Welcome to the North American Subaru Impreza Owners Club Tuesday June 2, 2015
Old 03-07-2013, 11:44 AM   #1
CryderSpeed
Member#: 88816
TO TWERK
Default Suddenly Getting TERRIBLE Gas Mileage!
Hey all, apologies if this ends up not being in the right subforum but it's a place to start.
I've got an '05 Saabaru with 116k on the clock and the car has been essentially trouble free apart from replacing the A/C system last summer. I typically average 250-260 miles a tank during mostly urban driving but over the past week my mileage has been cut by more almost half.
Car still drives fine, no loss of power that I can feel, no CEL's, no weird noises/vibrations. Tires are properly inflated, oil is freshly changed, tmiing belt done at 100k, etc. Car has Cobb Stg 1 flash and a Perrin air filter but powertrain is otherwise stock.
I'm planning on taking it in to my mechanic but I'd like to have an idea of what's going on, anyone got any ideas? Thanks in advance!
CryderSpeed is offline   Reply With Quote
Old 03-07-2013, 11:51 AM   #2
imprezats032
Member#: 306200
2002 wrx sedan
wrb
Is the air filter clean? How about the fuel filer?
imprezats032 is offline   Reply With Quote
Old 03-07-2013, 12:17 PM   #3
CryderSpeed
Member#: 88816
TO TWERK
Air filter could probably use a scrubbing but typically stays pretty clean during the winter on account of all the rain here. Never messed with the fuel filter, since my car is a 2005 vs 2006 the FF should be under the hood on the passenger side, correct?
Old 03-07-2013, 12:37 PM   #4
jh57
Member#: 314962
2003 WRX Wagon
Silver/Black
Might have a frozen or sticky brake caliper. Go for a normal highway drive then feel the lugnuts on each wheel for an unusual amount of heat.
Wife's Honda Element just did this in Jan. Her MPG dropped about 20% suddenly. I cleaned and greased the caliper pins and her MPG went back to normal instantly.
jh57 is offline   Reply With Quote
Old 03-07-2013, 12:43 PM   #5
KOJAK-02-WRX
Member#: 208052
2004 SGM FXT-6speed
*SOLD* 02 PSM WRX
Try cleaning MAF sensor could help or O2 sensor could still be bad without code.
KOJAK-02-WRX is offline   Reply With Quote
Old 03-07-2013, 12:46 PM   #6
CryderSpeed
Member#: 88816
TO TWERK
Interesting, I did just have a full brake job, will investigate, thanks!
Old 03-07-2013, 01:14 PM   #7
Cory51191
Member#: 332781
2006 STI
First thing I would check is my parking spot/under the car to look for a fuel leak.
Cory51191 is offline   Reply With Quote
Old 03-07-2013, 05:24 PM   #8
Barnt
Member#: 161824
15 WRX. Pro-tuned
Way too blue...
Fuel filter is inside the tank I believe
Barnt is offline   Reply With Quote
Old 03-07-2013, 07:14 PM   #9
bluemk3
Member#: 263694
World Rally Blue
No.. it's not...
bluemk3 is offline   Reply With Quote
Old 03-07-2013, 07:49 PM   #10
greenplates
Member#: 239162
I am a big fan of maintenance. Every few months, I get a bug in my a** and start replacing old parts. It feels good
Perhaps you should do the same.
Here are a few to consider-
o2 sensors (front/rear)
MAF sensor
PCV valve
air filter
fuel filter
brake pads
lucas oil injector cleaner
money well spent
greenplates is offline   Reply With Quote
Old 03-07-2013, 07:53 PM   #11
DZXN
Member#: 306186
2002 Subaru WRX
Actually I think 05 was when fuel filter went in the tank on the wrx and sti. Not positive.
DZXN is offline   Reply With Quote
Old 03-07-2013, 07:58 PM   #12
kevin85193
Member#: 145900
2003 16g wagon sold
05 SWP LGT
started in 04. BUT some 04's have the FF in the engine bay
kevin85193 is offline   Reply With Quote
Old 03-07-2013, 08:25 PM   #13
Nicklz
Member#: 94096
2003 WRX
fwiw I've never gotten an o2 failure code and I've got over 250k miles on my 03wrx.
Every time my o2 started to go out, my mileage will take a huge hit like that.
New sensor and back to 300+ miles a tank.
Nicklz is offline   Reply With Quote
Old 03-08-2013, 08:43 AM   #14
cmiovino
Member#: 134005
2004 WRX Premium
I've had the same happen too... if you keep up with the regular MPG stuff.. aka, tires pumped up, fuel filter, spark plugs, etc on a normal schedule.. normally MPG drops are O2 sensor related. If you haven't changed the front one in a while, I suggest changing it as preventive maintenance.
You may also want to clean your MAF. O2 sensors can't be cleaned, but MAFs generally can. This is good because MAFs are more $$$. Front O2's are about $100-150.
Old 03-10-2013, 10:14 AM   #15
D-Rodman
Member#: 110078
05 saabaru artc gr
02 wrx wag wrb ej207
Change the pcv valve, my fuel economy was also hurting and a new pcv valve restored it.
D-Rodman is offline   Reply With Quote
Old 03-10-2013, 03:56 PM   #16
danger1138
Member#: 279525
04 rex luger!
^^ u can also clean it/ remove the gunk with maf cleaner. Just make sure its making the clicking sound unimpeded ..
danger1138 is offline   Reply With Quote
Old 03-10-2013, 06:30 PM   #17
CryderSpeed
Member#: 88816
TO TWERK
PCV and O2 sensors are a another good idea. I'm probably going to just end up replacing a a bunch of stuff if my garage can't narrow it down to any one thing.
I did check to see if one wheel was hotter than the others indicating a sticking caliper, looks like we're OK there.
Old 03-12-2013, 03:44 AM   #18
Cornerstore
Member#: 328429
+1!!!
Cornerstore is offline   Reply With Quote
Old 03-12-2013, 10:42 AM   #19
Barnt
Member#: 161824
15 WRX. Pro-tuned
Way too blue...
Originally Posted by bluemk3 View Post
No.. it's not...
yes...it is...
Old 03-14-2013, 09:10 AM   #20
shamrock 05
Member#: 120057
2015 WRX
02-04 FF are in the engine bay, 05+ went to the fuel tank
shamrock 05 is offline   Reply With Quote
