Welcome to the North American Subaru Impreza Owners Club Saturday April 19, 2014
Old 03-04-2013, 05:03 PM   #1
BOOSTED20PSI
Member#: 347701
02 WRX
SILVER AND BLACK
Default Random Misfire Car Shaking Bad.
Ok So I Have A 02 Wrx With Accessport Stage 2 Pretty Much Stock Besides Stage One Clutch And Tanabe Downpipe Back Exhaust. Im Getting A Random Misfire When Im In 5th At Full Boost The Cel Will Flast A Few Times Then Go Off Without Me Having To Clear It. You Cant Tell A Difference In The Power When The Code Is Thrown. I Have Changed Spark Plugs Fuel Filter And Checked Coil Packs All Are Good.any Ideas??? Also If I Let My Car Idle For 10 Min Or So I Get A Horrible Shake Through The Whole Car Like Its About To Rattle Apart. I Cut The Key Off Imidiatly When It Does This And Start It Back Up And The Shaking Is Gone. It Doesnt Throw Any Codes And Rpms Are Not Affected Kinda At A Loss Here Any Help Would Be Aprriciated. Thanks
BOOSTED20PSI is offline   Reply With Quote
Old 03-04-2013, 11:46 PM   #2
badmannersgod
Member#: 349096
Try cleaning out your MAF sensor, have you been able to at least read the code to know which cylinder its coming from?
badmannersgod is offline   Reply With Quote
Old 03-05-2013, 12:20 AM   #3
BOOSTED20PSI
Member#: 347701
02 WRX
SILVER AND BLACK
I cleaned the maf then noticed it wasn't all the way screwed down the collar the screw goes into stripped out of the air box hopefully the leaking air was the problem hasn't done it since the fix
Old 03-06-2013, 11:18 AM   #4
BOOSTED20PSI
Member#: 347701
02 WRX
SILVER AND BLACK
Still having a random mis fire any other ideas
Old 03-06-2013, 12:03 PM   #5
BOOSTED20PSI
Member#: 347701
02 WRX
SILVER AND BLACK
AND NO I HAVNT IT DOESNT STAY ON IT FLASHES A FEW TIMES,I THINK 4 TIMES, THEN DISSAPEARS.
Old 03-06-2013, 12:48 PM   #6
wrxlaunch
Member#: 181298
02 , Vf43 Inside..
12 seconds at a time
Flashing cel is real time misfire. What is max boost in 5th? And why not just downshift?
wrxlaunch is offline   Reply With Quote
Old 03-06-2013, 02:36 PM   #7
BOOSTED20PSI
Member#: 347701
02 WRX
SILVER AND BLACK
Max Psi Is 18 And I Do Downshift But I Have To Shift To 5th Eventually
Old 03-06-2013, 06:39 PM   #8
ezil71
Member#: 207118
2003 Wrx Wagon
How did you check the coil packs?
I had misfires on my 03 a while ago and couldn't find the cause. I ended up replacing all the coil packs and haven't had a problem since.
If you haven't run any seafoam in a while, that can help clean things out.
Could be one of the coil packs isn't fully seated? The one on the passenger side that has the bracket on it would be the first one I'd look at. Make sure the bracket is really seated properly, not just 'kinda' seated properly.
When did you last change the plugs?
ezil71 is offline   Reply With Quote
Old 03-06-2013, 06:48 PM   #9
kelsyf13
Member#: 339401
I was having random misfire on all cylinders for a long time, when cruising in 5th and sometimes at idle the cel would flash, swapped plugs, coil packs, maf, cam/ crank sensors. Ended up being #3 injector might be worth taking a look at them. It also shook quite badly at idle.
kelsyf13 is offline   Reply With Quote
Old 03-06-2013, 07:41 PM   #10
ogboot
Member#: 170906
psm
Sucks that you're misfiring. You should really be moving before you go into 5th on the 5 speed. Like hauling ass. 4th gear takes you over 110 at least. What rpm are you shifting into 5th, and at what rpm are you getting the cels?
ogboot is offline   Reply With Quote
Old 03-07-2013, 12:12 PM   #11
BOOSTED20PSI
Member#: 347701
02 WRX
SILVER AND BLACK
i bought all new coil packs changed them out and the spark plugs less than a month ago i checked and made sure they were seated right also i have ran seafoam through my vac lines, fuel tank, and oil then changed the oil bout 50 to 70 miles after adding it. the oil was acutally pretty clean. Im starting to lean toward a injector problem jsut doesnt make sense that it is on all cylinders at one time.
Old 03-07-2013, 12:19 PM   #12
BOOSTED20PSI
Member#: 347701
02 WRX
SILVER AND BLACK
and ogboot i will shift out of 4th anywhere from 5500 to 6500 and it flashes normally around 5 after full boost has been set for 3 to 4 seconds also it idles fine besides the normal shimmy of a subi unless i leave it idleing for a good period of time then it starts violently shaking like the flywheel is loose thats the best example of how it feels.but i took the starter off and didnt feel any play in the flywheel.
Old 03-07-2013, 05:32 PM   #13
kelsyf13
Member#: 339401
Mine was all cylinders too and I thought the same thing. I think it was the rough idle causing the engine to detect a misfire, worth checking fixed my problem.
Old 03-07-2013, 06:10 PM   #14
bushflyr
Member#: 89628
'02 Wagon VF39'd
& Quick Racked
Bizarre. I just started having a similar problem a couple days ago too.
1. Going around a 60mph onramp, WOT in third I felt a lurch and got off the gas. No CEL.
2. Shortly thereafter I did a WOT pull at about 55mph in third. The boost appeared to pause going through 14psi then continued to build. Felt the lurch again at 20psi and CEL began flashing for about 5 seconds then gone. NO STORED CODE.
3. I just reflashed my base map (protune) and tightened the intake hose clamps that I could reach. Went for a 2nd gear pull and got violent lurching going through 7psi or so. It feels like ALL CYLINDERS are missing at the same time. Flashing CEL for 5 secs or so Then gone.
I'm almost wondering if it could be clutch slip and grab causing the issue. When I started up cold today my clutch judder was twice as bad as it's ever been. Off to clean the MAF when it cools down.
bushflyr is offline   Reply With Quote
Old 03-07-2013, 06:19 PM   #15
Wills03rexwagon
Member#: 198008
2003 Impreza WRX wgn
if possible try switching your coils around and see if the miss fire follows, if it follows you know your having a spark issue, if it stays I would check the injector for that cylinder
Wills03rexwagon is offline   Reply With Quote
Old 03-07-2013, 07:51 PM   #16
greenplates
Member#: 239162
spark or fuel.
coil or injector.
try those first
greenplates is offline   Reply With Quote
Old 03-08-2013, 10:59 AM   #17
BOOSTED20PSI
Member#: 347701
02 WRX
SILVER AND BLACK
swapped coils around and made no difference
Old 03-08-2013, 12:38 PM   #18
animalcrackers
Member#: 271364
2002 and 2006 WRX
AW - OPB
Had the shaking and flashing cel problem. Turned out to be too big of injectors. Went down in size, rescaled mac, and boom fixed
animalcrackers is offline   Reply With Quote
Old 03-08-2013, 02:41 PM   #19
animalcrackers
Member#: 271364
2002 and 2006 WRX
AW - OPB
maf**
Old 03-08-2013, 03:32 PM   #20
BOOSTED20PSI
Member#: 347701
02 WRX
SILVER AND BLACK
Maf Is Freshly Cleaned Along With Every Sensor I Could Clean And Its Stock Injectors Is It Possible For It To Work Itself Out Of Tune???
Old 03-08-2013, 03:45 PM   #21
animalcrackers
Member#: 271364
2002 and 2006 WRX
AW - OPB
Are you on an accessport tune, open source or what?
Old 03-08-2013, 04:54 PM   #22
BOOSTED20PSI
Member#: 347701
02 WRX
SILVER AND BLACK
Yes Im On Accessport STAGE 2 It Was Tuned On A Mustang Dyno In Nc Before I Bought It
Old 03-09-2013, 01:30 AM   #23
kelsyf13
Member#: 339401
I still say injectors, start with the basics before blaming tune.
Old 03-09-2013, 06:12 PM   #24
Jeffman44
Member#: 239072
2005 WRX Wagon
white
Should be running colder plugs if you.aren't already. The std Heat range will get really hot at full 5th gear load on a long pull. Hott enough to cause pre igniton - misfire.
Jeffman44 is offline   Reply With Quote
Old 03-09-2013, 08:45 PM   #25
greenplates
Member#: 239162
Stage 2? Bring it to a tuner bro
