Old 03-05-2013, 04:07 AM   #1
rex-wag
Member#: 281734
2005 WRX Wagon
World Rally Blue
Unhappy Car feels SUPER weak, NOT hitting full boost..... HELP PLEASEEEEE
Ok.... so this one has me pulling my hair out.... I have a 2005 wrx wagon, stock turbo, dyno tuned, intake, catless up/down pipe, and 3inch cat back invidia. Just recently I have not been able to hit max boost (16psi) when I am full throttle, i will only build to about 8-10psi all gears. When I go full throttle i almost feel like the car wants to go then just is too weak to go and it wont boost fully. Also I will reflash my tune with my cobb access port and then it will be fine. I will drive it a little, could be a matter of 1 min or an hour and then the car will randomly go back to only hitting about 10psi and feel weak again.... have never had this problem before and i am going crazy..... SOMEONE PLEASE HELP!!!!!!:furio us:
rex-wag is offline   Reply With Quote
Old 03-05-2013, 04:21 AM   #2
Artizle
Member#: 251825
2004 WRX
Bad tune maybe? What's your IAM? You should post a log it sounds like your ECU is finding something wrong like some knock especially since you said it's fine when you do a fresh reflash.
Artizle is offline   Reply With Quote
Old 03-05-2013, 04:41 AM   #3
rex-wag
Member#: 281734
2005 WRX Wagon
World Rally Blue
What does IAM stand for?? Don't really know all the shortened terms yet. Also I ha e 4 separate tunes for the car from the dyno tune. Does the same thing with them all. ALSO NO CHECK ENGINE LIGHTS.... forgot to put that in the first post, not yelling that at u haha
Old 03-05-2013, 04:58 AM   #4
Artizle
Member#: 251825
2004 WRX
Ignition Advance Multiplier. Use your Accessport to check it, I think it's called DAM instead of IAM in the accessport, it should be a number from 1-16. Don't check it right after a reflash check it when you start having the problems you described.
Honestly though you should just talk to the person who tuned your car.
Old 03-05-2013, 05:23 AM   #5
rex-wag
Member#: 281734
2005 WRX Wagon
World Rally Blue
Ok I'll have to wait because I just reflashed it last night and its still fine bit when it does mess up... If it does.... I'll have to check it out. I say if because I'm trying a tune I have not. Also I have had the car tuned for about a year or so now with no problems. This just popped up out of no where....
Old 03-05-2013, 05:40 AM   #6
StIGC11
Member#: 346106
2006 SGM BW88-75
E85
when you say reflash do you mean reset the ecu or reflash the whole map?
If you are reseting the ecu try reflashing the map.
If you are reflashing the map are you do a realtime flash or a acutal reflash where you plug the two green connectors in?
If your doing a realtime try doing a actual reflash.
StIGC11 is offline   Reply With Quote
Old 03-05-2013, 05:49 AM   #7
rex-wag
Member#: 281734
2005 WRX Wagon
World Rally Blue
Resetting the ecu did nothing I've tried that already, also I never reflash with just a realtime, I don't like using that cuz the tunes don't stay. I always do the actual reflash on the ecu where I plug in the green conectors.
Old 03-05-2013, 08:31 AM   #8
danger1138
Member#: 279525
04 rex luger!
Check for any leaks. Also would help if u tell us what your LTFT (long term fuel trims) are. Those are the ones on the cobb ap that say A/F Learning A, B,C,D. They should all be within +/- 7. Post what those numbers are.
You may have gotten some king of boost leAk after the tune. Also what the other guy suggested, check the adv DAM multi on the ap. when the car is 'happy' it should be at 16.. The farther you are away from this number chances are something is up.
danger1138 is offline   Reply With Quote
Old 03-05-2013, 11:00 PM   #9
bkruelle
Member#: 279027
2011 WRX
Check for leaks around the ic. The silicone tube from ic primarily. Do you notice any noises?
bkruelle is offline   Reply With Quote
Old 03-06-2013, 04:03 AM   #10
rex-wag
Member#: 281734
2005 WRX Wagon
World Rally Blue
Well ive checked the IC hoses, and rechecked boost/vac lines and nothing showed, i swapped out my MAS air flow sensor tonight and did a coolant flush(just cuz i needed to and wanted to) but seeing if the MAS air flow sensor does anything also waiting for car to act up to check out everything with the cobb, didnt drive really any today so didnt get a chance to check it... and depending on the situation with this snow thats coming ill try to check that out tom and post up the #'s.
Also thanks everyone for the help so far and to come!!!
Old 03-06-2013, 06:02 PM   #11
boosted25
Member#: 316107
2002 Wrx sportwagon
Rally blue
Might be a long shot but do you have a loose heat shield? My cobb shield rattles so bad sometimes my iam would drop like crazy because of all the false knock the ecu was picking up.
I was having the same problem and was chasing my tail and the rattle was pissing me off. Then I got annoyed and took it off and my iam stays at 16 now!
boosted25 is offline   Reply With Quote
Old 03-07-2013, 12:57 AM   #12
rex-wag
Member#: 281734
2005 WRX Wagon
World Rally Blue
The only heat shields i have are on my cross pipes
Old 03-09-2013, 12:39 PM   #13
rex-wag
Member#: 281734
2005 WRX Wagon
World Rally Blue
UPDATE: well i just checked my A/F ratio and at idle im at about 14 at full throttle im only getting to about 11 and i know my car used to go to about 7.... when i let off and not putting any load on the car im up around a 24.... also for the #'s for the A/F ratio learning A-D they are all down around 0,2,3,4 not around a +/-7...... so if someone could help out more so now with these #'s posted i would love to hear what you guys think...
Old 03-09-2013, 04:25 PM   #14
danger1138
Member#: 279525
04 rex luger!
AF; D should usually be at 0..
Old 03-12-2013, 11:02 AM   #15
kyle.hoyer
Member#: 327892
01/2 RS, WRX, STI
BRP, PSM, SWP
kyle.hoyer is offline   Reply With Quote
