Old 03-06-2013, 03:35 PM   #1
ScoobyDrift
Member#: 315446
2004 Impreza 2.5L
Default Steering rack
Ok guys I have a serious problem, and could really do with some much needed advice.
My steering rack gets stiff at times during driving not a permanent stiffness but off and on. So I bleed the entire system and changed the fluid, work great for about a week then problem started back, check for leaks NONE check for bubbles in the reservoir to see if air was getting into the system NONE.
And advice will be greatly appreciated.
ScoobyDrift is offline   Reply With Quote
Old 03-07-2013, 12:01 AM   #2
mod maniac
Member#: 300551
2002 FOZ STI 2.34
Fullers Garage
Try adding some friction modifier.
Old 03-07-2013, 09:55 AM   #3
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
QuickSilver Metallic
My advice would be to post in the Brakes, Steering, & Suspension forum, since this topic has nothing to do with the Normally Aspirated Powertrain.
Old 03-07-2013, 08:49 PM   #4
05rs_will
Member#: 216688
2005 2.5rs
aspen white
I had the same issue it would be stiff, but cut in and out and it seemed to be the Steering U-joint that was seized, got it replaced and worked fine...unfortunately i replaced it with a used one and the problem came back 2 years later....
05rs_will is offline   Reply With Quote
