Old 03-06-2013, 09:29 AM   #1
vrcoupe
Member#: 258300
02 wrx
Default 05 wrx pulsating help
I have an 05 wrx and when you are on it it starts pulsating and jumps between 15-20 psi boost. I don't know much about the car but it has an intake, bigger top mount intercooler, hks bov, and 3in turbo back exhaust with no cat. If someone could give me an idea what might be wrong that would be great. I was thinking it might need injectors??
vrcoupe is offline   Reply With Quote
Old 03-06-2013, 10:41 AM   #2
JMSok8
Member#: 309967
2003 WRX PSM vf34
I got a crap tune once that made the car have a back and forth feeling in the higher gears and the boost would fluctuate just as you are describing. It wasnt a violent feeling, but trying to accelerate on the freeway sucked. I would do some data logs and report back.
JMSok8 is offline   Reply With Quote
Old 03-06-2013, 11:23 AM   #3
Dakota D
Member#: 293894
2011 wrx sti
world rally blue
my suggestion is to check for leaks,also bovs if leaky can cause this issue a crap intake could also cause issues if its not tuned for.
what intake is on it?
do you know if its tuned?
Dakota D is offline   Reply With Quote
Old 03-06-2013, 11:39 AM   #4
vrcoupe
Member#: 258300
02 wrx
I don't know if it has a tune or not and it has some cheap intake on it.
Old 03-06-2013, 12:01 PM   #5
Dakota D
Member#: 293894
2011 wrx sti
world rally blue
cheap as in ebay cheap? that could be the problem right there(maf readings could be severly skewed) and if its not tuned thats a double wammy,that can cause alot of other issues.
when it pulsates does the car feel like its jerking?
Old 03-06-2013, 12:40 PM   #6
vrcoupe
Member#: 258300
02 wrx
Ok, it's not jerking its like a smooth pulsating.
Old 03-06-2013, 12:44 PM   #7
Dakota D
Member#: 293894
2011 wrx sti
world rally blue
hmm.have you checked for leaks yet like i suggested earlier?
Old 03-06-2013, 12:48 PM   #8
vrcoupe
Member#: 258300
02 wrx
Not yet I'm going to be doing that later today.
Old 03-07-2013, 02:59 PM   #9
blubug_768
Member#: 324962
02 WRX
I just read about this, its apparently common w/stock bcs. The remidy would be 3 port ebcs + tune.
blubug_768 is offline   Reply With Quote
Old 03-07-2013, 03:35 PM   #10
vrcoupe
Member#: 258300
02 wrx
Would the turbo going bad cause this?
Old 03-07-2013, 03:45 PM   #11
Cory51191
Member#: 332781
2006 STI
Check the vacuum line that goes from the turbo to the T-fitting before the stock BCS. There should be a small "restrictor pill" in the line somewhere that controls the amount of flow from the turbo to the sensor so it can accurately read boost levels. Make sure the machines hole in the pill doesn't have something blocking the consistent flow.
http://www.clubwrx.net/forums/tuning...-data-log.html
Go to post 10 there's a diagram.
Cory51191 is offline   Reply With Quote
Old 03-08-2013, 05:53 PM   #12
nfm
Member#: 171697
05 WRX 16G XT
Usually such intakes flow more than stock airbox, around 20% more in closed loop/off-boost, and between 0-10% in open loop, resulting in engine running lean and all it takes is one good knock and engine goes BOOM.
It's good to check for holes/slits in the bcs vacuum lines, if there is one that means that air is bleeding, without ECU's knowledge, without bcs/ebcs ever getting chance to bleed/intercept that air, this results in less pressure being applied against wastegate, resulting in higher boost, you overshoot the target boost, turbo dynamics kicks in, you undershoot, and you keep oscillating back and forth.
Not really a common problem, if you're unlucky you're bcs seizes to work, which in turn it doesn't bleed any air, so all that pressure coming from compressor outlet gets applied against wastegate, once you hit 7/8psi, clapper opens up and you won't run anymore boost than that.
No.
nfm is offline   Reply With Quote
Old 03-09-2013, 01:58 AM   #13
ogboot
Member#: 170906
psm
If the boost is oscillating you are overshooting your boost target. Best fix is to look up how to adjust your wastegate arm.
ogboot is offline   Reply With Quote
