Welcome to the North American Subaru Impreza Owners Club Tuesday September 1, 2015
Mid Atlantic Impreza Club
Old 03-06-2013, 01:37 PM   #1
6thgenva
Member#: 264569
2005 Stage II WRX
Platinum Silver
Default Snow + Curb = -_-
Ok I am going to get straight to the point on this. I like alot of you there have been looking forward to snow for quite some time in NOVA. So having an 05 WRX, with snow tires, I wanted to see just how much the car could take (handling wise).
The car handled like a champ, so not being content I wanted to see how far I could take it. Empty parking lot donuts etc. Long story short, I lost control over the car and went over a curb. I was going 25+ and hit from the front passenger wheel and carried speed all the way off the curb.
From what I can tell, the only damage I could find was the splitter, that ripped right off of the car. Wheels, tires, all other body work looked fine.
Since I have BC BR on, I am worried about my coilovers. I drove it a bit after, and everything felt normal.
What other damage should I look for? What should my next steps be? Should I take it to Mach V or any other shop to have them look it over.
Yes I now I am stupid, but I am looking for any type of help/advice I can get.
-Ryan
6thgenva is offline   Reply With Quote
Old 03-06-2013, 01:39 PM   #2
ryan s.
Member#: 276486
'08 lowered Outback
If it were me I'd take it to a professional ASAP
ryan s. is offline   Reply With Quote
Old 03-06-2013, 02:16 PM   #3
Grinder34
Member#: 252410
07 STI
Grinder34 is offline   Reply With Quote
Old 03-06-2013, 02:29 PM   #4
Insert name
Member#: 255640
2005 WRX
Came in here for a picture, received a wall of text.
Insert name is offline   Reply With Quote
Old 03-06-2013, 02:30 PM   #5
05WrXSTiCgM21
Member#: 182470
06 20g'd STi
sorry to hear that man, would probably head to a shop to make sure there is no damage done if you aren't quite sure what to be looking for.
05WrXSTiCgM21 is offline   Reply With Quote
Old 03-06-2013, 02:55 PM   #6
irish44j
Member#: 191290
09 OPB SM WRXsedan
85 BMW E30 M2 Rallycrossr
damn, where were you? I spent all day TRYING to find someplace with some slipperyness to it. All I found was boring wet and slushy roads.....
irish44j is offline   Reply With Quote
Old 03-06-2013, 03:13 PM   #7
spintheground
Member#: 239638
2007 WRX TR UGM
02 MR2 EGM
I hit a pothole the size of a curb hidden under 16 or so inches of snow going about 10-15mph in New Hampshire a few years ago.
Cracked wheel, bent tie rods and control arm.... Yeah I'd put it on a lift and get a good look at it man.
spintheground is offline   Reply With Quote
Old 03-06-2013, 04:30 PM   #8
6thgenva
Member#: 264569
2005 Stage II WRX
Platinum Silver
I will get it to a shop ASAP. I drove it a couple of more times today, all seems to be normal. The only thing that is a little different is the ride height. It looks to be a tad bit higher.
But that could be me being extra critical. Or it could be the front splitter being off.
Old 03-06-2013, 04:47 PM   #9
jrouillard
Member#: 283648
2011 WRX
Keep driving it without having it checked out and you're only making a potentially unrecognized problem worse.
jrouillard is offline   Reply With Quote
Old 03-06-2013, 07:12 PM   #10
hkprofection
Member#: 324309
04 WRX
Look your wheels over good for bends, cracks, and the tires for any damage.
If you're not up to checking stuff out under the car yourself, then take it to a professional and have them do an alignment ASAP.
If everything checks out, then consider yourself lucky!
Did you hit it straight on or more from the side?
hkprofection is offline   Reply With Quote
Old 03-06-2013, 07:34 PM   #11
CamaroFS34
Member#: 6850
1996 Camaro Z28 1LE
& 2006 IAG WRX (ForSale!)
This. I would be getting it checked out, and at the least re-aligned, as soon as possible. How high was the curb?
CamaroFS34 is offline   Reply With Quote
Old 03-06-2013, 08:46 PM   #12
6thgenva
Member#: 264569
2005 Stage II WRX
Platinum Silver
I hit from a slide. Hopefully Mach V will take a look at it this weekend. Fingers crossed
Old 03-06-2013, 08:56 PM   #13
KAT_Ayanami
Member#: 155017
2000 2.5RS
Blue Ridge Pearl
Edited.
KAT_Ayanami is offline   Reply With Quote
Old 03-06-2013, 10:21 PM   #14
metros
Member#: 111343
Or stick with an established and well respected shop like machV. Either way.
metros is offline   Reply With Quote
Old 03-06-2013, 10:38 PM   #15
mmetalmilitiaa
Member#: 160878
06 sti
sgm
Are you implying that Bilbo Automotive is not respected or established, have you been there... Heard anything negative about them?
I could list a page full of complaints I have heard about Mach V over the years. Doesn't mean they suck. But in my opinion, your statement is a tad silly, although I understand what you're trying to say.
OP get your car looked at somewhere convenient - you're just looking for damage, not getting an engine tuned... I'm sure you know enough about your car to tell if a shop is trying to screw you.
mmetalmilitiaa is offline   Reply With Quote
Old 03-07-2013, 01:08 AM   #16
vivalegreg
Member#: 203088
03 General Li wrx
orrrange!
whereever you take it, im sure the alignment is knocked out so by getting it on the alignment machine you can tell if components are bent if you cant tell by doing a visual check. sometimes components can LOOK ok but are actually bent..
and just for the record i have a brother who has taken his car into curbs more then one occasion ill just say and he has bc brs on his car and after all the beating they have been through, they have outlasted the control arms and knuckles hes gone through..
outlasted meaning he is still running the same coilovers and they are functioning fine.
vivalegreg is online now   Reply With Quote
Old 03-07-2013, 12:27 PM   #17
6thgenva
Member#: 264569
2005 Stage II WRX
Platinum Silver
If Mach V cant get me in, I will take it to shop (merchants, bilbo etc) and get it checked out by them.
Then after taking a look at it myself and hearing there assessment, I can make a decision from there.
Old 03-07-2013, 11:15 PM   #18
metros
Member#: 111343
No, I'm saying he's better off taken it to a well respected shop than taking some internet guys opinion to go to a never heard of shop. Believe what you want about MachV but I completely trust my car with them and that's worth paying a few extra bucks to me.
Or you can go to Carlos's oil change shop in Manassas and hope everything works out.
Old 03-08-2013, 04:12 AM   #19
KAT_Ayanami
Member#: 155017
2000 2.5RS
Blue Ridge Pearl
Edited.
Old 03-08-2013, 08:12 AM   #20
BoostinIX
Member#: 136701
2013 WRBBRZ/S14 240
04WRX/05STi- Goooone
Here's a thought....OP already mentioned Mach V. Stick with what OP wanted.
Kat- you're not helping that shop any by coming off pushy and defensive. OP has your recommendation, getting argumentative over it isn't doing any good. I've never heard of them but your attitude alone makes me not care. You're pushing a new shop (new to here) among a tight-knit group of enthusiasts that are quite loyal to their shops. Accept that not everyone is going to jump because you say you have a good experience. Every shop has bad stories, bet there's some about Bilbo too. Dan's got a proven track record here, like most of the NASIOC vendors. Bilbo doesn't, at least not on NASIOC. That's what he meant about a respected and established shop.
If you want your shop to have that chance, you need to chill.
Moving on.
How do you side swipe a curb at 25 with no wheel damage?
BoostinIX is offline   Reply With Quote
Old 03-08-2013, 11:17 AM   #21
mmetalmilitiaa
Member#: 160878
06 sti
sgm
....luck.
And the correct angles, of course.
Old 03-08-2013, 12:34 PM   #22
6thgenva
Member#: 264569
2005 Stage II WRX
Platinum Silver
....luck.
I am just as surprised as you by this no wheel/rim/tire damage.
Just the lip, maybe I wasn't going 25 , but I slid , and went over the curb.And it was enough to make me concerned.
Fingers crossed hopefully the lip is the only loss.
Old 03-08-2013, 01:34 PM   #23
metros
Member#: 111343
Moving on.
This. Said better than I could.
For the record - I had no idea that a Carlos worked at the shop. That's just a strange coincidence.
OP - When are you getting it looked at? Curious to know the outcome.
Old 03-08-2013, 07:11 PM   #24
KAT_Ayanami
Member#: 155017
2000 2.5RS
Blue Ridge Pearl
Edited.
Old 03-09-2013, 03:32 PM   #25
sushi-rice
Member#: 305075
2010 Impreza WRX Lim
Pearl
Here a pics of my Subie after the last snow in Richmond around mid January. I needed two new wheels and two suspension controller arms after that little accident!
sushi-rice is offline   Reply With Quote
