Old 03-08-2013, 10:55 AM   #1
Jojipoji
Member#: 346767
2013 Sti
World Rally Blue
Default FP green with no exhaust mods? possible?
Want to go stealth with a stock spool like turbos such as a fp green. I dont want to touch the downpipe/uppipe/exhaust at all. Just want more hp. Could I just drop in a fp green + injectors + intake and tune? Would I have to worry about back pressure? looking for about 330-350 whp. would such a set up be reliable? Should I expect the ringland issue to pop its head? Car has 1500 miles on it as it sits. Budget is 2-3k
Jojipoji is offline   Reply With Quote
Old 03-08-2013, 11:00 AM   #2
HinshawWRX
Medium Frank
Member#: 140114
2014 Porsche
GT3 (Currently on Fire)
You need to do a lot more research.
Old 03-08-2013, 11:02 AM   #3
eg33GC
Member#: 206851
56 Belair
Pro Street
you realize that stealth and a wrx are impossible, right?
eg33GC is offline   Reply With Quote
Old 03-08-2013, 11:04 AM   #4
Loyale93
Newbie Moderator
Member#: 91347
'13 XV Crosstrek,12
1050 Triumph Speed Triple
For the love of...
Read this. All of it.
http://forums.nasioc.com/forums/showthread.php?t=533787
Best bang for your buck for more power is downpipe and a tune. Putting in a bigger turbo, injectors, and tune, but no exhaust is asinine. You're basically giving someone a pool of water that they have to move from A to B, but they have to use a spoon. An exhaust will allow more airflow. More air = More fuel. More fuel = More speeding tickets.
Loyale93 is offline   Reply With Quote
Old 03-08-2013, 11:06 AM   #5
Heedlessone
Member#: 254130
1993 LS1 RX7
Possible? Of course it is.
Smart? No, you're a dumb-dumb.
Heedlessone is offline   Reply With Quote
Old 03-08-2013, 12:42 PM   #6
al82
Member#: 177913
2011 WRX STi PBP
I have to agree, yes you can bolt on whatever turbo you like but the stock exhaust system is going to kill the performance. If you want stealth I would suggest just changing your downpipe to a catted downpipe. Then you can make the power you want without too much noise.
al82 is offline   Reply With Quote
Old 03-08-2013, 12:43 PM   #7
alecb
Member#: 335146
2004 STi
Looks like someone has a lot of reading to do..
alecb is offline   Reply With Quote
Old 03-08-2013, 12:54 PM   #8
be0tch
Member#: 66206
2005 WRX STi
You'll need a downpipe, plus the injectors and fuel pump, a new intercooler, tgv deletes and a turbo inlet at very least.
This dyno sheet was with an FP HTA Green, aftermarket downpipe and the stock catback, but a bunch more parts, like intercooler, turbo inlet etc.:
My build thread is here, http://forums.nasioc.com/forums/show....php?t=2421905 and you'll need mostly all of that stuff.
My advice to you is don't do this on a small budget. You're going to break something or realize you need to spend much more than you thought and end up with either a bunch of parts sitting around for you to get some more money or in the worst case scenario, a broken car that needs an engine rebuild ($$$$) and a new turbo ($$).
edit: you're in CT. Call EFI at 203.748.1115 and see what they want you to install at minimum to support a Green-sized turbo.
be0tch is offline   Reply With Quote
Old 03-09-2013, 08:55 PM   #9
Jojipoji
Member#: 346767
2013 Sti
World Rally Blue
I understand and fully aware that dp and other mods would give more hp with a bigger turbo. My question is it safe for the motor to have a bigger turbo and stock everything else except for injectors and tune.
Budget is not the problem. I ran into exhaust smell/loudness with my Evo and am trying to avoid a similar situation. I just want 320-350 without having to touch the exhaust and the only way to get there seems to be a fpgreen.
Old 03-09-2013, 08:58 PM   #10
Scanyland
Member#: 282593
1996 Subaru Legacy
is there a reason you don't want to touch the exhaust
Scanyland is offline   Reply With Quote
Old 03-09-2013, 09:58 PM   #11
fmauriwrx
Member#: 154806
2011 SWP WRX
Yes, it's a wonderful idea and your motor will be fine. Enjoy.
fmauriwrx is offline   Reply With Quote
Old 03-09-2013, 10:28 PM   #12
mod maniac
Member#: 300551
2002 FOZ STI 2.34
Fullers Garage
There are exhaust systems that flow, are quite and have cats. I also keep my wagon on the down low. you can do it on the stock exhaust but it is easier to do on after market exhaust. Stealth is sweet I do that also however it does make things a bit harder.
Old 03-09-2013, 11:10 PM   #13
Navendra94
Member#: 327495
2012 Impreza WRX 5DR
Plasma Blue
If you want "stealth", downpipe + stock catback = done.
Research please ._. and check this thread out for more "stealthy" choises for exhausts if you don't want stock :
http://forums.nasioc.com/forums/show....php?t=2461182
Navendra94 is offline   Reply With Quote
