Old 03-02-2013, 04:52 PM   #1
CameronMac
Member#: 268843
2001 Impreza Ej22
Default Is this important? It just fell off.
The other day while playing in the snow, I started to hear a terrible rattle. Pulled over to inspect and found the heat shield that sits above my midpipe was hanging by my O2 sensor wire. I cut it off and am now wondering if it needs to be replaced. Am I now a rolling fire Hazzard or can I rest easy without it?
CameronMac is offline   Reply With Quote
Old 03-02-2013, 05:08 PM   #2
Charlie-III
Member#: 30669
1998 Legacy 2.5GT
Silver Sleeper Wagon
While it's cold out, I wouldn't worry too much. If it were me, I WOULD reinstall it though when the weather turns or if you have a garage to work in.
Old 03-02-2013, 09:15 PM   #3
GrundleJuice
Member#: 165749
1982 Sex Machine
Flesh
If that is a cat shield it protects the unibody and passenger compartment from heat and insulated the cat to improve its catalyzing performance. Both are only good things.
GrundleJuice is online now   Reply With Quote
Old 03-08-2013, 02:18 PM   #4
08 OutbackSport
Member#: 321935
2008 Outback Sport
Black Obsidian Pearl
All heat shields are a pain especially on subarus when the rattle all the time. Use some heat wrap if you're worried.
08 OutbackSport is offline   Reply With Quote
Old 03-09-2013, 10:14 AM   #5
Storm
Member#: 5218
96L Most Over-
Developed Beater
Ditch it and forget it.
Jay
Old 03-09-2013, 11:04 AM   #6
AliBenn
Member#: 487
1998 /2005 STunIcorn
Acadia Green RS-T
^^^^I agree.
AliBenn is offline   Reply With Quote
Old 03-12-2013, 01:26 PM   #7
KelConquer
Member#: 321498
1998 Legacy W. EJ25
I haven't run any shields on my exhaust for the past year and have had 0 problems.
KelConquer is offline   Reply With Quote
Old 03-12-2013, 03:47 PM   #8
NIN8185
Member#: 299546
2006 2.5i Impreza Wg
The only thing mechanics say is that if you don't have a heat shield on cat's then don't park in tall grass as the heat from the cat could cause a fire. Besides that you do not need them and they are very annoying when they get loose. Heat wrap will cause your exhaust to rust super-fast because it traps in all the salt and corrodes your car all year long instead of just the winter months
NIN8185 is offline   Reply With Quote
Old 03-14-2013, 04:57 PM   #9
motohippy
Member#: 225882
2000 OBS
'88 BMW K75S
I just cranked hose clamps around mine and they haven't rattled since...
But mine hadn't fallen off, either
motohippy is offline   Reply With Quote
Old 03-14-2013, 05:16 PM   #10
PjkFisher
Member#: 338227
1999 Impreza 2.5 rs
Heat shields are a non-issue. I ran slammed with them removed on my old car and never had an issue. I always had to park on the grass (sometimes dry) at my parent's house too. Unless you are in some seriously dry brush, you won't have a problem. And as stated earlier, if you are worried about heat in the cabin, just wrap the cat in heat wrap.
PjkFisher is offline   Reply With Quote
Old 03-14-2013, 09:25 PM   #11
Storm
Member#: 5218
96L Most Over-
Developed Beater
I always get a chuckle when people (supposedly intelligent) honestly warn about parking in tall grass with no heat shields. I laugh because the shields are ABOVE the cat......nothing between the cat and the grass straight from the factory.....
Jay
