Welcome to the North American Subaru Impreza Owners Club Saturday December 3, 2016
Old 03-06-2013, 09:56 PM   #1
xxsive25
Member#: 16669
my02 rex
blue
Question boost / pressure source
I have done exstensive research on the pros and cons of using the
intake manifold for a boost source.
im running an older stock location atp 3076 and the compressor housing is not tapped for a boost source so im using the vacume port that normally goes to the bpv. Who here is running a similar setup with success?
xxsive25 is offline   Reply With Quote
Old 03-06-2013, 10:41 PM   #2
wrxsubiemod
Member#: 165104
E85 SoCalPorting
Owner
For what?
Old 03-06-2013, 10:50 PM   #3
xxsive25
Member#: 16669
my02 rex
blue
Originally Posted by wrxsubiemod View Post
For what?
for pressure / boost source input to the 3 port
boost control solenoid.......
not sure what your asking....
Old 03-06-2013, 11:09 PM   #4
wrxsubiemod
Member#: 165104
E85 SoCalPorting
Owner
Not sure what u were asking. You should go off the turbo for a 3 port
Old 03-07-2013, 01:52 AM   #5
gnazlukh
Member#: 349340
2010 Toyota Prius
wrxsubiemod is correct you should go off the turbo. It's not hard to tap the turbo compressor housing.
gnazlukh is offline   Reply With Quote
Old 03-07-2013, 11:31 AM   #6
wrxsubiemod
Member#: 165104
E85 SoCalPorting
Owner
I have seen a few people run a fitting off of their boost coupler. Not sure how its done
