the rearmost axle is supplied by an extra shaft. There are five electronic differential locks offering 100 per cent lock up of all six wheels, operated by three switches on the dashboard.
Relaying the engine's strong reserves to the ground are massive 37-inch wheels featuring a bead-plate design. They are shod with 12.5in-wide wheels.
At 5875mm in length, 2110mm in width and 2210mm in height, the G63 AMG 6x6 is 1106mm longer, 225mm wider and 272mm higher than the G63 AMG. Along with a 300mm increase in the wheelbase through to the middle axle at 3120mm, the front and middle axles have increased in width by 281mm each at 1790mm, requiring widened and lengthened carbonfibre guards to cover the huge wheels.
Ground clearance is a whopping 460mm while fording depth is put at 1000mm – some 250mm and 400mm more than the standard car. Approach and departure angles have been increased by 16 degrees and 27 degrees at 52 degrees and 54 degrees respectively, while the breakover angle has increased by 1 degree at 22 degrees.
What is it like?
A blast, at least in the wide-open space of a Dubai desert where the G63 AMG 6x6 has sufficient room to strut its stuff. I'm not sure how it would fare during the morning rush hour, but there’s no doubt you'd be noticed. And really, that's what this new Mercedes-Benz is all about.
That said, the example we drove was terrifically engineered – as complete from a technical standpoint as you'd expect any model from the German car maker whose first 6x6 customer deliveries are planned to get underway in just six months' time.
Before we got behind the wheel, we were taken for a wild ride over the dunes by a Mercedes test driver, who performed a round of donuts to prove how well engineered the G63 AMG 6x6 really is. The fact that it was originally conceived for military use helps, of course. The big surprise is just how refined it is.
Once you’ve heaved yourself on to the substantial step plate and introduced your backside to the leather-lined comfort of the G63 AMG 6x6's heavily contoured sport seat, you discover a cabin changed little from the standard G63 AMG up front.
The upright driving position is old school, as is the steeply angled windscreen and shallow dashboard. But forward vision is brilliant and indicators mounted on the front fenders act as positioning points. Rear vision is hampered by the tall rear seatbacks and a small two-piece sliding rear window.
At 3120mm, there's a 300mm increase in wheelbase to the first of the rear axles. It provides a longer cabin than the standard G63 AMG – and with it additional rear legroom. There's a liberal covering of Alcantara throughout and the standard three-across rear bench seat is replaced by two individual AMG sport seats. They get electronic backrest adjustment and are divided by a rear centre console.
There's an engaging blare through the four sidepipes as you hit the starter button to fire the engine, lending the big Mercedes an eager demeanour. Blip the throttle and it squats on its springs under load change like a true muscle car.
Once underway, the G63 AMG 6x6 proves remarkably easy to drive. It may have been conceived for the rough-and-tumble of army duties in the Australian outback, but the work put in to converting it for civilian use has produced a straightforward nature together with level of comfort you'd hardly credit from such an extreme-looking machine.
In the dunes of the Dubai desert, the G63 AMG 6x6 feels invincible. Those big tyres work with the complex driveline to provide plenty of traction, allowing you to wind it up to regular motorway speeds on narrow sandy tracks without any great trepidation.
It cruises with great authority, providing longitudinal stability – far better than the regular G63 AMG owing to the longer wheelbase and added traction provided by the third axle. There's far less vertical movement through the suspension than the standard car, resulting in a surprisingly smooth ride. There's plenty of lean in corners, but body movements are controlled thanks to a unique spring and damper package developed specifically for the G63 AMG 6x6.
Despite its weight, it accelerates with great vigour. Heady torque combines with the traction-enhancing qualities brought by the six-wheel-drive system to deliver impressive off-the-line and in-gear qualities. Mercedes won't quote official acceleration claims just yet, but insiders suggest 0-62mph in less than six seconds. Top speed, limited by its balloon-like tyres, will likely be electronically governed to 100mph.
And consumption? Again, Mercedes is yet to publish official figures, but we're told to expect around 15mpg on the European test cycle. It's just as well that the G63 AMG 6x6 will come with two fuel tanks with an overall capacity of 159 litres.
The prototype's vague, hydraulically-operated steering, which is geared at a lazy 3.4 turns lock-to-lock, indicates the need for some fine-tuning to better suit the big tyres. But any doubts about dynamic ability on the back of its rugged good looks were quickly dispelled.
Even when confronted with steep dunes and daunting sink holes, the hulking SUV managed to take it all in its stride, powering on with determination and a baritone exhaust note. Excellent wheel articulation and myriad diff lock combinations keep all six wheels firmly planted on the ground for impressive progress. An onboard compressor with four 20-litre tanks fitted along the sides of the underbody allow you to adjust tyre pressures, taking just 20sec to increase from a stand-friendly 0.5bar up to the 1.8bar required for on-road use – much faster than a conventional system that typically takes around 10mins.
The only thing I've driven that comes remotely close to the feeling I got while at the wheel of the G63 AMG 6x6 is the Hummer H1. But while the former is incredibly nimble for something so vast and hugely powerful, the latter was stodgy and rather lethargic.
Should I buy one?
You could argue long and hard about the merits or otherwise of the G63 AMG 6x6 – surely the world's first road legal MUV (monster utility vehicle). However, one thing holds true: it is a fun thing to drive in the right conditions.
But with a price tag more than three times that of the G63 AMG, it is going to be a super-exclusive proposition for all but the mega-rich.
Right now, Mercedes is looking at an annual run of between 20 and 30 cars. But if the interest it stirred during our time with it in Dubai was any indication, that's not going to be enough. Not if the Dubai royal family gets its way...
Old 03-02-2013, 03:07 PM   #27
lark6
Member#: 2715
70 911T
Every time I look at this thing I can't stop thinking of this:
lark6 is offline   Reply With Quote
Old 03-02-2013, 03:42 PM   #28
skywaffles
Member#: 82470
I am more humble
than you can understand.
Deliciously absurd. I need dis.
skywaffles is offline   Reply With Quote
Old 03-02-2013, 10:40 PM   #29
UKscooby
Member#: 33287
RIP Nik
I will always miss you
This is the steer axle right? Then why do I only see one rear axle and wheel?
UKscooby is online now   Reply With Quote
Old 03-03-2013, 12:58 AM   #30
hi5.0
Member#: 340456
2013 Impreza
Needs vertical exhaust stacks coming out of the bed with optional hardwood stakes. G 63 AMG Red(neck) Edition.
Waiting for some "rap artist" to buy one and bling it out.
hi5.0 is offline   Reply With Quote
Old 03-03-2013, 02:42 AM   #31
Rodeoflipper1818
Member#: 193977
2007 2.5i Wagon
2004 Honda RC51
Damn, just imagine having these two sitting in the garage...
Rodeoflipper1818 is offline   Reply With Quote
Old 03-03-2013, 09:21 AM   #32
daveyboy
Member#: 35419
Originally Posted by torquemada View Post
which has a maximum payload capacity of 1,433 pounds.
Originally Posted by 92XJET View Post
It's not a semi tractor trailer, I don't see the point of 4 rear wheels
Originally Posted by Hondaslayer View Post
Because 6wd and the military versions are used as heavy load carriers (see also US deuce and a half)
1400lbs of payload is typical 1/2-ton pickup capacity.
So the the payload referenced is either a typo or this thing is just a toy.
daveyboy is offline   Reply With Quote
Old 03-03-2013, 12:33 PM   #33
nhat
Member#: 140163
03 STi
hellaflunctional
It's a Mercedes. I don't think people are going to be using it to haul heavy loads.
Old 03-03-2013, 12:57 PM   #34
torquemada
Member#: 128484
2006 EDM WRX STI
3 metric tons for military use
Old 03-03-2013, 01:30 PM   #35
shikataganai
Member#: 92634
'07 Land Cruiser
'12 RAV4 EV
Could be the 37" tires, portal axles, or fancy hardwoods, unicorn blood, and jewels lining the bed that result in less payload capacity for the sheik-playtoy version.
shikataganai is offline   Reply With Quote
Old 03-03-2013, 05:34 PM   #36
White out
Member#: 46277
** LP640
Viper GTS
This is so horrible, yet I love it.
White out is offline   Reply With Quote
Old 03-03-2013, 05:35 PM   #37
CryderSpeed
Member#: 88816
TO TWERK
I'll take this one. Leave that frou-frou bull**** for the raptards and durkas.
CryderSpeed is offline   Reply With Quote
Old 09-10-2013, 01:49 PM   #38
torquemada
Member#: 128484
2006 EDM WRX STI
Old 09-10-2013, 02:03 PM   #39
daveyboy
Member#: 35419
Lose the faux-beadlock wheel covers and replace them with spinners = perfect... .
Old 09-10-2013, 02:27 PM   #40
Dex
Member#: 163775
2014 Ford Fiester ST
Murica Red
As much as I want to hate it and go off on some rant regarding **** we don't need, I can't, my inner 10 year old won't let me. I need this truck for reasons.
Dex is offline   Reply With Quote
Old 09-10-2013, 02:28 PM   #41
lark6
Member#: 2715
70 911T
Old 12-28-2013, 02:26 PM   #42
torquemada
Member#: 128484
2006 EDM WRX STI
Old 12-28-2013, 05:41 PM   #43
4wdwrx
Member#: 72042
2002 V7 Impreza
"Blue Mammoth" Returns
Most people in the US only knows them to make luxury cars, they actually make many military vehicles, industrial machinery, and work vehicles
4wdwrx is offline   Reply With Quote
Old 12-28-2013, 06:17 PM   #44
torquemada
Member#: 128484
2006 EDM WRX STI
Old 12-28-2013, 06:41 PM   #45
torquemada
Member#: 128484
2006 EDM WRX STI
Up until now, the best chance you'd have to get to drive this monster 6x6 AMG would be to join the Australian army, which signed a contract with Daimler in 2008 to procure 2,100 of these unstoppable desert chasers. But now Mercedes has decided - rather brilliantly - to make a civilian version, ready to order by millionaires before the end of 2013.
From the original military blueprint, it keeps six driven wheels, an off-road low-range ratio in the transfer case, portal axles, five differential locks and a tyre-inflation control system that allows the pressure in the 37-inch tyres to be adjusted in record time, on the move.
But once you climb into the cabin, there's a much less utilitarian bent. Four heated and ventilated leather armchairs, a leather-finished dash with contrast stitching, carbon-fibre trim and Alcantara slathered on the roof headlining and pillars. Pure AMG opulence. And the weirdness doesn't end there. Once you've got over the sheer size of the 6x6, it's worth noting the gigantic carbon wheelarch extensions and a pickup load area featuring an exclusive bamboo lining. Normal, this thing is not.
Did we mention it was big? At 5.85m long and 2.3m tall, it's positively huge. And fast. With the G63's 540bhp, 5.5-litre bi-turbo V8, the G63 AMG 6x6 can hit 62mph in seven seconds. And it does so with no hesitation, the 561lb ft being split in 30/40/30 (front, mid and rear axles) with the help of the familiar 7spd dual-clutch 'box. It just stomps its power to the road. Or whatever surface you happen to be on.
Ok, so the strangest product AMG has ever engineered was likely never supposed to corner like a sports car, but its relative agility is mind-blowing, especially considering that, at 3.85 tonnes, it's a VW Golf heavier than the already mighty G63 AMG.
More than that, it just will not be stopped. By anything. It has axle articulation that would make a Land Rover wince, manages 460mm of ground clearance and has a diving - sorry, fording - depth of a solid metre, 40cm more than the bodystyle it has been derived from. You can take it as read that absolute traction is never an issue, and even if you do begin to slip, you just drop the tyre pressures - independently for each axle, I might add - via switches mounted on the overhead console.
It's the best big boy's toy ever invented. Not a cheap one, though, at something over €300,000. But be honest, can you think of a better way to get your off-road kicks?
THE NUMBERS
5461cc, V8, 6WD, 540bhp, 561lb ft, 13.4mpg, 0-62mph in 7.0secs, 100mph, 3850kg
http://www.topgear.com/uk/mercedes-b...est/6x6-driven
Old 12-28-2013, 07:10 PM   #46
Skunkers
Member#: 115480
I know, I'm late but:
Skunkers is offline   Reply With Quote
Old 12-28-2013, 09:12 PM   #47
GDB FAN
Member#: 105814
I cannot stand this ****ing hipster dork.
GDB FAN is offline   Reply With Quote
Old 12-29-2013, 12:36 AM   #48
Not-EWRX
Member#: 158043
2013 Wrx Hatch
Germany.... **** Yeah!!!!
Not-EWRX is offline   Reply With Quote
Old 01-03-2014, 07:17 PM   #49
pf777
Member#: 86567
2005 WRX Wagon
Can't wait to see one of these in Beverly Hills.
pf777 is offline   Reply With Quote
Old 01-03-2014, 07:24 PM   #50
DeeezNuuuts83
Member#: 34406
2006 Evolution IX
graphite gray
^ Or OC. I saw one of those Gurkhas or whatever they're called (the crazy SUV that The Rock drove in Fast Five) parked in valet at Fashion Island in Newport Beach a few weeks ago.
DeeezNuuuts83 is offline   Reply With Quote
