Old 03-02-2013, 08:21 PM   #1
Subiekid724
Member#: 348838
2004 Impreza WRX
UGM
Default 96 EJ22 swap into impreza l or rs??
Please dont bash me. Im a junior in high school and am working on my senior project. I pulled out a ej22 from a 96 legacy wagon and was wondering if i can drop it into an impreza l or rs without any major problems(harness,ecu,etc.).
Subiekid724 is offline   Reply With Quote
Old 03-02-2013, 09:07 PM   #2
Subiekid724
Member#: 348838
2004 Impreza WRX
UGM
Any opinions?
Old 03-02-2013, 09:35 PM   #3
Loyale93
Newbie Moderator
Member#: 91347
'13 XV Crosstrek,12
1050 Triumph Speed Triple
Sounds like fun, but don't bump a thread under a few hours. Sometimes it takes people a while to respond. This isn't IM or Text.
Loyale93 is online now   Reply With Quote
Old 03-02-2013, 11:50 PM   #4
Imprezid
Member#: 320777
2005 STI
The ej22 should bolt right in to any 93-01 impreza with no problems. The wiring should all match up. If its the turbo ej22 then the wiring and other things may be different.
Imprezid is offline   Reply With Quote
Old 03-03-2013, 12:05 AM   #5
Hondaslayer
Interpretively Paraphrasing
Member#: 4562
1995 Legacy LSi
1998 Declasse Moonbeam
What?
No, just no.
The RS is going to have an EJ25 in it so a 22 will be a downgrade (and no, the wiring does not "just match up")
An Impreza will likely already have the EJ22 in it (some had an EJ18, but the 22 is almost as gutless)
Wiring wise you can make it work, however all the sensors have to match the ECM and the harness.
So you would use the harness, sensors and ECM already in the vehicle and swap the engine out. You may have to change the cam and crank gears so the sensors send the proper signals to the ECM.
All told, why? If you are going to do a swap either do a turbo (EJ20X, EJ25X or EJ22-t) or a 2.5 into an Impreza L. If you are on a budget you can do a "frankenstein build" (EJ25 block with EJ18/22 heads)
Old 03-04-2013, 10:52 PM   #6
Subiekid724
Member#: 348838
2004 Impreza WRX
UGM
What if i do like ej22 block and ej22t heads? What about wrx heads?
Old 03-04-2013, 11:13 PM   #7
Hondaslayer
Member#: 4562
1995 Legacy LSi
EJ22T heads are basically the same, except you have a (bolted on) port for the oil return (or is it the feed line?) for the turbo.
WRX heads will need a complete re-wire, might as well just swap a WRX engine at that point.
Old 03-04-2013, 11:15 PM   #8
bugeye-brawler
Member#: 182337
1997 Impreza Outback
Sport -- White
Do not bother with the 2.2 at all if you want to make a franken motor go with a 2.5 block and use 2.2 heads it gives you a higher compression rate. Plus then you have more upgrade options of the 2.5 block.
I am swapping a 2.5 into my 2.2 going with cams headers and an intake and that should be enough with the lighter impreza frame to make the kind of power I need. The 2.2 does not have as many options as the 2.5 does.
bugeye-brawler is offline   Reply With Quote
Old 03-04-2013, 11:41 PM   #9
cal_look_zero
Member#: 294461
2006 San Remo Wagon
Under construction
As far as the EJ22, they come in many different flavors:
1989-1995 (early) non interference, hydraulic lash adjusters in the heads, dual port heads , piston style timing tensioner, about 135 crank hp
1995 (late) non interference (I think), solid lash adjusters, dual port heads, piston style timing tensioner, 135 chp
1996-1998 (early) interference, solid lash adjusters, single port heads, piston style timing tensioner, 138 chp
1998 (late) to 2001: interference heads, solid lash adjusters, single port heads (?), hydraulic roller timing tensioner, 142chp.
That said, the idea of swapping one 2.2 into another is silly. If you know the 2.2 you have is good, swapping it into a 2.5 Outback that puked it's head gaskets is a good option. Also, building a frankenmotor (2.5 block/2.2 heads) is the route I went and am making near stock 2.0 WRX power; though I have a lot of time and money into my build. Sheer cool points would be swapping it into a VW of some kind; bonus points if it was air cooled.
cal_look_zero is offline   Reply With Quote
Old 03-04-2013, 11:48 PM   #10
Subiekid724
Member#: 348838
2004 Impreza WRX
UGM
Ej22t is closed deck i believe. And well i got the engine and tranny in running order for $50. So i got it. Didnt think it was a bad deal.
Old 03-05-2013, 07:14 AM   #11
Tweeder
Member#: 129922
2007 Titan
You could actually do a pretty cool build using the ej22t SB as the basis of your build. If you current car is running and doesn't need a new motor, I would look into the built motor section for 22T builds and start building that motor over the next couple years with what ever spare funds you come across.
Tweeder is online now   Reply With Quote
Old 03-08-2013, 08:44 PM   #12
killerz99
Member#: 349541
94 impreza
red
Angry
I just recently bought a 94 preza with an ej22 swap already done the guy must have done something wrong it lasted 9 months then it wemt into limp mode after it warms up cleaned the egr and that got it out then it felt like it was spittin so replaced plugs runs better but now you can hear it missing but only after warm up stil. No cels whatsoever. Any thoughts?
killerz99 is offline   Reply With Quote
