#1 |
Member#: 307725
Vehicle:2012 WRX ISM |
https://docs.google.com/spreadsheet/...EE&usp=sharing
My car was tuned back in October and has been great ever since 2012 WRX Tsudo Catless DP K&N SRI Invidia N1 Street TBE GS EBCS Cobb AP Tuned on 93 Now I'm getting ready for another round of mods and getting tuned for E85, the only change I made so far was installed my GS Upipe/Tial 44mm EWG. When my car was tuned, my tuner also made me a low boost map, which I flashed to after installing my EWG. Haven't been retuned yet, im waiting on my injectors and an intercooler. Do you think the EWG is causing it to run like this? I'm careful with the car since installing it, and barely ever get into boost. Is something wrong with the car?
#2 |
Member#: 277487
NWIC
Vehicle:2006 CGM WRX Limited 6sp, 18G, Phatron tuned |
Nice IDC's. Your DAM is also dropping. You need a tune for the EWG. I would not do any further pulls until you get it sorted.
#3 |
Member#: 73884
International
Vehicle:2005 STi 2006 Evolution MR |
You cannot run an EWG on a map tuned for a stock IWG.
There is a SIGNIFICANT difference between the two - hence your significant problems.Your best bet is to disconnect the EWG, reconnect the IWG, and reset the ECU until you get tuned for the EWG. Seriously..., you are lucky you did not blow up your engine. |
#4 |
Member#: 73884
International
So I actually looked at TD Boost Error compared to the boost column and your target boost for the entire RPM range is 21.25#
How is that a low boost map? |
#5 | |
Member#: 307725
#6 |
Member#: 254130
NWIC
Vehicle:2004 STI Hurr hurr |
It's over boosting because your WGDC are way higher for an IWG than an EWG. Get a tune, now, or put the stock up pipe back on.
You're causing damage to the engine. |
