Old 03-05-2013, 06:22 PM   #1
fr0st
Member#: 41618
2008 WRX Hatch
wrb
Default up pipe heat shield
mine is rusing off to the point of hanging on the pipe itself..
any issues if i remove it and don't wrap it ?
fr0st is offline   Reply With Quote
Old 03-05-2013, 06:32 PM   #2
danger1138
Member#: 279525
04 rex luger!
No issues at all. Its just a good idea to wrap it
danger1138 is offline   Reply With Quote
Old 03-05-2013, 08:15 PM   #3
fr0st
Member#: 41618
2008 WRX Hatch
wrb
any good wrap out there? i never did this before.
Old 03-05-2013, 08:19 PM   #4
Psychoreo
Member#: 79643
2015 WRX STI
Terminal black pearl
Just yank it off
Psychoreo is offline   Reply With Quote
Old 03-05-2013, 08:43 PM   #5
tuzzio
Member#: 292532
05 STI
Never wrap it.
Never pull out either.
tuzzio is offline   Reply With Quote
Old 03-06-2013, 01:39 AM   #6
BraveSTi
Member#: 262030
Originally Posted by tuzzio View Post
Never wrap it.
This x 2
BraveSTi is offline   Reply With Quote
Old 03-06-2013, 02:16 AM   #7
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
bad idea to not use a shield or not wrap it.....it gets to 1600*F and your power steering lines are pretty close as is that cam cover
one of the dumbest things i see is n0000bs not thinking about things like this
nobody thinks anymore
Old 03-06-2013, 02:25 AM   #8
Andrewxxcarlson
Member#: 316415
2006 WRX
Thank you!!!
Andrewxxcarlson is offline   Reply With Quote
Old 03-06-2013, 02:25 AM   #9
Andrewxxcarlson
Member#: 316415
2006 WRX
I'm always havin to tell people to put their damn heatshields back on... Sigh*
Old 03-06-2013, 05:27 AM   #10
fr0st
Member#: 41618
2008 WRX Hatch
wrb
had to buy both lowersides heat shield( the sandwiches type that bolt where the manifold bolts to the head)... the prvious owner had the bright idea to drive around without the plastic shield underneath.they rusted pretty good and fell..
the uppie shield is still there but loose and doesn't have much meal left to bolt on anything... it looks to be a pita to insall a new shield without removing the uppipe..
Old 03-06-2013, 06:52 AM   #11
jebjkey
Member#: 73884
Chapter/Region: HIIC
16 HyperBlue STi
16 Crystal White STI
The stock UP heat shield is welded on. The only way to get it off when the welds break is to cut/destroy the heat shield. You cannot buy a replacement heat shield without buying a new UP from the factory.
Nearly every aftermarket UP has no heat shield and only one or two can be purchased with a coating. I am pretty sure that a vast majority of the people running an aftermarket UP have no wrap/coating on it. Running the stock one without the crappy heatshield would be no different then an aftermarket UP.
Now, it is a very good idea to have some sort of heat shielding. For the UP, I believe that coating it is the best option due to the fire risk associated with wrapping. Either one is better than neither one.
When my heat shield broke, I cut it off and wrapped the UP with some remanent exhaust wrap I had left over from a long time ago. I was not concerned about the fire risk becuase I knew it was temporary since I was about to buy Tomei headers and send them to SwainTech. I just got those headers back from SwainTech, but I am currently on a business trip in Diego Garcia so I have not installed them yet.
jebjkey is offline   Reply With Quote
Old 03-06-2013, 07:58 AM   #12
Mr Wrex
Member#: 332887
2012 WRX stage 2+
DGM (sedan)
DEI Titanium wrap is the way to go if you're so tempted to get that heat sheild off. Don't risk melting **** above/around the uppipe. I was going to take mine off because mine also snapped and was becoming quite noisy when I floored it... I opted to get a new EWG setup to get rid of the rattling sound and make more noise
Mr Wrex is offline   Reply With Quote
Old 03-06-2013, 10:52 AM   #13
BraveSTi
Member#: 262030
Never wrap it.
This x 2
Yo son.. I hope you wussint referring to me, cause I wus concurring with the gentleman statement regarding my up-pipe goin' up women, not not an exhaust component. Get it? Got it? Good.
Old 03-06-2013, 05:06 PM   #14
fr0st
Member#: 41618
2008 WRX Hatch
wrb
it's not noisy on mine yet.. but it's so rusted up that it actually spins on the up pipe
i really have to take it off and wrap the up pipe..
i didn't check just yet but will while i'm doing my oil change in a few weeks..
is there any space to wrap it while installed ??
Old 03-06-2013, 05:13 PM   #15
danger1138
Member#: 279525
04 rex luger!
With the heatshield still on? Its gonna be a tight squeeze.
Old 03-06-2013, 07:17 PM   #16
fr0st
Member#: 41618
2008 WRX Hatch
wrb
No i'll remove it prior..
Will i be able to wrap the up pipe then if i leave it installed?
Old 03-06-2013, 08:44 PM   #17
VinceCarter
Member#: 284694
2006 WRX 6 Speed
277/323 @ EFI Logics
Never wrap it.
This. Don't wrap things in the engine bay. Just coat it.
VinceCarter is offline   Reply With Quote
Old 03-06-2013, 08:50 PM   #18
danger1138
Member#: 279525
04 rex luger!
Im not sure about that^^ been running since the summer time with my perrin up pipe wrapped, all good so far.
Old 03-06-2013, 08:52 PM   #19
VinceCarter
Member#: 284694
2006 WRX 6 Speed
I'm not surprised but if you can coat something rather than wrap it I see that as a much better alternative. I wouldn't want any gas/oil/grease to get onto that wrap.
Old 03-06-2013, 09:04 PM   #20
danger1138
Member#: 279525
04 rex luger!
Ooops 4got to mention, mines was first sprayed with that thermo tec heat spray, later wrapped.
Old 03-06-2013, 09:11 PM   #21
Uncle Scotty
Member#: 16200
OK buy Nates beans
Originally Posted by BraveSTi View Post
This x 2
if idiots didnt post such stupid **** around here.....YOU
things woud be easier
leave the OT **** in OT....stop ****in around...idiots
Old 03-06-2013, 09:22 PM   #22
nhat
Member#: 140163
03 STi
hellaflunctional
I prefer coating to wrapping simply due to the risk of oil fires.
Old 03-06-2013, 10:22 PM   #23
Mr Wrex
Member#: 332887
2012 WRX stage 2+
DGM (sedan)
I wrap all of my parts and not once have I had an oil fire. Yes I've had oil wick about it, but nothing has happened. Yay DEI titanium wrap
Old 03-08-2013, 02:53 AM   #24
BraveSTi
Member#: 262030
Look who's talkin here.. you mad unckle crouchy
Don't be so serious. I know its your yob and tihs, but its only the internets.
Old 03-08-2013, 02:58 AM   #25
BraveSTi
Member#: 262030
I don't wrap. I coated.. Swain Tech AIIIIIGHT?!!
