Welcome to the North American Subaru Impreza Owners Club Tuesday September 16, 2014
Old 03-07-2013, 08:37 PM   #1
z0rz
Member#: 231953
Default Weird Boost Spike
The other day I was driving a drunk friend home and had to pull over to the side of the road for.. emergency evacuation.. so my car spent a good amount of time idling that night.
So I finally get the guy home and I'm pulling onto the freeway and my boost gauge spiked up to ~29 PSI and the needle was jumping around a bit as I drove at a constant speed. When I pulled over I didn't see any smoke. The car seemed to drive fine after that but I avoided boost just to be safe.
Fast forward to today, I decide to datalog with my AP and strangely everything seemed completely normal-- boost gauge seemed accurate (wasn't bouncing around), and the car had no problem pulling on some ~50% throttle runs.
Unforunately, I didn't think about updating my AP firmware so it is using some older parameters. Hopefully there's enough to see if anything is wrong. On datalog9 I tried to go WOT but had to let off really fast because I saw a black Ford front end poking around a corner haha.
datalog8
datalog9
datalog10
Car is running Stage 1 Cobb OTS map, all stock aside from K&N filter, Perrin silicone intercooler Y-pipe, and Greddy Evo2 catback.
Does anything look wrong?
z0rz is offline   Reply With Quote
Old 03-09-2013, 12:50 AM   #2
mod maniac
Member#: 300551
2&4 fxt & fxt sti
Fullers Garage
If it is all stock running the td04I don't think you could make 29 psi. You also should have hit fuel cut if you did.
