Old 08-20-2011, 01:08 PM   #1
JimmyOOOOO
Member#: 12647
2011 STi
Obsidian Black Swirl
Default 2011 STi: Valentine 1 wired to Map Light
Bye-bye lame curly-cord tht scratches whimpy trim pieces!
Red to Gray and Green to Green. Done!
Wish there was power in there at was connected to the ignition instead of always on, but I guess the first time I kill my bettery I'll remember.
JimmyOOOOO is offline   Reply With Quote
Old 08-20-2011, 01:08 PM   #2
JimmyOOOOO
Member#: 12647
2011 STi
Reserved for the pics I know you're gonna ask for
Old 08-20-2011, 08:26 PM   #3
PARANOID56
Member#: 22035
2003 Brocoma DCab
71 FJ40, 13 DRZ400SM
i dont remember what i attached mine to, but its to some wires in the map light area but they were acc on only. been working great for years now
PARANOID56 is online now   Reply With Quote
Old 08-20-2011, 09:45 PM   #4
vinz0r
Member#: 154112
08 STi
You could always splice into the auto-dimming / homelink mirror if you have that. There's an ignition-based line.
vinz0r is offline   Reply With Quote
Old 08-20-2011, 09:57 PM   #5
jtc4313
Member#: 273611
2011 WRX Premium
I've been meaning to do this on my 2011 wrx and just haven't had the time. Rather I'm just too damn lazy to do so.
jtc4313 is offline   Reply With Quote
Old 08-20-2011, 11:22 PM   #6
huynhvx
Member#: 271434
2011 WRX 4-Door
I want to hardwire my V1 to the auto-dimming, homelink mirror on my 2011 WRX also.
Does anyone know the wire chart for the cables coming from the auto-dimming mirror? Looks like there is 4 total: 2 black, one black/white, and a black that is kind of folded around the other 3.
I'm guessing, maybe the b/w is the hot and the wrap around black is the ground? It kind of looks like this image here.
huynhvx is offline   Reply With Quote
Old 08-21-2011, 02:03 AM   #7
CSVT_2004
Member#: 182213
1999 Contour SVT
Use key sense to activate a relay to turn the V1 on....
CSVT_2004 is offline   Reply With Quote
Old 10-27-2011, 08:00 PM   #8
Scooby207
Member#: 255687
11 WRX DGM
bump for wiring diagram
Scooby207 is offline   Reply With Quote
Old 10-27-2011, 10:32 PM   #9
huynhvx
Member#: 271434
2011 WRX 4-Door
I found what the wires are.
The b/w is hot
The middle black is the ground.
I actually went to radio shack and use their blue 3M scotchlok.
I can't find the item on the radioshack site, but this is what it looks like.
http://www.etrailer.com/Accessories-...s/3M/804C.html
It was around $5 for a pack of 10.
Old 10-27-2011, 11:47 PM   #10
OrbitalEllipses
Member#: 178811
2011 White Corolla
Over 400hp
I believe those are referred to as vampire taps. I prefer soldering connections, personally.
OrbitalEllipses is offline   Reply With Quote
Old 10-28-2011, 01:11 AM   #11
razrielle
Member#: 205698
I hate vampire taps, the most useless thing I have ever used. they're supposed to be a no strip solution, every one Ive used Ive had to strip a bit of wire
razrielle is offline   Reply With Quote
Old 10-28-2011, 01:14 AM   #12
CSVT_2004
Member#: 182213
1999 Contour SVT
That they are, and they are the worst way to install equipment.
Old 10-28-2011, 07:32 AM   #13
Scooby207
Member#: 255687
11 WRX DGM
The b/w is hot
thanks for the info.
i'm planning on using posi-taps...they are the same concept as vampire clips but it is a small pin the pokes through the coating on the wire. I used them when i did this on my last subie. When you take them off there is nothing left showing except a small hole.
Hard to find though...just order them online and be pateint
Old 10-28-2011, 11:51 AM   #14
huynhvx
Member#: 271434
2011 WRX 4-Door
I didn't realize other people were having problem using the Wire Tap-In Squeeze Connectors.
This is the first time I've use these wire-tap-in squeeze connectors. A friend of mine recommended them and they work just fine for me. Feed in the cables and squeeze. You have to use a pair of pliers to make sure they have enough squeeze on them. But you also don't want to over-squeeze them.
They are actually only $2.39 for 10. So the price is right.
http://www.radioshack.com/product/in...ductId=2104093
So the cost of the whole setup for me was next to nothing. Just had to figure out which of the wire from the Homelink was hot and ground and 2 wire tap-in squeeze connectors.
Old 10-28-2011, 08:18 PM   #15
CSVT_2004
Member#: 182213
1999 Contour SVT
I've said it once, and I'll say it again... Just because it's cheap and available, doesn't mean you should use it in an automotive application. Learn how to splice wires together properly... Here are some references...
http://www.mmxpress.com/technical/connections.htm
Old 10-29-2011, 09:22 AM   #16
Scooby207
Member#: 255687
11 WRX DGM
^ I can respect that. I guess I was going for a shortcut too with the posi- taps but they worked for me perfect and when I got rid of the car it was 2 seconds to uninstall and I didn't have to re-wire the mirror. Again I admit it is a shortcut but for something like the V1... Is it that important to have any more sophisticated of a connecting.. For audio components like we're mentioned in that first reference you posted, it makes more sense to me.
With that said, if you give me a good answer I will probably try to be a real electrician and do some soldering
Old 10-29-2011, 01:34 PM   #17
Power6
Member#: 72730
2001 Lexus ES300,
2005 Outback XT
Yeah T-taps are the worst. I used to like them, because they tap and make an easy connection that is removable vs. the "scotch lock" style taps. All the taps have the same issues but the t-tap kind are the worst.
The posi-lock stuff is better. At least it eliminates the variablity of making and losing connection as it crimps down on the wires that are joined/tapped.
Still you compromise the integrity of any wire with a tap, even if it is a good tap. Also usually the resistance of the tap will be greater than if the wires were soldered. That could be bad depending on how much current you are passing through.
I like to think longer term solutions now, I don't want to have to go back in later to fix something I didn't do right, so I solder and use quality wire and materials. Those things might not matter if you trade your car every couple/few years.
Power6 is offline   Reply With Quote
Old 10-30-2011, 11:49 AM   #18
CSVT_2004
Member#: 182213
1999 Contour SVT
In reality a splice/tap can be done relatively quickly once you're used to it. Not all of them require solder. Solder is a nice insurance that there will be no loose connection. Personally if I was doing it, I'd just do the typical military/western union splice (Whatever you want to call it) and then electrical tape it and a zip tie for tension relief and call it a day. On things like remote starts though, I always solder, that way there is no doubt in my mind on my connections, especially when it comes to MUX (multiplex) and DATA wires. A bad connection on one of those and you'll have problems for sure.
Plus like the other guy stated. If your t-tap fails, then you have to go back a redo it. I believe in the do it right the first time, or don't do it all philosophy.
Old 11-01-2011, 02:03 PM   #19
Zonker92
Member#: 299098
2011 WRX Base 5D
Red
A company called Blendmount makes a "Mirrortap" cable that uses thin pins to tap into the Homelink jack on the back of the mirror without damaging any wires or using vampires:
http://store.blendmount.com/mirrorta...fuse-p361.aspx
The pins for the Subaru application look to be about 1.25mm thick. I would guess the hot wire goes to the black-and-white wire socket, and the ground goes to the black (middle) socket. (I would probably hide almost all of the red part with some heat-shrink tubing for a more factory look.)
I think the price ($25) is a bit high ($10 is more like it), and I do see that another company, called Rogue, makes a cheaper one called the "Seamless cord". I don't know if the pins are the correct size for a Subaru.
http://rogueradarmount.com/sample/seamless-cord/
I tried to make my own, but I was not able to strip the RJ11 wires properly and I lacked good pins. I would welcome any advice on how to get the right pins, and strip my wires properly.
Zonker92 is offline   Reply With Quote
Old 11-01-2011, 03:48 PM   #20
dvrmstrng
Member#: 274717
2011 WRX TP Stg2+
what mount are you guys using up that high, suction cups? And for those without the homelink mirror...what are you using?
dvrmstrng is offline   Reply With Quote
Old 11-01-2011, 04:00 PM   #21
Zonker92
Member#: 299098
2011 WRX Base 5D
Red
I have the Homelink, but I'm using the V1 suction cups. And I'm eyeballing these:
http://www.blendmount.com/
http://countryjoycrafts.com/Connecto...rDetector.html
Old 11-01-2011, 04:02 PM   #22
Zonker92
Member#: 299098
2011 WRX Base 5D
Red
[double post deleted]
Old 11-02-2011, 12:08 AM   #23
CSVT_2004
Member#: 182213
1999 Contour SVT
Use the FIRE!
A soldering iron or lighter usually work wonders on small wires like that. Get the outer layer a little hot then just pull it off, should be pretty easy to do, just don't burn yourself. Then crimp/solder your ends on.
Old 11-02-2011, 12:11 AM   #24
Zonker92
Member#: 299098
2011 WRX Base 5D
Red
Thanks! Strangely enough, I tried both a soldering iron and a lighter, but the wire was too delicate for fire and the insulation was too tough for the iron. Today I did find that there are RJ11 stripping tools out there, but it's probably cheaper just to buy the premade cable I listed above.
Old 11-02-2011, 01:36 AM   #25
CSVT_2004
Member#: 182213
1999 Contour SVT
Turn your iron up higher then, should be able to melt the outer coating fairly easily, just make a melt on the top and bottom of your wire then pull it off.
1 Solution to Brake Lights Not Working Seda Electrical & Lighting 1 09-13-2012 11:18 AM
Which wire to the ECU id the MAP wire? renhoek Pre-2002 Factory Turbo Powertrain 2 12-08-2008 01:10 AM
Valentine 1, where to get them? crookid7 Car Audio, Video & Security 36 09-07-2008 10:33 PM
wiring radar detector into map light area subieboywrx07 Legacy Forum 2 11-10-2007 06:12 PM
Map light wiring DDMan Car Audio, Video & Security 3 09-18-2002 10:51 PM
