Old 03-08-2013, 09:38 AM   #1
gtasti
Member#: 152036
2004 Sti
Default Id1000s and tic tgvs not fitting ?
So my problem is my id1000s aren't fitting into the tic tgvs
Is it supposed to be really tight ?
gtasti is offline   Reply With Quote
Old 03-08-2013, 09:49 AM   #2
mccanixx
Member#: 60566
2005 XT 5sp, 02 WRX
01 Legacy 95 Impreza L
I have id1000's in tic tgvs. Fit like a glove, NO issue. Aeromotive rails but should be no different.
Mine are the metal manifold version.
mccanixx is offline   Reply With Quote
Old 03-08-2013, 10:13 AM   #3
gtasti
Member#: 152036
2004 Sti
I have the same tic tgvs is it possible the injectors are wrong then
I'm go check later at my buddy's shop to make sure I don't have the wrong injectors
Old 03-08-2013, 10:16 AM   #4
momoscoobiedoo
Member#: 276198
are you sure you have the gasket in the correct way because mine fit amazingly. i have boomba fuel rails and parallel lines only problem im having is all my godamn back fires and misfires. cause of everything else i did
momoscoobiedoo is offline   Reply With Quote
Old 03-08-2013, 10:28 AM   #5
gtasti
Member#: 152036
2004 Sti
Pretty sure the plug faces up no other way to put it in
I'll have to measure the whole and injectors supposed to be 14mm
Old 03-08-2013, 10:33 AM   #6
mccanixx
Member#: 60566
2005 XT 5sp, 02 WRX
It's hard to mess up gaskets when one is a symetrical donut and the other is an o-ring.
Old 03-08-2013, 10:45 AM   #7
gtasti
Member#: 152036
2004 Sti
So I talked to the original owner he says I need to snip the small black piece at the bottom
Has anyone else had to do this ?
Old 03-08-2013, 11:12 AM   #8
mccanixx
Member#: 60566
2005 XT 5sp, 02 WRX
Nope. What small black piece? the injector, the gasket?
I've never had to do anything with them besides replace seals. Right from the factory tgvs to the composite.
I assume these are bosch topfeed id versions.
Old 03-08-2013, 11:15 AM   #9
gtasti
Member#: 152036
2004 Sti
There's a black plastic piece holding the o rings on that is what's stopping it from going into the tgvs
Old 03-08-2013, 11:21 AM   #10
mccanixx
Member#: 60566
2005 XT 5sp, 02 WRX
Hmmm. I had mine on factory rails before the aero's with no modification. News to me, but I bought the injectors brand new awhile ago. Sometimes it's a pain to get them both aligned? Idk
And the oring is on the rail side so it would prevent it from seating in the rail. If that's the scenario..
Old 03-08-2013, 11:23 AM   #11
25rsti
Member#: 166324
Post some pictures if you could. I would definitely hold off on cutting anything just yet.
Old 03-08-2013, 11:26 AM   #12
gtasti
Member#: 152036
2004 Sti
yeah i just did do you guys notice the black piece at the bottom i was told this has to be removed
Old 03-08-2013, 11:33 AM   #13
mccanixx
Member#: 60566
2005 XT 5sp, 02 WRX
Measure. Don't think they sit that deep.
Old 03-08-2013, 11:37 AM   #14
gtasti
Member#: 152036
2004 Sti
The o ring doesn't even go in that black piece stops em from seating
Old 03-08-2013, 11:45 AM   #15
mccanixx
Member#: 60566
2005 XT 5sp, 02 WRX
Unmodified. My lower seal is different however
Old 03-08-2013, 11:46 AM   #16
the suicidal eggroll
Member#: 51961
2005 STi
2012 WRX
You do know they don't go in that direction, right? I hope you just took the picture with them oriented like that because it made the size restriction more apparent...
Old 03-08-2013, 12:01 PM   #17
gtasti
Member#: 152036
2004 Sti
Your really asking that lol
Yes I no that's wrong way but the other way u won't see anything
Mcc do u got a pic of the injectors before u installed ?
Old 03-08-2013, 12:04 PM   #18
Member#: 51961
2005 STi
2012 WRX
Just making sure. We get a lot of idiots on this site, sometimes the dumb questions have to be asked.
Old 03-08-2013, 12:10 PM   #19
Concillian
Member#: 4414
2002 WRX Sedan
Midnight Black
That ID1000 looks nothing like mine.
Mine don't have the black "shelf" and 2 o-rings, they have no shelf and a very thick o-ring in all dimensions that slips on the end just like the stock ones. (looks like this http://www.t1racedevelopment.com/ind...o-cushion.html )
Are you sure you have top feed ID1000s and not the ones that were made for the T1 Race Development sidefeed --> top-feed conversion kit? The ones for the top feed conversion kit don't fit normal top-feed TGVs. You can see in this picture that there's WAY more clearance around the injector on the side-feed TGVs: http://www.titanmotorsports.com/t1sutopfefur.html
I think you have the wrong injector.
Concillian is offline   Reply With Quote
Old 03-08-2013, 12:10 PM   #20
mccanixx
Member#: 60566
2005 XT 5sp, 02 WRX
Nope. But in my pic you can see your smallest tab at 9 oclock.
Old 03-08-2013, 12:13 PM   #21
gtasti
Member#: 152036
2004 Sti
No worrys lol
I got them from a member on here so they can possible be the ones for the conversion setup then fml
Ok thanks
Old 03-08-2013, 12:27 PM   #22
Concillian
Member#: 4414
2002 WRX Sedan
Midnight Black
If this is the case you can try to send them back since he probably advertised them as normal top feeds. He may not have known that these were not just regular top feeds.
Or you can call T1 Race Development and explain that someone managed to dupe you into buying them and see if they have any advice for modifying them to fit... You NEED a good seal there or you'll get a boost leak through the injector mount hole. It should seal well on bottom and sides.
This is what they should look like:
http://forums.nasioc.com/forums/show....php?t=2165382
Old 03-08-2013, 02:47 PM   #23
gtasti
Member#: 152036
2004 Sti
yeah thats exactly what happen i tried to save a few bucks and in the end i got ****ed
so i went to my buddys shops and here are the 2 side by side u can see mine are totally different
the top bottle necks up which doesnt allow for them to sit proper into the rails as well
Old 03-08-2013, 03:15 PM   #24
juanmedina
Member#: 133146
07 FPgreen [email protected]
WRX VF39+E85 12.0, 121mph
I have 1200cc injectors for sale if interested. They are amazing...
Old 03-08-2013, 03:18 PM   #25
STIBungy
Member#: 51684
You had to be "that guy".
This is a tech thread.
STIBungy is offline   Reply With Quote
