Old 03-03-2013, 03:18 PM   #1
couchfuzzy
Member#: 320301
1995 Legacy GT-B
Default Help choosing a EJ22t Hybrid to put in a '95 Legacy L
so, ive been searching here and nasioc for a couple hours looking for the best route to take here but being new to the turbo world im getting a bit lost due to a lot of conflicting info im reading...
Available:
-I've got a seized up DOHC ej22e i'm pulling out of my 95 Legacy
-I've also got a complete ej22t longblock out of a '94 SS
-and technically, a DOHC ej25d, although this is in my dd '98 fozzy so i can't afford too much downtime to swap parts (unless it's worth it)
i'v never had a turbo'd motor before although ive gained a bit of knowledge by reading around,
Goals:
-I really want to shoot for more torque and low end acceleration than anything high end, this will end up as a dd/lightly tracked car...
-Aiming for 250whp
-Want to stay obdII
Budget:
- i'd like to upgrade the minimum to get the car running to start as inexpensively as possible ..and then build on it from there to find out which direction i want to go from there..
-College student, i probably wont be dropping more than about $300 on a single part
Build plan rough draft:
-1st gen Turbo Xmember
-ej22t shortblock
-eg20g/k heads, matching IM (wiring harness, ecu?)
-440cc injectors
-wrx fuel pump
-td05 turbo
-delta camshaft grind (unsure of what grind yet)
Questions:
(1)will i need fuel rails?, side feed or top feed?
(2) can i run off stock internals to reach my whp goal? if not, what are good internals?
(3) i'm assuming i'm going to need the ecu matching the heads and IM, will i need the entire wiring harness from them too?
(4)^im hearing good about robtune, would a greddy emanage ultimate be a sufficient EM to use for that?
(5) what else do i need to know?
anything from that mess of info anyone would recommend?
couchfuzzy is offline   Reply With Quote
Old 03-03-2013, 05:04 PM   #2
eg33GC
Member#: 206851
56 Belair
Pro Street
just buy a $1000 g off ebay with a trans, find a wiring harness and ecu. easiest and cheapest way
eg33GC is offline   Reply With Quote
Old 03-03-2013, 05:20 PM   #3
couchfuzzy
Member#: 320301
1995 Legacy GT-B
i've been thinking about that, so the 22t block isnt all that great after all nowadays?
Old 03-03-2013, 05:30 PM   #4
eg33GC
Member#: 206851
56 Belair
Pro Street
nothing needed for what you want to use, but they are still good
Old 03-03-2013, 06:26 PM   #5
rob
n00b Moderator
Member#: 811
2000 RS-Ej20G
It tastes like burning
These two are incompatible;
- eg20g/k heads
- Want to stay obdII
rob is offline   Reply With Quote
Old 03-04-2013, 12:52 PM   #6
couchfuzzy
Member#: 320301
1995 Legacy GT-B
Yeah, I hadn't realized those were obd2, I was under them impression they were while i made up that list
Old 03-05-2013, 08:29 AM   #7
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
this is just a bad idea
IF you want more power and need to stay obd-2 a 02-05 ej205 swap is hands down the way to go
you may get what you want out of the custom hodge poge but it will never perform like you want it to
Old 03-05-2013, 02:30 PM   #8
rob
n00b Moderator
Member#: 811
2000 RS-Ej20G
I am curious why OBDII is your goal when;
1) you have a '95 (typically not tested as OBDII)
2) you live in E. WA (no emissions)?
Also note that the 2.0 heads you are looking at will drop your compression down to around 7.8:1. This is also not conducive to your goal of more low end torque. You can fix that with aftermarket pistons, but it wasn't on your build list.
If you want more info on how the Robtune works for the ej22t folks, do a search on legacy central. If you go the chip route, you won't need the emanage. Of course if you follow Jaxx's advice, you have open source for all your tuning needs. It doesn't sound like it fits your budget however.
Either way, I think it would serve you better to sell off what you have, save your money and look for a complete motor (either ej22t or ej20g) w/wiring and bits. You will save yourself some newbie headaches and have a car you can enjoy a lot sooner. Just my opinion.
-Rob
Old 03-05-2013, 05:17 PM   #9
couchfuzzy
Member#: 320301
1995 Legacy GT-B
well, i've got another couple years before i dont have to do emissions in e.wa but after reading into it, it looks like you guys are right as far as just going with the ej205
especially for my first step beyond n/a, and with my budget
