Old 03-02-2013, 12:07 AM   #1
ForShtNGiggles
Member#: 348465
Lightbulb New ACT SB5-HDSS Clutch Install
I have been a member here at NASIOC for about a week. I joined because I have just started my clutch shopping experience. My 2007 WRX is completely stock with about 77k on the odometer. I bought it brand new in 2007 and absolutely love it. Here recently I have noticed that my clutch has started slipping and have decided to start the shopping process for a new one.
My first post on here was a less then desirable one as I have found NASIOC is full of a bunch of trolling tools looking to attempt to show how big their dicks are. I asked a question and the only good answer I got was a link to the Clutch FAQ thread. I found it to be more then helpful. After some research I have decided to go with ACT because of the excellent reviews it has got. I drive my car daily and it is my only one so when I do the clutch I need it to be right the first time. I have decided to go with a full face sprung organic disk for its excellent stock characteristics. The part number is this so you know which one I am talking about: SB5-HDSS. I am going to pair it with an ACT Streetlite flywheel.
I am posting this thread to find out the following:
1. Does anyone have any experience with this set up? How does it fair and what can I expect out of it?
2. What are the advantages and disadvantages of this setup?
3. Is there anything else I need in order to do the replacement or anything you would suggest doing while I am performing the switch?
4. Any other HELPFUL information would be greatly appreciated. Please try to keep in mind I am new to the tuning world and this is the first 'Aftermarket" part that will going on my vehicle.
ForShtNGiggles is offline   Reply With Quote
Old 03-02-2013, 12:20 AM   #2
the suicidal eggroll
Member#: 51961
2005 STi
2012 WRX
The HDSS is MUCH stronger than you need unless you have a turbo swap you didn't tell us about. Personally I'd stick to the Exedy OEM replacement or stage 1. Clutches are one area where you buy what you need and that's it...bigger is not better. That said, at least you picked the lowest ACT has to offer.
1) I have an ACT XTSS and Prolite flywheel, so it's kinda similar, but more aggressive. Honestly I think you'll probably like it. It's harder to drive, it'll take some getting used to, and morons who you let drive your car (emissions testing people, car wash people, etc) will likely stall it multiple times trying to just pull it forward 5 feet. But, up and down shifting will be smoother due to less rotating mass, and initial engagement should still be smooth.
2) Advantages: smoother/faster up and down shifting
Disadvantages: less rotating inertia means worse launches and it'll be more difficult to accelerate from a stop
3) Not that I can think of. Make sure your rear main seal is in good condition, because if it's leaking at all now will be the time to swap it out.
4) There are two ways to do the swap. First is to disconnect the front axles and driveshaft and drop the tranny. Second is to pull the radiator, lift the engine, and shift it forward a half a foot. I recommend the latter.
Old 03-02-2013, 12:28 AM   #3
ForShtNGiggles
Member#: 348465
Default Good Advice
the suicide thanks for the info man! I don't have a turbo install right now. I wish. I am sure it will take some getting use too. I heard that it was a very street friendly clutch and the fact that it is organic means it will recover from heating up fairly well. Is any of this true? I am sure it will be different at first but my thinking is that it will hold any additional power no problem that I will make with starting bolt on modifications? Am I correct in assuming all of this more input is very appreciated and thanks for the info in advance.
Old 03-02-2013, 03:44 AM   #4
Counterfit
Member#: 124254
2006 06 SGM Slowbaru
"The Scoobinator"
You still forgot to mention how much torque your car is making. That's the most important number.
Counterfit is offline   Reply With Quote
Old 03-02-2013, 10:05 AM   #5
vision.dynamix
Member#: 139955
2015 Subaru STI
Stage e
Because the car makes a little over 390hp with torque to match
Wut..
Old 03-02-2013, 10:58 AM   #6
Aaron'z 2.5RS
Member#: 1026
'00 RS/WRX Stg5
'98 RS Stock
Do you not understand why you got raped in your other thread?
Some of us "Trolls" have been here for YEARS answering questions from people such as yourself..
Some obviously have more time and knowledge than others.. So some post more and know more..
The kick in the balls comes after reading and answering the possibly 40th post of the day (across mutiple forums and forum sections of course) and then finding out that EVERYTHING you first read and then subsequently took the time to post an opinion on... was wrong...BECAUSE pertinent info was left out...
Put yourself in some other peoples shoes, suck it up and move on..
But note, if you havent learned something from your hazing, it will undoubtedly happen again..
Welcome to NASIOC
Old 03-02-2013, 05:45 PM   #7
Tripintaz
Member#: 245218
2013 STI Limited
I have this setup and i even wrote a review about it. Which shows up when you search But here is the thread for you.
http://forums.nasioc.com/forums/show....php?t=2430796
Tripintaz is offline   Reply With Quote
Old 03-02-2013, 08:12 PM   #8
ForShtNGiggles
Member#: 348465
Welcome to NASIOC
Lesson learned. Hahaha no more complaining from me.
Old 03-02-2013, 08:13 PM   #9
ForShtNGiggles
Member#: 348465
It's stock.
Old 03-02-2013, 08:24 PM   #10
vision.dynamix
Member#: 139955
2015 Subaru STI
Stage e
It's stock.
Didnt you throw a temper tantrum in the other thread because people assumed your car is stock then you said it makes "390hp with torque to match"?
Old 03-02-2013, 08:31 PM   #11
ForShtNGiggles
Member#: 348465
Vision dynamic your right now get off my thread if your not answering my question. Your the main troll I'm talking about keep going till you get an answer huh? Yeah I did now I'm looking for the correct answer so go troll somebody else.
Old 03-02-2013, 08:33 PM   #12
ForShtNGiggles
Member#: 348465
Trip very nice I am pretty sure I'm going with the set up. Going to order next Friday.
Old 03-02-2013, 08:45 PM   #13
vision.dynamix
Member#: 139955
2015 Subaru STI
Stage e
390hp and "bone stock" are 2 vastly different things. There is absolutely no need for a HDSS if you are "bone stock".
Get your information straight before you try to ask a question. Garbage in = Garbage out.
Old 03-02-2013, 09:11 PM   #14
ForShtNGiggles
Member#: 348465
Vision I live in TN. Be my guest or just keep being a fan boy.
Old 03-02-2013, 09:13 PM   #15
ForShtNGiggles
Member#: 348465
By the way everyone I have spoke too says its a good street clutch dip****. So keep trolling troll.
Old 03-02-2013, 11:30 PM   #16
Counterfit
Member#: 124254
"The Scoobinator"
You know, that sounds familiar.
Because the car makes a little over 390hp with torque to match on the stock oem clutch.
Old 03-03-2013, 07:53 AM   #17
Aaron'z 2.5RS
Member#: 1026
'00 RS/WRX Stg5
'98 RS Stock
Good, that didn't take long and wasn't very hard... Some just NEVER get it..
After effects... people remember the other thread... let it DIE and it WILL die..
This is true... read above and let the guy slide...
Old 02-04-2014, 01:36 AM   #18
Back Road Runner
Member#: 60082
2004 Forester STI
If the car is stock, is there a reason why the clutch isn't staying stock?
I can see stepping to an Exedy Stage 1 clutch if you're bumping up boost and want better grab when launching. This is where my brother's at, and 21psi with the Stage 1 clutch is a good fit for slipping the clutch on a high rpm 1st gear launch.
OEM is Exedy. There are fan boys for both sides as well as haters for both sides on the Exedy vs ACT debate. Both are pretty competitive these days I'm sure. Torque specs are typically at slip, so plan choice based on that and based on your long term modding plans. I would compare both brands, look at specs, and probably just buy the well fitting one that costs less. I would also note that OEM costs a LOT less than these higher torque options, so if value is a concern stock may be the way to stay. It just comes down to your plans with your car.
