Welcome to the North American Subaru Impreza Owners Club Monday October 24, 2016
Old 03-10-2013, 10:50 PM   #1
Member#: 213930
2002 02wrx
Default rich fuel trim; been through the basics
2002 wrx and got the cel that wont go away. po171 or 2; rich fuel trim.
checked alot...So far
1) replaced o2 sensors, ran better, gauge reads normal, slight lag after letting go of pedal, however light came back on tonight for third time; same code
2-3) cleaned maf and air filter
4) no vacume leaks pre or post turbo
5) new plugs
6) battery is good
Also, gas light has been coming on when im not even low. when coming to a stop, idle drops hard.
Could it be a burnt cat? I have a catless set up, was tuned to be catless, but had to put one in to pass inspc; just visual. Just never swapped it back to my test pipe. Should I any way, people tell me it doesnt matter?
Any suggestions...
mjcnv1p is offline   Reply With Quote
Old 03-10-2013, 11:26 PM   #2
Member#: 327495
2012 Impreza WRX 5DR
Plasma Blue
Did you tune it with an AP?
Navendra94 is offline   Reply With Quote
Old 03-11-2013, 02:02 PM   #3
Eerc WRX
Member#: 215706
02 Impreza WRX
There is a pretty good write-up about that code here.
I usally get a loose vacume hose below the BOV.
Eerc WRX is offline   Reply With Quote
