Welcome to the North American Subaru Impreza Owners Club Monday May 25, 2015
Old 03-06-2013, 11:53 AM   #1
Vpduong
Member#: 272971
2009 WRX
Default Freezing my intercooler instantly
I am planning on taking my car to the drag strip and I was wondering if it was a good idea to freeze my topmount before runs with the instant freezing spray they use for electronic parts. I.know people have used ice bags but I'm curious if anyone has ever freeze sprayed theirs because I don't want to have a melting bag of ice in my car. I posted a link of the spray so everyone knows what I'm talking about. I was thinking that or spraying my tmic with nitrogen or CO2 with the paintball gun tanks. I just want something portable and not.have to get an intercooler spray kit because it's not worth it in my opinion when I can do this haha
http://www.crcindustries.com/ei/cont...x?PN=14086&S=Y
Vpduong is offline   Reply With Quote
Old 03-06-2013, 11:58 AM   #2
pauli133
Member#: 233261
2005 Outback XT
Seriously! Why pay for something designed to do what you want, when you can rig up an ineffective, wasteful, and potentially dangerous ghetto version?
pauli133 is offline   Reply With Quote
Old 03-06-2013, 12:04 PM   #3
Mr Wrex
Member#: 332887
2012 WRX stage 2+
DGM (sedan)
Why not start with wrapping all of your exhaust components to avoid heat soak? Better yet, why not just throw a meth kit in there?
Mr Wrex is offline   Reply With Quote
Old 03-06-2013, 12:05 PM   #4
Jack
Add Lightness
Member#: 13699
2007 Lotus Elise
(From General)
Would it help? Sure. Would it help much? No. The problem is that there isn't enough thermal mass there that it's going to keep things cool. This is essentially what putting meth into the intake does. So if you really want to do this, have the cold spray hooked up to spray into the intake charge. It will likely get you an additional 3ms off your 1/4 mile time, however the added weight of the cold spray can will lose you 10ms on your time.
Dry ice is better, packed around the intercooler/intake piping. It doesn't leak into a liquid like ice. A really scummy way to win against someone running ice is to wave at the track officials and tell them that you're leaking fuel. You get DQ'd and they win. Dry ice doesn't do this.
Old 03-06-2013, 12:13 PM   #5
Vpduong
Member#: 272971
2009 WRX
I already do have meth kit I'm about to throw on and the heat barriers, I know the gains wouldnt be noticeable if even existant except on a butt dyno. I know people install co2 and nitrous spray kits for a few hundred dollars to do pretty much the same thing. It seems like something new that it would be worth a try for gits and shiggles.
Old 03-06-2013, 12:27 PM   #6
Turd Nugget
Member#: 346017
2013 STi Wagon
Satin White Pearl
I used to run meth both through the intake and sprayed on the intercooler. When sprayed on the intercooler the liquid which evaporates faster than water just helps a little by making the heat transfer faster basically making the car think its got a bigger intercooler. when on the dyno or track I'd use 100% meth but otherwise i'd use windshield washer fluid, it is just water/meth mix and if you get it to like -30F it is pretty high concentration and waaaaay cheaper than buying meth from a shop. On a hot day without meth I'd see 140+ deg F intake temps, with the meth in the intake it would be down to pretty much ambient, and if I sprayed the intercooler I could get another 5 deg or so.
Turd Nugget is offline   Reply With Quote
Old 03-06-2013, 12:28 PM   #7
Turd Nugget
Member#: 346017
2013 STi Wagon
Satin White Pearl
Id say a pretty easy way to get a cheap extra few deg of cooling would be to run the lines from your windshield sprayer to just spray the intercooler, would be cheap and easy.
Old 03-06-2013, 12:29 PM   #8
i_c_the_light
Member#: 88618
1994 Legacy
"The Silver Slug"
**** just give it a try, you'll never really know otherwise.
i_c_the_light is offline   Reply With Quote
Old 03-06-2013, 01:34 PM   #9
Loyale93
Newbie Moderator
Member#: 91347
'13 XV Crosstrek,
1050 Triumph Speed Triple
Use liquid nitrogen, it will really cool down the metal a lot. And don't worry about the metal fatiguing or cracking. It's metal!! It's strong!!
If you don't wrap your pipes and mitigate heat soak, any cooling you do right before the run will be gone before the lights turn yellow. That's kind of the point of a spray that works while you're driving, so you get the instantaneous cooling. So I guess if you rigged up a few bottles like that. Then you could have a laptop in your passenger seat that says "DANGER TO MANIFOLD!!" as you spray, right before your floor board drops out for no reason...
Loyale93 is offline   Reply With Quote
Old 03-06-2013, 01:37 PM   #10
vision.dynamix
Member#: 139955
2015 Subaru STI
Stage e
Use a fire extinguisher. They used it to chill a 6-pack on myth busters.
Old 03-06-2013, 01:38 PM   #11
Turd Nugget
Member#: 346017
2013 STi Wagon
Satin White Pearl
or you could just sell some sr20 race motors, I hear they pull a premium right before race wars.
Old 03-06-2013, 01:41 PM   #12
vision.dynamix
Member#: 139955
2015 Subaru STI
Stage e
Also, don't disrespect my famiry.
Old 03-06-2013, 03:38 PM   #13
i_c_the_light
Member#: 88618
1994 Legacy
"The Silver Slug"
I like the fire extinguisher idea.
Old 03-06-2013, 03:39 PM   #14
Vpduong
Member#: 272971
2009 WRX
whatever. ill just tape ice cubes to my tmic
Old 03-06-2013, 03:49 PM   #15
Loyale93
Newbie Moderator
Member#: 91347
'13 XV Crosstrek,
Remember to use lots of duct tape. you don't want ice cubes coming loose at those new top speeds you'll be hitting down the quarter.
Old 03-06-2013, 04:25 PM   #16
Unabomber
Big Ron
Member#: 18062
on car parts so PM
me b4 j00 buy
Any really effective intercooler cooling trick will require specific tuning for that affect. Do you ever hear of anyone getting their car road tuned in Canada in January and then running that tune in Phoenix in August....think that through.
Old 03-06-2013, 04:52 PM   #17
Vpduong
Member#: 272971
2009 WRX
Do that and you'll be lucky you don't blow the weld off your intake
Old 03-06-2013, 05:45 PM   #18
nhmtns
Member#: 94283
'05 OBXT Stage 2
Min bil är svart
Two better solutions: drink some Coors Light or bring along Ice Cube
nhmtns is offline   Reply With Quote
Old 03-06-2013, 06:07 PM   #19
SatinWhitePearl
Member#: 170780
2007 STi
Satin White Pearl
... I'm not sure what to say here, but I laughed.
SatinWhitePearl is offline   Reply With Quote
Old 03-07-2013, 02:09 AM   #20
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
yeah....why not
Old 03-07-2013, 02:11 AM   #21
Uncle Scotty
Member#: 16200
OK buy Nates beans
we usta do that at a place i worked years ago....works great
Old 03-07-2013, 02:24 AM   #22
Pitcrew91
Member#: 271718
2005 STi
Why not go Front mount?
Pitcrew91 is offline   Reply With Quote
Old 03-07-2013, 03:07 AM   #23
Frankh21
Member#: 295776
2005 SAAB 9-2x Aero
Take a computer keyboard duster can and invert it and spray it onto the IC.
Frankh21 is offline   Reply With Quote
Old 03-07-2013, 01:09 PM   #24
p951951951t
Member#: 276541
1972 Alfa Romeo GTV
Alfa Rosso
Don't waste your time.
p951951951t is offline   Reply With Quote
Old 03-07-2013, 02:55 PM   #25
greenplates
Member#: 239162
You would be more beneficial by spending your time removing rear seats, spare tire, and finding some excellent fuel.
bring ice bags
greenplates is offline   Reply With Quote
